Does sitting in direct sunlight for hours affect (effect) ignition?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 747, Mar 24, 2008.
  1. Mar 24, 2008 at 6:18 PM
    747 [OP] function > form
    1st Gen.
    I had this problem with my Honda...but I've never heard of it with Toyotas!?. I had no problems starting this winter, but now that the sun's come out, I may have to let the truck turn for 4 or 5 seconds before it catches (doesn't sound like a long time, but time it out yourself...a little too long for normal, eh?).
    Anyway, with my Honda it was a common occurrence and was easily diagnosed and cured. With my tacoma though, it's a little tougher...I was planning on digging into the throttle body and cleaning the same this weekend, and thinking about the distributor cap, wires, and rotor, but thought I'd check with you guys first. I have new platinum plugs and all belts have been replaced (4k miles ago) and, otherwise, I've had no problems. Truck has 68k miles on it.
    Note: I don't know if 4 to 5 hours in direct sunlight has anything to do with the problem...but the weather's all that's changed in the past few weeks (i.e., the problem began occurring 2-3 weeks ago; doesn't occur every ignition attempt, just sometimes). However, the truck can sit in my garage for over a day, and will start w/o incident thereafter (but I don't have a garage at the office, and I don't want to get stranded).
    Any and all suggestions are welcome.
  2. Mar 24, 2008 at 6:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    there was a tsb for a problem that occured with some of the 05 and up tacomas, which was an extended start tsb. basically,they reflash the ecu. take it to the dealer and tell them its cranking for too long without starting and they should take care of it. mine did this for a while, and since they reflashed it, its been cranking just fine.
  3. Mar 24, 2008 at 7:14 PM
    1st Gen.
    Forgot to mention that I drive an 03 w/the V6.
  4. Mar 24, 2008 at 7:30 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    oh..............well, that makes a difference:)!! how old is your battery?? if its the original,by chance, it may be time for a new one. or it could be time for rotor cap/button, and maybe plug wires depending on mileage.
  5. Mar 24, 2008 at 7:37 PM
    1st Gen.
    The more I think about it, the more I think I'll replace the wires, cap, and rotor, and give the throttle body a good once over. The battery feels strong, but I should (i.e., will) have it tested.
    Ahh, maintenance. What else would I do on the weekends? (besides beating my wife and kids) :D That was a joke...I don't have a wife or kids to beat.
    Thanks, bud.
  6. Mar 24, 2008 at 7:40 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    let me know how it turns out. by the way.......try some seafowm deep creep on the throttle body.....thats some good stuff there. you do all that.......you'll be running like new!!
  7. Mar 24, 2008 at 7:40 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    The '03's don't have a cap and rotor. It has coil packs on each cylinder.
    Run some Seafoam through it and check the battery, better yet drop a Red Top in it.
  8. Mar 24, 2008 at 7:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    oops....i thought the 03's had cap and rotor:eek:!! ok, maybe just change plugs then, and definitely run seafoam thru it(you can run it thru the brake booster line.....it'll smoke like hell, but it'll clean like crazy!!), and clean throttle body with the deep creep.
  9. Mar 24, 2008 at 7:54 PM
    1st Gen.
    Coil packs on each cylinder...wtf is that? Don't answer, I'll find it, and educate myself accordingly.
    Thanks fellas...I'll keep you posted.
  10. Mar 27, 2008 at 5:50 PM
    1st Gen.
    Battery's good. Ran some seafoam through the tank, but issue persists (occurred once today). I'll dig into the throttle body this weekend (got deep creep as advised). Also, called local Toyota dealership service dept...they thought battery might be the problem also. Toyota also said that reflashing wouldn't do anything for me, but I could try it anyway if I wanted.
    Hmm...
  11. Mar 27, 2008 at 5:57 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i think i'd have it reflashed if it isnt gonna cost you too much to do so. may help your problem. also......may want to keep an eye on one of the coil packs, may be breaking down and causing your problem. not sure.....just trying to eliminate certain things.
  12. Mar 27, 2008 at 7:36 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    BKieth check your PM's
  13. Mar 28, 2008 at 8:13 PM
    glassdoc
    glassdoc Well-Known Member
    Spring City, PA 19475
    04 DubCab 260,000 miles
    Stubbs Sliders, 2.5" lift, Ken-Mtn Bumpers, Leather Seats, AM/FM/CD/DVD & CB, IP Trans-Upgrade, (2) Trans Coolers, Synthetics Thru-out
    What brand fuel filter are you running? Could be a vapor issue. Maybe the vent on your gas cap is closed up from dirt etc. If it happens only after sitting in the sun/heat, its more than likely a fuel issue. Does it crank easy? Or is it slow?
  14. Mar 28, 2008 at 9:12 PM
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I sent him the TSB for Hard Cranking on the 03 and 04 Tacomas.
  15. Mar 28, 2008 at 10:50 PM
    1st Gen.
  16. Mar 28, 2008 at 10:56 PM
    747
    1st Gen.
    Thanks, glassdoc! It cranks quickly (normal), but it doesn't catch (ignite). I'm going to try the new harness as indicated by the service bulletin. If that doesn't work, I'll move on to the fuel filter and throttle body. In any case, thanks much for your input!
  17. Mar 29, 2008 at 9:36 AM
    747
    1st Gen.
    The wiring harness costs in excess of $300...I'll live with the hard cranking and I'll wait until it won't start. Even the Toyota rep. was surprised at the price.
  18. Mar 29, 2008 at 10:34 AM
    747
    1st Gen.
    Called Toyota's national customer relations department ("NCRD"). NCRD representative stated that because my vehicle was out of warranty, the wiring harness would not be provided at a discounted price. I asked whether I understood the technical service bulletin (#EG042-04) correctly inasmuch as it indicated that Toyota acknowledged a defective design or manufacture, and acknowledged that such defective design or manufacture caused the issue/damages that I was complaining about. The NCRD rep. confirmed my understanding, and stated that I could speak with the corporate representative of the local dealership to try and work something out.
    Local dealership service department refused coverage as the truck is out of warranty.
    Time to put on my lawyer pants and send out a few demand letters...or not...I'll see.
