Dome Light Timer??
Discussion in '1st Gen. Tacomas (1995-2004)' started by CutnShootTaco, Sep 3, 2007.
  1. Sep 3, 2007 at 6:30 PM
    CutnShootTaco
    CutnShootTaco [OP] Member
    2004 Tacoma Texas Edition
    My dome light is out. Bulb is good. No power up there. Thinking it may be the auto timer. Anyone know where this is???
    Thanks
  2. Sep 3, 2007 at 8:20 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    There's an auto time on those things? First I've heard of that.
  3. Sep 3, 2007 at 8:26 PM
    coreyredken
    coreyredken Well-Known Member
    North Georgia, Mount Airy
    07 Prerunner SR5
    Westin Stainless Steel Oval Side Bars!
    If you notice that when you close the doors the light stays on in the cab for about 10 sec. or so and then slowly dims until turns off.. so I would say it had a timer on it of some sort..
  4. Sep 3, 2007 at 9:38 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    Hmmm, don't have that sort of thing on my '99. I guess they had them on the '01+.
  5. Sep 4, 2007 at 6:19 AM
    CutnShootTaco
    Exactly what I have. This is a 2004.
  6. Jan 30, 2009 at 5:11 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    It might be the switch
  7. Jan 30, 2009 at 6:26 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I wouldn't call it a timer either...
    My dome light did some weird stuff a while back. It'd go on when I turned a corner....weird... so I'm wondering if its related somehow. ??
    I'll keep watching this thread for updates.
  8. Jan 30, 2009 at 7:21 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    check the fuse.
  9. Jan 30, 2009 at 7:44 PM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    x2 if its completely not working and you say the bulb is good, first thing to check is fuse
  10. Jan 30, 2009 at 8:21 PM
    jps76
    jps76 Member
    pemberton, bc, canada
    02 trd xtra cab
    3" revtek lift, 33" bfgs, piaa fog lights, more to come...
    i had the same thing happen on my 02 and it ended up being corrosion in the switch on the light, a little sand paper on the contacts and it works great now. hope that helps
  11. Jan 31, 2009 at 10:49 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    The interior light wiring diagrams for all years from 2001 through 2004 are identical.
    However, the 2002 owners manual is the last one that says the lights simply 'go off' after 15 seconds with all doors closed and the dome light in the 'DOOR' position.
    The 2003 and 2004 owners manuals clearly state the light 'fades out' in this condition.
    In any case - there's no separate 'timer' component in the circuit. My best guess would be that they added an 'auto-dim-to-off' circuit / whatever in the Body ECU unit effective with the 2003 model year.
  12. Jan 31, 2009 at 11:01 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    hmmm... only 1.5 years old. :thumbsup:
