does your transmission shift late sometimes???
Discussion in 'Technical Chat' started by tacomaman06, Jun 18, 2008.
  1. Jun 18, 2008 at 2:56 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    this past winter, on a few occasions, my transmission seemed to want to shift late a few times. felt really weird, and i knew something wasnt really right about it. took it to the dealership then(for tire balancing) and told them to check the transmission fluid, cause i figured it was low. at the time, the service writer told me, when i came to pick my truck up, that since it was a "drive by wire" system, that the late shifting was normal:rolleyes:!! i called bs on it then, but let it be. took the truck this morning to have the tires balanced again and rear drums adjusted...........and told them to check my transmission fluid again. figured i'd get the same response as before...........but it didnt happen this time. the service writer i work with now(holley at harrelson here in rock hill) said they checked the transmission fluid as i had requested, and it was 3/4 of a quart low!!! just as i suspected. no leaks or anything........just underfilled from the factory. this is just a heads up to everyone here with the sealed w/s toyota transmission on the 05 and up tacomas..........if your truck seems to late shift or ahve a weird shift to it...........have the stealer check the fluid level, as it may be the culprit. could save you some headaches down the road a bit!!:)
  2. Jun 18, 2008 at 4:01 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Only when I get distracted and forget to shift:eek::D:D:D
  3. Jun 18, 2008 at 4:34 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I dunno if its a late shift... but mine feels like it shifts 'hard' into 2nd gear sometimes. Happens pretty consistantly on one stretch of road I always travel on (with same speed, etc).
    I should just take it in and have 'em check it anyway after 1 year...wouldn't hurt (other than the dealership giving me a hard time about doing it).
    So - I would assume your problem is gone?
  4. Jun 18, 2008 at 5:02 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I've had a few times where my Taco seemed to jerk when shifting into second (under normal acceleration).
  5. Jun 18, 2008 at 5:22 PM
    007Tacoma
    007Tacoma I dub thee malicious!
    Mark
    San Antonio, TX
    2015 4Runner Trail Edition Premium
    Cloaking Device
    Mine will do this when I press on the accelerator, and then immediately take it off (sometimes). It thinks I am going to continue to accelerate, but I don't and it shifts hard or too late.
    Is that what you are talking about?
  6. Jun 18, 2008 at 6:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    mine was shifting late, which made it a pretty damn hard shift from first to second a few times......hard enough to know something wasnt right. and honestly.....it feels like when an auto is low on transmission fluid......best way i can describe it anyhow.
    i will let you know as far as if the late shift is gone though, as i will have to drive it a bit more to tell. but im guessing that it should be since they added the 3/4.
  7. Jun 18, 2008 at 6:46 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that sounds kinda like the torque converter trying to lock/unlock in a hurry.......but thats probably more or less what it feels like.
  8. Jun 18, 2008 at 6:51 PM
    007Tacoma
    Mark
    San Antonio, TX
    Cloaking Device
    Well, maybe I should get them to check the level just to be certain...
  9. Jun 18, 2008 at 6:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    it may be a good idea to do so. it took me 2 times up there to get them to check mine......each time stating it was shifting late, but im glad they did.
  10. Jun 18, 2008 at 6:55 PM
    Janster
    Jandy
    Lancaster, PA
    Another question..... is there any difference between a cold tranny versus a warm tranny? I think mine does it mostly when cold and just leaving for work (truck sits for 8+ hours or more).
  11. Jun 18, 2008 at 7:02 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    there actually is, according to the dealership. they said with the new w/s transmission, that it has to be heated up to driving temp. for proper shifts and all...........but mine was acting up after i had been driving for 15 to 20 minutes......plenty of time for it to get up to operating temp. being 3/4 of a quart low may not be too bad.......but it definitely will make the transmission shift "erratically".
  12. Jun 18, 2008 at 7:07 PM
    BlueTaco
    BlueTaco Well-Known Member
    Long Beach, CA
    08 Tacoma Speedwayblue
    I've had the same problem from a dead stop a few times. I'll press the accel and for a sec or so it won't go anywhere then suddenly take off.
  13. Jun 18, 2008 at 7:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd definitely go get the fluid checked.
  14. Jun 19, 2008 at 3:06 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    I have the same situation when the truck is cold. After it heats up, there's no problem from 1st to 2nd. I'm going to the dealership tomorrow for the suspension tsb evaluation and will have them check the fluid. Thanks for the tip Tacomaman06.
  15. Jun 19, 2008 at 2:06 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob man, and better to be safe and get it checked now. good call on that!!:)
