Does the V6 alternator fit on the 2TR-FE engine?
Discussion in '4 Cylinder' started by TireFire, Jul 29, 2016.
  1. Sep 10, 2021 at 12:24 PM
    #81
    Sscustoms
    Sscustoms Well-Known Member
    Seth
    05 taco 2.7 5spd
    -315s on Methods -5.29 gears -Arb/Detroit lockers -Twin Arb compressor -LCE header -mandrel 2.5” side exit exhaust -4X rock sliders -LCE dual comp clutch
    Its also cheaper that route. But for kicks i did contact powerbastards this morning about theirs and they did confirm that even with the smaller pulley they equip their alts with it is totally safe on a 2trfe crank pulley to turn higher rpm on a built engine ~6500rpm.
    The sales rep said as long as the crank pulley is 6” or smaller it will be totally fine. I just measured a 2006 pulley and the diameter on the ID belt surface is 5-3/8”. Flush with the back of the belt is 5-3/4”. We good folks
  2. Sep 10, 2021 at 12:27 PM
    #82
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    Not at idle your alternator won’t give you 90A. likely a little more than half.
  3. Sep 10, 2021 at 12:27 PM
    #83
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    as someone who has had various sub set ups. lights almost always flicker @ stop lights. i wouldnt worry about it. your battery will just die pretty quickly. maybe 1year 2 y ear tops.
    have a spare battery with you and dont worry about it.
    Sscustoms likes this.
  4. Sep 10, 2021 at 12:32 PM
    #84
    Sscustoms
    Seth
    05 taco 2.7 5spd
    Good point though. My stock 2TR Denso alt is only 80amp and if your pulling a deafening 50amps then add the fuel pump, the dash lights, the ignition system, running lights the blah blah. Lots of little normal draws. A 4banger stock system is definitely not able to keep up with the pulled amps. A really nice AGM will mask the problem at slow speeds but the source of amps with a quality battery is the real answer.
    fiftyxp[QUOTED] likes this.
