Does this look right?
Discussion in 'Off-Roading & Trails' started by 06Bluez, Dec 27, 2008.
  1. Dec 27, 2008 at 1:54 PM
    06Bluez
    06Bluez [OP] Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    Those of you who haven't heard I jacked up my Taco doing some light off roading. I have already ordered the new shocks and UCA's. But I just noticed this part seems to be bent. Can I just replace the bolt or do i have to replace the whole part?
  2. Dec 27, 2008 at 2:01 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Here is the passenger side. Seems to be perfectly straight. What is this part called so I can look it up?
  3. Dec 27, 2008 at 2:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Looks like your sway bar. Hard to tell in the pics, but worst case, you can remove it and still be fine, you'll just have more body roll when takeng a turn.
  4. Dec 27, 2008 at 2:07 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Can I replace that bolt that is bent or is that vertical thing connecting it all one piece?
  5. Dec 27, 2008 at 2:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Its one peice from toyota, but you might be able to find it at a parts shop. It dont look bad, and its not going to affect anything. You may just want to leave it how it is.
  6. Dec 27, 2008 at 3:08 PM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Oh great, so I don't have to worry about that then.
  7. Dec 27, 2008 at 4:00 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    Chris 4x4 is correct, Its non serviceable. I actually replaced one on my brothers Civic and my Fathers F150 in the same month, once they break your sway bar is not attached on one side, the honda was $30 and the Ford was under $10.00 from a good parts store. Look up sway bar end links.
  8. Dec 27, 2008 at 4:14 PM
    Monkeysuncle
    Kevin
    Florida
    I guess Chris was saying the sway bar was bad? In the two cases I replaced the end links in a Civic and a F150, they were both broken. My brother complained of a "clunk" when going over a simple speed bump. My dad was the same. Either way, if you replace the part is easy.
  9. Dec 27, 2008 at 4:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I said it doesnt look bad (Post #5). X2 on it being an easy fix if it was broken. :)
  10. Dec 28, 2008 at 9:00 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    It's not bent at all. Those sway pieces rotate in that area. Nothing is wrong with it. The difference you are seeing is in your sway bar and not that piece. Nothing to worry about.
  11. Dec 28, 2008 at 11:14 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If you are running stock UCA's, you wont get more down travel, just better articulation between the 2 front tires. To get more travel, you need extended coilovers, or shocks used in conjunction with different UCA's. ;-)
  12. Dec 28, 2008 at 12:01 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    Since everyone is calling it "that" piece, I'll let you know that it's called an end link. The end link does not seem to be bent. The other end of that bolt is a uniball and it pivots inside the cup. Unless the bolt it's self is bent the end link is fine.
