Does this look right? PICS
Discussion in 'Long Travel Suspension' started by lilgerber, Nov 15, 2012.
  1. Nov 17, 2012 at 3:34 PM
    #61
    Bobber Bill
    Bobber Bill Well-Known Member
    Los Angeles, CA
    Prerunner Daily Driver
    If you buy the correct shocks, your problems are over.
    If you don't want to buy new shocks, you still have options.
    1. Cut out your coil bucket and fab new upper mounts. You'll have every inch of up-travel back if you do this right, maybe even an extra inch.
    2. Remove all preload and run a helper spring. You'll have to properly limit your droop so that your coil doesn't bounce around. Full droop is possible, full up-travel is most likely not.
  2. Nov 17, 2012 at 3:37 PM
    #62
    lilgerber
    lilgerber [OP] Well-Known Member
    Aaron
    Fresno, CA
    06 4x4 off road Speedway blue
    Front: Total Chaos 3.5 4x4 LT kit, Engage off-road one piece hood, Caged front end, TC gussets. Rear: Fiberworks fenders, King 14" 3.0 triple bypasses, boxed/braced frame, extended brake lines, 63" chevy leaf springs, U bolt flip kit, TC lower shock mounts. Preformance: URD intake, Doug Thorley headers, Flowmaster 40, 2.5 tubing. Interior: Weather techs, LED's, Double DIn, kicker 10" subs, Kicker componet speakers, Exterior: Method wheels with OMF beadlocks, Custom made bumpers, Retro headlights.
    TC was closed friday, so I haven't contacted them. I wanna try and make these work since I'm stuck with them. Good point closing the gab.
    I plan on getting the TC secondary to also strengthen the coil bucket.
