Dome Light Mod / Map Light Mod.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DeeKay21, Feb 11, 2009.
  1. Sep 20, 2012 at 2:15 PM
    #41
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    :thumbup:
  2. Dec 5, 2012 at 4:29 PM
    #42
    CLynch
    CLynch Well-Known Member
    Charlie
    Upstate New York
    None
    Sheppymach,
    Thanks for the tip. Question, how did you connect to map lights? Solder?
  3. Oct 14, 2013 at 9:34 PM
    #43
    benzo
    benzo Member
    2012 White DCLB
    Will the map light work in a single cab and just replace the existing light?
  4. Aug 1, 2014 at 9:54 AM
    #44
    MikeBaucom
    MikeBaucom New Member
    Michael
    Ga
    2011 DC Prerunner SR5
    Added TRD hood. Paint matched headlight mod. Anytime fog light. Map lights to dome.
    Well to everyone doing this mod. I had leds in my map lights. Did everything by the book and it still didn't work. Turns out by swapping the wire locations of the map light connector you are changing polarity of the whole circuit there. So mine wasn't working until I remembered leds only work in one direction. Flipped my leds around from the way they were and bingo. Worked. Just fyi.
  5. Aug 1, 2014 at 9:58 AM
    #45
    pruchai
    pruchai KAMA3
    San Diego, CA
    ‘07 Saab 9-7x 4.2i (it identifies as a Tacoma)
    Not enough...
    I just installed LED lights for Map/Dome/License plate/Reverse. They are all polarity dependent.
  6. Jul 3, 2015 at 3:49 PM
    #46
    Firetazz02
    Firetazz02 New Member
    2013 Tacoma double cab sr5
    I did this mod today on a 2013 Tacoma Db cab. It took me longer to get the truck apart than it did wire the lights. Here is how I did it.
    At the dome light I put a small machine screw through the hole on the silver side
    With a red ring terminal and a nut and washer on the back side of the machine screw.
    At the map lights I switched the wires at the white connection and bent the third unused terminal up and use a red insulated female terminal crimped down to fit snug and tight on the bent terminal.
    Easy mod with great results. Map lights still work independent of the dome light .
  7. Jul 3, 2015 at 4:37 PM
    #47
    Zollars
    Zollars Well-Known Member
    Eagle River, AK
    2009 TRD Sport 4x4
    Suspension: 5100 Billstein Front Shocks Rear AAL 3" lift Engine Bay/Engine: Under-Hood LED lighting Hood QuickLift Elite Hood Struts - Redline Tuning Exterior Additions/Mods: Front Steel Skid plate Front Bumper Light Bar - NFab Bed Cap System: Steal Bedside and Tailgate Caps - KBVoodoo Fabrications 2x US Flag Vinyl Decals Under Mirrors - Far North By Design Exterior Lighting/Electrical: Retrofit Headlights - Ambiguous Fog Light Relay Mod (Fogs On With High Beams) - Thanks To Ostrichsak Depo Taillights 50" 4D Curved Trac Performance LED Light Bar - SLX Motorsports 4x Spot Fog Lights on NFab bar Full Exterior LED Bulb Swap - CSJumper LEDs Interior Additions/mods: CVRV Mirror Riser - BirdDawg Industries Pioneer 8100NEX Head unit Interior 6 Switch Panel - IggyCorp Interior Lighting/Electrical: Backlit 4x4 Switch Mod - RCBS204 Otrattw Switches On IggyCorp Panel For Accessories Dome Light on With Open Door Mod
    Did this one a couple months ago, I cab get a few pictures if anyone needs.
    On the dome light, I drilled out one of the little rivets holding one of the metal bulb brackets down, and ran a bolt through, and attached the wire onto the screw before the nut
  8. Feb 25, 2016 at 8:19 PM
    #48
    Robman
    Robman Well-Known Member
    Rob
    Hawaii
    '14 Tacoma Double Cab
    Reviving an old thread here. Did everything exactly as others and it works as described. Independent map light operation etc.. However, there is now way to turn off the map lights when leaving a door open. Ya know, like when your doing a wiring project (ironic).
    Options? I could put a switch on the jumper wire. Swap for LEDs, so I don't have to worry about heat or battery drain. Reverse the mod. Any other ideas?
  9. Feb 26, 2016 at 3:49 AM
    #49
    NeedmoreTaco
    NeedmoreTaco Garage full of white Toys...
    Eric
    Travelers Rest, SC
    2012 Super White DCSB Prerunner
    LEDs and stuff
    Swap to LEDs AND conceal a switch in the sunglass holder to turn them off when needed. :thumbsup:
