Doing a bunch of repairs... anything I should replace while I'm elbows deep?
Discussion in '1st Gen. Tacomas (1995-2004)' started by chiefO, Mar 13, 2019.
  1. Mar 13, 2019 at 12:24 PM
    chiefO
    chiefO [OP] Well-Known Member
    Fresno, CA
    2005 Tacoma 4x4 Double Cab SB
    So I'm fixing a bunch of crap on the Taco:
    Rack and Pinion
    Driver Side CV and seal
    UCAs
    Clutch
    head gasket seal...
    Anything else I should replace while I have it apart to prevent future repairs? I was planning on doing the transmission seals as well possibly? Oh and the truck currently has 120K on it.
    Thanks all!!
  2. Mar 13, 2019 at 12:26 PM
    eon_blue
    eon_blue Most Improved Member
    Be a good time to do those seals since you'll have the transmission off anyway to do the clutch.
    Maybe consider doing your lower ball joints too with new OEM ones if they are the originals...these trucks are notorious for having weak LBJs
    MacGyvR and scocar like this.
  3. Mar 13, 2019 at 12:28 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Slave Cyl
    Throw Out bearing
    Rear Main Seal
    Inspect U joints
    Inspect Engine Mounts
    Lower control arm bushings
    Ball joints
  4. Mar 13, 2019 at 12:36 PM
    scocar
    scocar hypotenoper
    V6 I assume? If so, was the T-belt and water pump done at 120k?
    Head gasket, or valve cover gasket?
    Consider a new fuel filter too. This is what came out of mine at about 140K
    jammer likes this.
  5. Mar 13, 2019 at 12:37 PM
    chiefO
    Fresno, CA
    Ok so lower ball joints, slave cylinder, and throw out bearing, along with front and rear seals?
    OneWheelPeel[QUOTED] likes this.
  6. Mar 13, 2019 at 12:39 PM
    chiefO
    Fresno, CA
    Checked out my fuel filter already when I replaced the overflow check valve. Timing belt was done around 110
    eon_blue likes this.
  7. Mar 13, 2019 at 12:43 PM
    chiefO
    Fresno, CA
    What about the Low Range lower balljoints onstead of OE?
  8. Mar 13, 2019 at 12:44 PM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    check the tranny and transfer case mounts also!
    chiefO[OP] likes this.
  9. Mar 13, 2019 at 12:45 PM
    scocar
    scocar hypotenoper
    Cool. Oops, I meant due at 90k...standard manual interval.
  10. Mar 13, 2019 at 1:01 PM
    eon_blue
    I would stick with OEM...there are a lot of threads on here in the lower ball joint issues these trucks have and it's due to a poor design, but OEM is the highest quality part you can get for it. There are a lot of horror stories on here from those that have bought aftermarket LBJs...an LBJ failure can be catastrophic
  11. Mar 13, 2019 at 1:04 PM
    chiefO
    Fresno, CA
    Sounds good. I also have a lift on the truck and use it for wheeling every now and then too so that probably a good idea
    eon_blue[QUOTED] likes this.
  12. Mar 13, 2019 at 1:05 PM
    chiefO
    Fresno, CA
    Thanks for the help all. I'll be getting those other parts.
    OneWheelPeel likes this.
  13. Mar 13, 2019 at 1:06 PM
    scocar
    scocar hypotenoper
  14. Mar 13, 2019 at 2:41 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Check valves
  15. Mar 13, 2019 at 3:24 PM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    Why are you replacing your upper control arms? Are you upgrading, or are the bushings just worn?
    You may as well check on the bushings while you're in there. Look for any that are deteriorating or allow a lot of slop.
  16. Mar 14, 2019 at 5:57 PM
    chiefO
    Fresno, CA
    Upgrading. I put on allpro UCAs :bananadance:
  17. Mar 15, 2019 at 8:38 AM
    1997tacomav6
    1997tacomav6 V6 5sp,RegCab,TRD Supercharger,Haltech,meth, 750k
    Denver
    97 reg cab, v6 5sp 300hp supercharged, Methonal Injection, 750,001 plus miles, Original Owner
    V6 5sp,RegCab,TRD Supercharger, 1.9” pulley, methanol injected Haltech ECU, AC TRD supercharger,(MUST DO) TRD supercharger ported, every 125,000- 150,000 needs rebuild Projector headlights HID 5 speed manual Amsoil for all drive train Smaller 2” pulley, (MUST DO) 2004 DESNO fuel injectors, zero ping ping, 2004 side door mirrors Dick Cepek Rims, Michelin tires LTX, ( that last 100,000 miles) Now running Dynopro ATM mud and snow tires KN cold air intake Cat back exhaust with ss exhaust tip, Raised exhaust tail pipe to 2" below body line Optima*dry cell battery,red top Alpine sirius radio, 200 watt amp, focal is165 split door pod speakers Focal door speakers Subwoffer behind seat Viper alarm, Electric Locks Dark tinted windows, bucket seats corbeau lg1 Tacoma Rubber floor mats TRD fender extenders, Bilstien shocks, King shocks nerf bars, add a leaf for rear springs trailer iv hitch, electric brake control, Drilled slotted brakes, High carbon steel (MUST DO) EBS green stuff 7000 series pads(MUST DO) TRD engine oil cap TRD stick shift, Marlin crawl shift kit. Rear sliding window 2002 4Runner functional hood scoop cut into Tacoma hood, 4Runner dual overhead map light Gentex Auto dim + Compass + Temp, garage,rearview mirror Snow Methonal kit stage 2 Custom 3 core aluminum radiator Linex bed liner Haltech stand alone ECU, Intake supercharger gauge. Stainless steel brake lines, Custom leather wrapped steering wheel,
    Don’t forget about that dam fan bracket bearing, it should be replaced when the timing service is done.
    Mine failed twice so I now replace mine every timing belt service now.
  18. Mar 15, 2019 at 8:52 AM
    Wulf
    Wulf no brain just damage
    Kira
    1789 28th St, Boulder, CO 80301
    rock raisin
    Change the front diff fluid, when you pull a CV you will have to top the diff off anyways so might as well make it all fresh
