Dome lights won't turn off!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jadoiron, Nov 22, 2015.
  1. Jul 9, 2019 at 8:21 AM
    #141
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    What bulbs are you guys using that is causing this to happen? People should know what to avoid....
    I know several 3rd gen owners who have made the switch (including myself) to LED bulbs for the interior from Superbrightleds and have 0 issues for 1+ year now.
  2. Jul 9, 2019 at 9:24 AM
    #142
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    FFS I just cancelled my LED order from Amazon. I don’t need a bunch of electrical issues on a new truck.
  3. Jul 9, 2019 at 10:02 AM
    #143
    COdude3
    COdude3 Well-Known Member
    Colorado
    2017 SR5 Access Cab 4x4
    Pro Grille, Pro Whls, King Shocks, 265/75R16 A/T3
    Completely stock bulbs.
  4. Jul 9, 2019 at 10:42 AM
    #144
    godzilla888
    godzilla888 Just a plain white T
    Paradise
    2017 Super White SR5 DCSB AT
    Possibly the third brake light leaking?
    Any light stains/discoloration in the rear of the headliner?
  5. Jul 9, 2019 at 12:43 PM
    #145
    COdude3
    Colorado
    That was my first thought. I checked and found nothing. My next plan is to run water on each suspect spot (third brake light, fin, door jams), eliminating each until I find the culprit.
  6. Jul 12, 2019 at 10:13 AM
    #146
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Exactly, led stands for light emmitting diode. A diode allows current to flow in one direction so they only work in one orientation. Some fancier ones have crossover circuits that allow either orientation while still allowing current to only flow the correct way through the led(s). It is still possible to have a short in a lamp assembly but even then if a fuse blows and a problem crops up elsewhere the problem is bad engineering since the fuse is proven inadequate to isolate a surge.
    Winch likes this.
  7. Jul 12, 2019 at 10:33 AM
    #147
    Winch
    2019 TRD OR MT V6
    None yet
    This is why I cancelled this upgrade.
  8. Aug 10, 2019 at 2:18 PM
    #148
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  9. Aug 14, 2019 at 7:16 PM
    #149
    ckmason14
    ckmason14 Member
    Chad
    2017 Inferno Toyota Tacoma SR5
    Tube steps, mud guards, access Lorado tonneau cover
    I'm in the same boat here. Lights stay on. Truck is under warranty. I put the stock bulbs back in. Going to take it to dealership next week. What did you "tell them" how the problem started occurring? Thanks!
  10. Aug 14, 2019 at 10:39 PM
    #150
    Dryfly24
    Dryfly24 He’s a leprechaun. He tells me to burn things.
    George
    NM
    2020 Jeep Gladaitor - Formerly 2019 Tacoma OR SB
    I just installed LED’s in mine and ran into the same problem. The map lights are designed so that you can push the lenses to turn them on and off. Sometimes when installing the LED’s you accidentally push the switch to the on position. The switch is located in the recess near where the bulbs go. It’s a little black protrusion in a hole. All you have to do is push on it again with the tip of a pen or pencil or something to reset it back to the off position. People are way overthinking this.
    The problem I’m having with mine is that the LED’s don’t fit the brass base designed for the halogen bulbs very well. I can only get one side to stay on very long because it doesn’t make a solid contact.
    Led’s are and bright and nice to have if you can get them to work correctly. But they are a pain in the ass if they don’t.
  11. Sep 15, 2019 at 4:40 AM
    #151
    COdude3
    Colorado
    So I finally got around to problem solving my issue. To recap: When it would rain, my dome light would stay on, and after everything would dry out, the light would go off.
    Because I was busy, I removed the dome light fuse. It remained removed for a about a month. This weekend I replaced the fuse and ran water all over the exterior - 3rd brake light, fin, doors, windows...everywhere. I could not get the dome light to come on, everything was working normal. I would love some help/thoughts? My warranty is up next month.
  12. Sep 16, 2019 at 10:32 PM
    #152
    bagleboy
    Scott
    Norcal, Santa Rosa
    Wait 5 weeks and it'll come back. :anonymous: It may take a little time for enough moisture to get in and cause the problem to reoccur. Maybe try the drive through carwash?
  13. Sep 17, 2019 at 5:01 AM
    #153
    COdude3
    Colorado
    Good idea, I’ll try a spray wash today.
  14. Sep 17, 2019 at 9:43 AM
    #154
    ckmason14
    ckmason14 Member
    Chad
    Has anyone had this fixed "under warranty"? And if so, what did you tell the dealership? I'm taking my Tacoma in next Wednesday and having the problem fixed (I hope). I put the stock bulbs back in. Don't know what to tell the dealership how the "problem" started so it will still be covered under warranty. Thanks!
  15. Dec 23, 2019 at 10:20 PM
    #155
    Sleevez
    Sleevez Well-Known Member
    LA / Toronto
    2017 SW TRDPro, 2000 PinkTaco
    Slightly different issue, but just a couple of weeks ago, I tried to turn off traction control, and notice it was turning on my dome and map lights. Also with the atrac and diff lock. At first I recall atrac indicator would come on but after turn off the truck and none of the traction control buttons would show anything on the dash but it would turn on my dome and map.lights. not sure what's going on. It was raining and snowing while I first noticed it.
    Is there a fuse I could I check? Also I have LEDs replaced and the meso puddle lights installed, I tried disconnecting the meso puddles.but didnt fix the issue. Might need to revert all the mods and take her in :(
  16. Dec 24, 2019 at 6:35 AM
    #156
    COdude3
    Colorado
    When my dome light would not turn off after raining, I pulled the dome light fuse. After a month, I replaced the fuse and was going to work on solving the problem but everything works fine now. For the life of me, I can’t get the dome light to stay on. I have power washed every inch to try to replicate a hard rain, but no luck. By pulling the fuse, I must have reset something. Try pulling the fuse and leaving it out for a day.
    Sleevez likes this.
  17. Dec 30, 2019 at 4:02 PM
    #157
    Sleevez
    LA / Toronto
    looks like it's a short in the overhead console circuit board. luckily Ext warranty is covering it. or it would have been a $350 fix. still not 100% sure what caused the short. as all the LED bulbs are still working.
    shane100700 likes this.
  18. Mar 21, 2020 at 12:16 PM
    #158
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    Have you tried pressing the light? They can switch on and off individually that way.
  19. Mar 21, 2020 at 12:31 PM
    #159
    wcoffman
    wcoffman Well-Known Member
    '18 TRD Sport DCLB 4x4 SuperWhite
    Fr pass door handle replace, Tyger step rails and soft bed cover, DDSS3 fogs, TRD skid, OR front tow hook, SokieTech hood struts, fr seat covers (neoprene), metal oil filter housing, magnetic oil plug, Cyclone under hood lights, Blue Sea Systems 5025 Fuse Block ST Blade 6 Circuit with Ground and Cover, Blue Sea Systems 60A DC Panel Mount circuit breaker.
    Thanks Dilbert. I’m embarrassed to admit that solved the problem. Dryfly in post 169 reminded me about the lenses being able to control each light. I knew that, having used that feature many times. However, it slipped my mind. I went to delete my post but you were too quick. Appreciate your responding!
    Canufixit and dilbert like this.
  20. Mar 22, 2020 at 6:53 AM
    #160
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    also, the overhead console has a switch, dome lights on, on when doors open, or off. i bump it sometimes, when i hit the garage door opener function on the auto mirror. Ski
