Dome light help...
Discussion in 'Lighting' started by ETaco23, Nov 13, 2009.
  1. Nov 15, 2009 at 4:51 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    the OEM bulb works fine, It was just a little loose, thats why it was flicking.
    What else could I try? I took apart the map lights too and everything seemed fine, all connections good.
  2. Nov 15, 2009 at 8:00 PM
    ETaco23
    Evan
    PNW
    Alright! I found out my problem but dont know how to fix it or address it. My LED light only works when my key is either on or in acc.
    I think it has something to do with how much power less power it needs so it thinks that its burnt out and only comes on with half the light. Or something like that. :)
    Well any thaughts on this one?
    Thanks again guys!
  3. Nov 15, 2009 at 8:02 PM
    ETaco23
    Evan
    PNW
    Or maybe something having to do with the timer on the dome? :(
  4. Nov 15, 2009 at 8:21 PM
    ETaco23
    Evan
    PNW
    Nobody???:(
  5. Nov 15, 2009 at 8:41 PM
    jefferson
    jefferson needs to stop cruising Buy/Sell/Trade....
    Sex Panther
    San Diego (North Park!), CA
    05 PreRunner SR5
    toyota brand hitch and uhaul wiring harness, fog lamps on anytime, bed lamps, map lights on with dome, day time running lamps, remove secondary air filter, painted bumper grill, Double Din touch screen stereo, Sockmonkey custom SR5 decal, door & seatbelt bells disabled, painted engine cover, installed compass/temperature overhead console, failed mod: passenger side auto down window switches, weathertech front mats, RedLine hood struts, Cheap Beep piezo buzzer locking beep, 5100s in the front set at 2.5, 5100s in the rear, AAL, hitch safe, revenge fab sliders, bed bar, prerunner light, cb wired
    sorry dude - i think its a power delivery issue. Go back to incandescent.. i like how incandesent lamps fill better than LED anyway. LED is designed for straight forward light, whereas incandescent is a messy lamp and shoots light in all directions, making for more of a "filling" light...
    so.. no big loss. Just hope you kept that receipt ;)
  6. Nov 15, 2009 at 8:59 PM
    ETaco23
    Evan
    PNW
    ok... well I found a thread at TTORA about this and the guy found out a way to bypass the dimmer and run a full 12 volts to the dome. But I dont think Im up for doing that. :) I will put the old bulb back in it.
    But I did order a couple LED bulbs for the map lights to see if that works. I hope so.
  7. Nov 18, 2009 at 8:58 PM
    ETaco23
    Evan
    PNW
    Update.....
    No luck! I know someone at TTORA that is ganna try something to fix this issue, and I hope it works. I wouldnt mined going back to the old bulbs, but after seeing the LED's, I really love them and would like to make them work.
    So time will tell.... thanks!
