Does the locker become easier to engage?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by aaronk, Jun 28, 2009.
  1. Jun 28, 2009 at 8:06 PM
    aaronk
    aaronk [OP] Well-Known Member
    2009 Dbl Cab V6 TRD
    TRD OR package and I've only engaged the locker a couple times to make sure everything works OK. So far it hasn't locked in without me driving forward a bit and turning the wheel a little. I'm just wondering how I'm going to engage the locker if/when I get stuck and am not able to drive forward and turn the wheel. Is this considered normal or will I eventually be able to get it locked as soon as I hit the button?
  2. Jun 28, 2009 at 8:11 PM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    It sounds ike the gears just have to differentiate a little before it will lock. If you're stuck and one wheel is spinning it will do the same. Just make sure you only give it a little bit of power until it locks.
  3. Jun 28, 2009 at 8:21 PM
    thecreeper
    thecreeper Well-Known Member
    interesting, while test driving the TRD OR today the rear locking diff did not engage (we were off road). but the salesman said it did but...anyway it did not so i wasn't sure what was up. i just assumed the gears needed some time to "figure it out" before locking but they never did and the salesguy didn't want me engaging it in the first place... interesting...
  4. Jun 28, 2009 at 8:29 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    sounds sketchy to me...
  5. Jun 28, 2009 at 8:36 PM
    aaronk
    2009 Dbl Cab V6 TRD
    I've got 1600 miles on the truck thus far, so it's still pretty new. The first time I tried to engage the locker, nothing... Drove it slowly forward for a ways and still nothing. Double checked the owners manual, tried it again with the exact steps listed and still nothing. Though I was going to have to go back to the dealer but then read a thread on here about sometimes having to turn the steering wheel to get it to engage. The next time out I did and you could hear it lock in to place and the flashing light on the dash glowed solid confirming it.
  6. Jun 28, 2009 at 9:38 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    The last few times I have used it I had to be at a complete stop before i pushed the button. Then I rolled forward a little to get it to engage. But, it will not engage if I push the button while rolling forward.
  7. Jun 29, 2009 at 4:32 AM
    thecreeper
    i am sure it works... but the salesguy was so paranoid we were gonna mess something up. if he just let me continue driving in a straight line i bet they would have engaged. but when i test drove a Nissan and pushed the button for rear locking it did lock up within a few seconds i'd say...
    edit - ok so you need to be stopped to engage the lock? i was not stopped nor did i move the steering wheel...
  8. Jun 29, 2009 at 9:45 AM
    djs05tacoma
    djs05tacoma Well-Known Member
    Martinez, CA
    05 Double Cab TRD offroad 4x4
    3" OME Lift, 285's
    Definately seems to get easier the more you use it. I've got about 60k on my truck and the first few times it took a while to engage but now it seems to engage a lot faster.
  9. Jul 3, 2009 at 3:12 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    Read the owners manual, it states from a stop, press button, drive forward slowly and turn wheels to engage. thats exactly how mine works.
  10. Jul 3, 2009 at 5:49 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    +1 It helps to be moving a bit for it to engage.
  11. Jul 3, 2009 at 6:30 PM
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    I have 37k on mine and have only used the locker a couple times. i went out today to do a check on my locker mod wiring job( i know, quite a bit of time i let go by before testing my work:) ) when i push the locker button it takes not even a second for the light to display solid. I also put it in 4 Low and 4 hi and tried all these then would move forward and backward each time i tried a different combo. I never heard a clunk at all. i guess i'm just lucky?
