Does thes dakars look correct ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dacapster, Nov 5, 2017.
  1. Nov 7, 2017 at 7:30 AM
    DaveInDenver
    DaveInDenver Not Actually in Denver
    David
    Grand Junction
    2008 Super White TRDOR AC 6MT
    Unexceptional
    I didn't get anything noticeable. I did drop the carrier bearing but I'm not sure it was absolutely necessary.
  2. Nov 7, 2017 at 7:32 AM
    RCRcer
    RCRcer Well-Known Member
    2015 OR DC
    Good to know and lucky you! Thanks for the feedback
  3. Nov 7, 2017 at 7:38 AM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    I have a shudder when taking off from a stop. I've dropped my CB and just installed 3.5 degree shims last weekend. Seemed to help some but hasn't completely eliminated the issue. I have some 2.5 degree shims on the way to try next. I was too lazy to measure my angles so now that I have the new pins in the packs I'm just going to swap shims a few times to see what works best.
    I would consider adding the pins before you install, just in case you have to add shims. Basically just like the normal pins but with a washer that extends the head to clear the shims after installation.
  4. Nov 7, 2017 at 7:48 AM
    RCRcer
    2015 OR DC
    Thanks! Best of luck solving your vibration issue. If the 2.5 shims don't do it for you I would get unlazy and measure.
    rollin904[QUOTED] likes this.
  5. Nov 7, 2017 at 8:00 AM
    Captainskidmark
    Captainskidmark Well-Known Member
    Northern Illinois
    2015 4X4 TRD SPORT DCLB ~ Black
    ECGS 4.56 gears with Detroit True Trac in the rear. Camburg Ball Joint UCAs Dirt King LCA Dobinson IMS rear shocks Dobinson IMS w/ 352 coils DAKAR EL096 HD LEAFS AR172 17"x8" BAJA RIMS (5 wheel/tire rotation) GX470 Front Brake Upgrade SS extended brake lines Front and Rear (Toytec) 285/70/17 BFG A/T Toyota Roof Rack over Cab A.R.E. Z series CAP with Rhino Rack rooftop rails , -RED/WHITE LED BED LIGHTING -12V AUX POWER AND USB MAGNAFLOW CAT BACK RAAMmat Sound Abatement Pioneer AVH-2440NEX w/ Android Auto + Morel Speakers 120 VAC Block Heater Pelfreybilt Front/Mid Skids ATH Bed Braces ATH FRONT BUMPER - FULL LOOP BAJA DESIGNS FOGS HERETIC 20" LIGHT BAR ATH REAR BUMPER - STANDARD RIGID FLUSH MOUNT REVERSE LIGHTS Weathertech floor mats Rear Diff Breather Mod Wheeler's Super Bumps + Ubolt Flip Kit ABS Kill Switch Mod Northstar AGM Battery Pedal Commander Desert Does It Seat Spacers
    If you are referring to the wavey appearance, mine look like that too....or if you think the bottom 2 springs look upside down, those are the overload springs.
    I have been happy with the Dakars (2nd truck with them), they turn the Tacoma into an actual truck.
  6. Nov 7, 2017 at 9:21 AM
    Dacapster
    Dacapster [OP] Well-Known Member
    Hugh
    14 trd
    Many coming
    Very bad take off vibes. Did 3 deg shim in the back and an OME CB drop. Needed another .045 at the CB to get it smooth.
  7. Nov 7, 2017 at 9:35 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Youre running the light dakar EL095 packs? If so how much weight do you have in the back in addition to your cap? Not trying to thread jack, but around 23.5-24 is where i want to end up and i have about 500lbs constant load in the back of mine..
    Ive been trying to get feedback from others on what pack theyre running, the lift they have and the amount of constant lod they carry..
  8. Nov 7, 2017 at 10:08 AM
    Dacapster
    Hugh
    14 trd
    Many coming
    No cap -
    empty
