Does using GPS apps add to iPhone data usage?
Discussion in 'Technology' started by jrallan26, Jan 1, 2016.
  1. Jan 1, 2016 at 6:51 AM
    jrallan26
    jrallan26 [OP] Well-Known Member
    Iowa
    2004 White D-Cab TRD
    For convenience I use my iPhone as a GPS. Doing this, Does this add to my data usage? Does it matter which navigation app I use?
  2. Jan 1, 2016 at 7:08 AM
    Randys13taco
    Randys13taco Well-Known Member
    Randy
    Portland, Oregon
    13 Tacoma 4x4 DCLB Sport
    Bushwacker fender flares, husky floor mats, avs bug deflector. Avs in-channel vent visors,victory 4x4 roofrack, Naturnest rooftop tep wedge tent, Naturnest shower, Amp power steps, Fuel Vector bronze wheels, 12" antenna, snugtop cap, redline tuning hood struts, Magnum front and rear steel bumpers, rough country 2" front leveling spacer, ridgid dually driving lights, 50qt ARB fridge, 175 watt flexible solar panel and 30 watt solar charger, Rexing dual front and rear dash cam, Viair 150 psi compressor
    Hope this helps you I found this online via google search...... The iPhone is equipped with an integrated GPS antenna which, when combined with the native “maps” app, can create a rudimentary GPS. GPS operates outside of the cellular signal, communicating directly with satellites to determine your position. Every other feature on the iPhone, however, relies on cellular towers or Wi-Fi networks to transmit data. This can result in the GPS using a portion of your allotted cellular data.
  3. Jan 1, 2016 at 7:10 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Most apps do use your data to load the maps. Such as apple maps, google maps, waze...
    Some apps allow you to download a map of a area you will be traveling to before leaving. So if you use wifi at home you can keep your data turned off while on the road.
    Google maps for iOS now allows this. Setting is called "offline areas"
    ecoterragaia likes this.
  4. Oct 24, 2016 at 2:48 PM
    TuffRuffDangerous
    TuffRuffDangerous Well-Known Member
    San Diego, CA
    2011 TRD Off Road 4x4 DCSB
    Salex glovebox/console organizers, Philips H4 MotoVision headlight bulbs, Optilux H10 Extreme Yellow XY foglight bulbs, csjumper2003 LED domelight & license plate bulbs
    I use offline GPS apps such as Here We Go or NavFree on my iPhone 6 Plus. But it's annoying to use it as a GPS when people are calling or texting you, so instead I bought cheap Android prepaid smartphones, added 32gb microSD cards and downloaded offline GPS apps such as Here We Go, NavFree, MapFactor and Sygic. These apps allow you to download maps by state, country or region, so if you're limited by space you can just download the areas you need. You can use these apps like a standalone GPS unit and not have to worry about using data.
    ZTE Maven for $9.99 at Rite-Aid
    https://www.fatwallet.com/forums/hot-deals/1534489
