Does this look right? PICS
Discussion in 'Long Travel Suspension' started by lilgerber, Nov 15, 2012.
  1. Nov 15, 2012 at 5:24 PM
    #41
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    Just because the spanner is far down doesnt mean there is alot of preload. It could just be where it is resting since it is a longer shock.
    I just built one of these truck, it is currently sitting in my shop and I can guarantee that a normal 8" will not work with an extended rod end. OP, take the shock off, pull the spring off and cycle the suspension, If the shock bottoms out way before the uniball binds out, you will have your answer right there.
    Before you go hacking apart your coil bucket, try putting the top mount on upside down to see if it will even clear.
  2. Nov 15, 2012 at 6:16 PM
    #42
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    x2
    That's about where an 18" spring sits on a standard 2.5x8 coilover. My 18's have zero preload and I have more exposed threads than that.
  3. Nov 15, 2012 at 9:34 PM
    #43
    rcfreak201
    rcfreak201 Well-Known Member
    He can't take out anymore, the spring gets loose.
    This^
    500lbs 18" spring with zero preload. Sorry its the only pic I have.
  4. Nov 15, 2012 at 10:23 PM
    #44
    Bobber Bill
    Los Angeles, CA
    Holy cow! That's not at ride height is it?! Hope you're flexing in the picture...
    Do you know your coilovers' ext/comp lengths? Have you cycled your front for travel numbers? I'm assuming those are standard off the shelf 2.5x8s, and not Tacoma specific.
  5. Nov 15, 2012 at 10:23 PM
    #45
    rcfreak201
    No its not at ride height at all lmao. its flexing on a bump.
  6. Nov 15, 2012 at 10:24 PM
    #46
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    flex hahaha
  7. Nov 15, 2012 at 10:30 PM
    #47
    Bobber Bill
    Los Angeles, CA
    Those other questions were for you too. About the lengths and travel etc...
  8. Nov 15, 2012 at 10:35 PM
    #48
    rcfreak201
    Yeah I have the lengths written down somewhere but they're standard 2.5x8s. I haven't taken the spring off and cycled it yet and I don't know how much travel I'm exactly pulling. That pic was with the camburg spindles but since then I've added preload and swapped to stock spindles.
  9. Nov 15, 2012 at 10:38 PM
    #49
    Bobber Bill
    Los Angeles, CA
    Cool. Well I'll find out for myself as soon as I get my spacers back from the machine shop.
  10. Nov 15, 2012 at 10:46 PM
    #50
    M C M
    Matthew
    Sin City, Nevada
    The coilovers ADS builds me are 17.5 collapsed and 25.5 extended. This is with a 2" extended lower rod end for the 2nd gen
    The ones they build for my 1st gen stuff is 15.5 collapsed and 23.5 extended
  11. Nov 16, 2012 at 6:20 AM
    #51
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
    That is almost identical to off the shelf 8" Fox coil overs.
    charge.
    From Down South Motorsports web site.
    Shock Travel Extended Length Collapsed Length
    8.0" 25.43" 17.50"
    10.0" 29.43" 19.50"
    12.0" 33.43" 21.50"
    14.0" 38.43" 24.50"
    16.0" 42.43" 26.50"
  12. Nov 16, 2012 at 6:55 AM
    #52
    M C M
    Matthew
    Sin City, Nevada
    Now add 2" to those numbers so your comparing apples to apples. A standard lower rod end will not clear the axle. The problem he is having is he added an extended rod end to a standard length shock.
  13. Nov 16, 2012 at 7:14 AM
    #53
    05TacoRunner
    Peoria, Az
    I understand what you are saying, but that is why on the 4wd the coil bucket is cut, the adapter is flipped and the shock is moved up a few inches. If he does that per TC instructions it will compensate for the longer rod end.
  14. Nov 16, 2012 at 7:39 AM
    #54
    M C M
    Matthew
    Sin City, Nevada
    If that bracket clears the king top cap that may work
  15. Nov 16, 2012 at 10:13 AM
    #55
    lilgerber
    lilgerber [OP] Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    I also have a flat steel top plate mount, I'm going to use that one and flip it to see where that puts me today after work.
    Then decide from there if I need to cut bucket, or if they will even work.
    If they don't work out, I'll post them for sale with both rod ends on here.
  16. Nov 16, 2012 at 10:15 AM
    #56
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    if that doesnt work, before you start selling stuff take off your spring and cycle
  17. Nov 16, 2012 at 10:20 AM
    #57
    RAD
    RAD Well-Known Member Vendor
    Rad
    LAX & LOGAN
    ^ Do that first before you sell out those coilovers. I'm sorry you ran into this issue. I knew my kit was perfect for what you were looking for and wanted to help you find Coilovers. . .
    I really hope it all works out soon enough for you. . .
  18. Nov 17, 2012 at 2:50 PM
    #58
    lilgerber
    Aaron
    Fresno, CA
    Well I tried to flip and just mount the top plate but had to cut the coil bucket. Here is how the the uniball is setting now .
  19. Nov 17, 2012 at 3:26 PM
    #59
    Bobber Bill
    Los Angeles, CA
    Two things:
    Number 1: Weld in a half section of tube to bridge that gap in your coil bucket. Do not wheel before you do that, the bucket will collapse if you apply enough force.
    Number 2: That's an improvement, but like myself and a couple others have said already - call TC if you haven't already. TC kits are made to work with short body shocks, and I'm pretty certain that what you have is not the right part.
  20. Nov 17, 2012 at 3:30 PM
    #60
    lilgerber
    Aaron
    Fresno, CA
    Yes but only has one side completed so I have a good taco lean going on. I will be doing the other side tomorrow morning.
    I also tried to adjust the spring preload but its already max out. ( 8 threads on shock)
