Dome light LED bulb that actually works right.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Taco me elmo, Feb 3, 2012.
  1. Feb 4, 2012 at 9:39 AM
    Taco me elmo
    Taco me elmo [OP] Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    They work fantastic, I had them installed since last week and no issues.
  2. Feb 4, 2012 at 11:13 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Lights, CB, Switches, skids, LED's... OH MY!
  3. Feb 4, 2012 at 11:18 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
  4. Feb 4, 2012 at 11:20 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i thought i found a solution to this over on ttora a while ago
  5. Feb 4, 2012 at 11:20 AM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
  6. Feb 4, 2012 at 3:52 PM
    TacoMX
    Jonathan
    Deltona, Florida
  7. Feb 4, 2012 at 4:15 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    sounds good i bought a pair. i'll let you guys know if it works when i get them
  8. Feb 4, 2012 at 9:29 PM
    csjumper2003
    csjumper2003 Jumper's Leds Vendor
    Savannah, GA
    2014 SSM Trd Off Road 4x4 Auto
    I've been researching this issue why some like dougs are working fine and some post 00s are having issues. I found that the dimmer feeds off of resistance that the factory bulb uses thus controling the amount of power sent to the bulb to turn it on. Dougs doesn't have this and his pop on right away and dont dim. The key is to add resistance to the led as the factory has. I'm going to try out my new theory when I hook back up with taco elmo.
    Thanks
  9. Feb 4, 2012 at 10:21 PM
    dud122
    Dan
    Riverdale Park, MD
    2004 Tacoma DC
    awesome... i guess the lights i got coming from ebay will be useless as well
  10. Feb 5, 2012 at 7:06 AM
    01Yota
    01Yota Well-Known Member
    Jonathan
    Kentucky
    2003 toyota tacoma 4x4 Little monster truck
    I went to my local advance auto parts store here in kentucky and I got a led square that will fit many different dome lights with a connector type deal and its works flawlessly with the truck on of off when the doors open and by the switch and its really bright. And the brand was Dome Litz (ps sorry for no periods I'm texting and driving)
  11. Feb 5, 2012 at 7:52 AM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
  12. Feb 5, 2012 at 8:07 AM
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
  13. Feb 7, 2012 at 6:43 PM
    otoball
    otoball New Member
    Jacob
    Pensacola
    I have a 2003 Taco and here is how I fixed the LED light issue. I had a problem with my dome light not coming on with an LED in it. I had to turn the key to the "ACC" position or turn one of the dome lights on to get the dome light to work (WEIRD STUFF). Here is the fix:
    1- buy x4 1w 100olm resistors
    2- solder x1 resistor to each of the map light bulbs.
    3- solder x2 resistors to your dome light bulb (you cold probably buy a bigger resistor but this is what worked for me).
    This fix allows you to have LEDs in your TACO. Hopefully this helps. Pics to follow soon.
    NOTE: When putting LEDs in the are polarized so they only work in one direction. You may have to switch them around to get them to work.
  14. Feb 7, 2012 at 8:30 PM
    Taco Man in HD
    Taco Man in HD DC TRD MallRunner
    Ohio
    2004 DC Tacoma PreRunner
    Methods, Red Labels, and other bro stuff.
  15. Feb 8, 2012 at 6:26 AM
    #35
    otoball
    otoball New Member
    Jacob
    Pensacola
    1- buy x4 1w 100olm resistors (Radio Shack)
    3- solder x2 resistors to your dome light bulb (you cold probably buy a bigger resistor and reduce it down to one, but this is what worked for me).
  16. Feb 8, 2012 at 8:48 AM
    #36
    TIPICOTACO
    Tyler
    nw nj
    anxious for pics.. hope this works for me too sounds easy enough..
  17. Feb 14, 2012 at 5:52 PM
    #37
    Ohbrian
    Ohbrian Taco Roja
    Brian
    Fremont, CA
    04 PreRunner
    Eclipse head unit,scratched paint,ripped seat, black chaos 6 rims, Bilstein 5100's, top plate spacers, AAL, Midget antenna, Bakflip G2 cover, 14" Magnaflow, 400W inverter, LR UCA's
    I did this tonight but I used a single 1W 100ohm resistor on the dome and it works like a champ.
  18. Feb 14, 2012 at 6:06 PM
    #38
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    do u hook that resistor in directly with the hot wire or what?
  19. Feb 14, 2012 at 6:10 PM
    #39
    tacoman355
    tacoman355 WORD!?!
    Tyler
    Hampton,VA
    03 Reg Cab Taco
    sold....
    yeah itll take a month but its worth it, lol
  20. Feb 14, 2012 at 6:18 PM
    #40
    Ohbrian
    Ohbrian Taco Roja
    Brian
    Fremont, CA
    04 PreRunner
    I soldered it directly accross the connectors on the bulb, so basically from one end to the other. You can see it works first just by taking a full lenth resistor without clipping the wires and jumper it accross the led bulb while its still in the socket. Just connect one end of the bulb to the other.
