Dome lIght questions
Discussion in '1st Gen. Tacomas (1995-2004)' started by bliggity, Aug 16, 2021.
  1. Aug 16, 2021 at 6:23 PM
    bliggity
    bliggity [OP] Active Member
    2022 Lunar Rock Tacoma TRD Off Road
    I was recently gifted a great little 2003 Tacoma. I'm going through lighting updates now. I don't know about any modifications made before I was given it.
    Can anybody confirm if the dome light should turn on when the door opens? I confirmed my dome light switch is set to door, however, the dome light only turns on with the door open if a key is in the ignition. Seems like it should open when I unlock and open the door. Needing to put a key in the ignition kind of defeats the purpose. I tested all of the doors and get the same results. Very unlikely that it is a door switch causing the issue in my opinion.
    The dome light works when set to on. And like I mentioned before. The door mode seems to work when there is a key in the ignition. Door mode only doesn't work when there isn't a key in the ignition.
  2. Aug 16, 2021 at 6:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Looks like a problem with the Body ECU if I'm reading the pinout correctly, it should ground pin 9 on connector 1H anytime a door is open thus turning on the light.
    Any aftermarket alarm systems installed?, that could be a factor as well.
    Also look for signs of water intrusion.
  3. Aug 16, 2021 at 7:36 PM
    bliggity
    I just figured out a major clue. I took out the LED upgrade bulb and put the regular old incandescent bulb back in. It started working as expected. Something is up with using LEDs on that switch. I do remember reading in another thread about needing a resistor in order to use LED bulbs in the dome. I didn't pay much attention to it since nobody else seemed to be saying that, but I think he may have been onto something. Can anybody verify that? I've never installed a resistor. Is it difficult?
    ekul310 likes this.
  4. Aug 16, 2021 at 7:53 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Interesting I have LED dome and map lights in my 2nd gen and it's happy, I wonder what's different I would think the body ECU on a 1st gen wouldn't be "smart" enough to notice the different resistance of an LED.
    It's not difficult to install a resistor just get the correct one and be careful where you put it because they can get quite hot.
  5. Aug 16, 2021 at 8:02 PM
    bliggity
    Some people had to install resistors for their map lights too. In my case I think I only need the dome.
    100 ohm 3 watt resistors seem to be what people are using in this thread. Will that cause more heat than the incandescent bulb that was in earlier?
    https://www.tacomaworld.com/threads/led-dome-light-issue.585539/
    ekul310 and davidstacoma like this.
  6. Aug 16, 2021 at 8:12 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It shouldn't, it would be dissipating around 140 mA or 2 watts of current at 14 volts so you should be good as long as it's not touching anything that could melt or burn.
    Found another thread here but they were using 1 watt resistors, I think I'd use a 3 watt to be safe.
  7. Aug 16, 2021 at 8:16 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    There needs to be some resistance in the dome bulb to trick the integration circuitry function properly. Basically, you just solder a resistor to each end of the LED bulb.
    ekul310 likes this.
  8. Aug 16, 2021 at 8:22 PM
    bliggity
    Thank you both for your advice. I appreciate it.
  9. Aug 16, 2021 at 10:16 PM
    Akkording
    Akkording Well-Known Member
    Pete
    Houston
    03 +300k Still Truckin, 2012 4Runner
    Welcome to TW
  10. Aug 20, 2021 at 10:19 AM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
