doing the stereo mod to the double cab 2010 with pics and prices (write up)
Discussion in 'Audio & Video' started by gearcruncher, Feb 20, 2015.
  1. May 22, 2015 at 7:22 PM
    #41
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Well, depends on the sub size and the sub's required room.
    We used to use these for 4th order SPL burp boxes but they do just fine for sealed as well.
    You just have to do the math on it :)
    (3.14*R^2 ) x Length of the tube = x, then take x / 1728 for CF. Im sure there are cylinder CF calculators online though
    Cut a round MDF ring that goes at the bottom, maybe a couple inches up so you can trim the pvc to fit over the hump or obstacle
  2. Jun 6, 2015 at 8:55 PM
    #42
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    how'd the box go
  3. Jun 28, 2015 at 3:08 PM
    #43
    mly
    mly Well-Known Member
    15 tacoma double cab TRD sport
    Did you ever find one of these for hdmi and usb?
  4. Jun 28, 2015 at 5:10 PM
    #44
    gearcruncher
    gearcruncher [OP] Well-Known Member
    Canadain bumper technician
    not yet . i did call metra with my question mind you . Jason said nobody màkes them yet. its been 3 months since i made the call . give him a shout . maybe they are making them now
    Audio/Visual
    Audio And Visual System: Parts Location
    Audio And Visual System: System Diagram, System Description
    Audio And Visual System: How To Proceed With Troubleshooting
    Audio And Visual System: Identification Of Noise Source
    Audio And Visual System: Problem Symptoms Table, Terminals Of ECU
    Audio And Visual System: DTC Check / Clear
    Audio And Visual System: Noise Occurs, Sound Quality Is Bad In All Modes
    Audio And Visual System: Sound Quality Is Bad Only When CD Is Played (Volume Is Too Low), CD Cannot Be Ejected
    Audio And Visual System: CD Cannot Be Inserted Or Is Ejected Right After Insertion
    Audio And Visual System: CD Sound Skips
    Audio And Visual System: Radio Broadcast Cannot Be Received (Bad Reception)
    Audio And Visual System: Steering Pad Switch Circuit
    Audio And Visual System: Illumination Circuit
    Audio And Visual System: Speaker Circuit
    Audio And Visual System: AMP Mute Signal Circuit (From Radio Receiver Assembly)
    Audio And Visual System: AMP Sound Signal Circuit
    Audio And Visual System: Sound Signal Circuit Between Radio Receiver And Stereo Component Amplifier
    Audio And Visual System: AVC-LAN Circuit
    Audio And Visual System: Radio Receiver Power Source Circuit
    Audio And Visual System: Stereo Component Amplifier Power Source Circuit
    Radio Receiver: Components, Removal, Installation
    Radio Setting Condenser (For 1GR-FE): Components, Removal, Installation
    Radio Setting Condenser (For 2TR-FE): Components, Removal, Installation
    Front No. 1 Speaker (For Regular Cab): Components, Removal
    Front No. 1 Speaker (For Regular Cab): Installation
    Front No. 1 Speaker (Except Regular Cab): Components
    Front No. 1 Speaker (Except Regular Cab): Removal, Installation
    Front No. 2 Speaker: Components
    Front No. 2 Speaker: Removal, Installation
    Rear Speaker (For Double Cab): Components, Removal
    Rear Speaker (For Double Cab): Installation
    Rear Speaker (For Access Cab): Components, Removal, Installation
    No. 1 Speaker With Box: Components, Removal, Installation
    Radio Antenna Cord: Components, Removal
    Radio Antenna Cord: Installation
    Radio Antenna Holder: Components, Removal
    Radio Antenna Holder: Installation
    Radio Antenna Pole: Components, Removal, Installation
    Voltage Inverter: Components, Removal
    Voltage Inverter: Inspection, Installation
    Steering Pad Switch: Components, Removal
    Steering Pad Switch: Installation
  5. Jul 13, 2015 at 6:14 AM
    #45
    Zonktified
    Zonktified Well-Known Member
    Rob
    Wisconsin
    Tacoma TRD Sport
    Sub'd for reference...great write up and info links...thank you!
  6. Jul 30, 2015 at 3:19 PM
    #46
    dubbydubs
    dubbydubs New Member
    Richie
    2005 Red Tacoma Prerunner v6
  7. Jul 30, 2015 at 3:22 PM
    #47
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    i see your box is built! and :)
  8. Sep 9, 2015 at 10:26 AM
    #48
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    So, is it all bumping now ? Whats your impression? any final pictures?
  9. Sep 9, 2015 at 6:46 PM
    #49
    gearcruncher
    Just working on the power and ground wires , but here is a sneak peek . I test drove the system last week . The sound was fantastic. When I installed the Mercury tweeters , I used the factory mounts , but twisted the mounts upward in an attempt to raise the sound stage .When I made the templates for the K62,s , I tapered them to fire upward . It worked great . The sound deadening made an incredible difference with the factory speakers , I cant imagine how good its going to sound with the Mercury speakers . I could turn up the music with factory speakers and you could hardly hear the sound outside the truck , yet inside , the sound was quite loud . The 1/0 positive cable is a nightmare to wire . Doesnt fit down the side along the doors . Its too thick .
    Working on the amp and crossover board tonight . Its a tight fit
    All rugged up and ready to mount
    Out of all the installation requirements to make this system function , I found it most difficult to get the RCA wires up to the dash . This was by far the most difficult part .
  10. Sep 16, 2015 at 12:54 PM
    #50
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    We need more updates. Is this thing totally done yet?
  11. Sep 16, 2015 at 3:29 PM
    #51
    Babs
    Babs Well-Known Member
    Asheville NC
    TRD V6 6spd
    Scratches preinstalled from original owner
    Looks like good progress. Yeah for wire runs, make it easy on yourself and just pull it all. Seats, carpet, all of it. It's just plain easier.
  12. Sep 16, 2015 at 5:36 PM
    #52
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    i think he may also get the R62 mids for the rear.... Thats gonna be one damn nice SQ setup thats for sure
  13. Nov 15, 2015 at 4:13 PM
    #53
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    i do love your setup
  14. Feb 26, 2016 at 2:22 PM
    #54
    6uam671_tacoma
    6uam671_tacoma Well-Known Member
    SOCAL (LA/OC)
    08 SW TRD OR & 13 SSM TRD OR
    (08)12-15 Front-end conversion w/TRD Pro grill, Icon UCAs, 5100s w/OME 885, 1.5” Headstrong AAL, SCS Matte Black Ray10s mounted with Nitto 265/75/16 Ridge Grapplers (13) Ironman 4X4 UCAs, Bilstein 6112/5160, Headstrong AAL, SCS Matte Black w/Blaze Bronze lip Ray10s mounted with Nitto 285/70/17 Ridge Grapplers
    Subscribing
  15. Feb 26, 2016 at 5:27 PM
    #55
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Hey buddy, how are things. I usually check in now and then but havent for a while! pm me some updateS :)
  16. Nov 11, 2020 at 5:26 PM
    #56
    Jessel
    Jessel Well-Known Member
    Jesse
    Manitoba, Canada
    13’ Super White TRD Sport
    Im a little late to the party here. I just did all the doors on my truck. Did doing the back of the cab make a big difference
  17. Dec 22, 2020 at 7:46 AM
    #57
    Big Red 10
    Big Red 10 Member
    VA
    TRD Off Road
    THANK YOU for taking the time to post it for the rest of us! Lots of work to do that. Could you verify that indeed the BT controls you had to purchase and install DID control an aftermarket HU (I bought Pioneer DMH-1500NEX)?? I have a non JBL 2010 with left side steering controls, like you do.
    I got on the horn with Crutchfield and purchased the Axxes ASWC-1 this morning to control the existing radio buttons on the left, and then I asked him if it would enable a new BT switch I want to buy and install, he said twice when I questioned him that there's nothing that will get the BT controls to work with the HU. Is it the specific HU that makes it work or did he not know (he has 13 yrs experience). I really really appreciate if you can take a minute to clarify anything before I pull the trigger on the new switch control and install it.
    #57
    GRNT4R likes this.
  18. Dec 22, 2020 at 12:53 PM
    #58
    gearcruncher
    If your pioneer came with Bluetooth , your left and right side steering wheel controls will all work providing you purchase the ASWC . If you want to watch movies , you will need the parking brake bypass .
    You will also have to figure out a good place for your michrophone .
    Been running this set up for 5 years now . Everything works good
  19. May 18, 2021 at 12:47 PM
    #59
    CROM123
    CROM123 Love my Tacoma
    Garland
    Virginia
    2010 Tacoma 4x4 2.7 reg.cab. 27-k miles
    265/75/16 coopers at3 4s
    That is one helluva badass system !!!
