Doin spark plugs, need some opinions.
Discussion in '4 Cylinder' started by SNIPES, Sep 28, 2008.
  1. Sep 28, 2008 at 4:50 AM
    SNIPES
    SNIPES [OP] Well-Known Member
    NY
    04 Access Cab
    Its time to swap out the plugs in my 04 Tacoma 2.7. Im looking for some opinions on which plug to run. There seem to be some big cost differences with all the versions available these days. Anyone advise?
  2. Sep 28, 2008 at 5:09 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i would just suggest to sticking to either denso or ngk standard plugs. that, you'll know that they are the correct heat range and all.
  3. Sep 28, 2008 at 6:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I think the Densos were OEM on your truck. Stick with those and you will be good. :)
  4. Sep 28, 2008 at 7:58 AM
    Bakemono
    Bakemono Wrath of the runbird
    Southern Wisconsin, USA
    '09 Toyota Tacoma regular cab 4x2
    Denso Iridiums. They will last 100,000+ miles.
  5. Sep 28, 2008 at 9:26 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    I always run NGK R's cheap and seem to last a good while
  6. Sep 28, 2008 at 9:56 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Only run Denso or NGK or your rig will run like crap.
    Artruck likes this.
  7. Sep 28, 2008 at 10:57 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    I bought NGK irridiums from Advanced Auto parts. Same price as platinum plugs. Irridium is better from what I have read.
  8. Sep 29, 2008 at 4:37 PM
    Bakemono
    Yup, Iridium is far superior to platinum or double platinum.
    http://www.densoiridium.com/spconstruction.php
  9. Jan 1, 2016 at 10:46 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I put NGK Iridiums in my 2004 2.7 for only one reason. They'll last 100,000 miles. I do plan on pulling them every now and then to look at how they are burning but don't want to HAVE to pull them. Other than that. Copper is a far better conductor than Iridium or Platinum but it doesn't last as long. I'd run the standard copper if I was really worried about fuel mileage and performance but if you don't want to be "required" to pull plugs every 30,000 miles then I'd go Iridium. I put my Iridiums in 20,000 miles ago and haven't even thought about plugs since then. The way the truck runs didn't change a bit and the fuel mileage didn't change either.
