DomeRock Module for Courtesy Rock Lights V4 by DSIM Solutions
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by DSIM, Apr 24, 2018.
  1. Jun 3, 2020 at 8:28 AM
    #961
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    Thanks BRANDON!!! I'll have to check it out and compare it with what I have at the house when I get home from work.
    CttAznRanger[QUOTED] likes this.
  2. Jun 3, 2020 at 2:14 PM
    #962
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    This looks good to me but now I’m wondering if this is redundant/ over kill / not right.
    I spoke with resident electrical expert @caribe makaira and this is what he said
    “No DSIM.
    SPDT (Single Pole Double Throw) switch, like MESO's puddle lamp switch.
    Battery (hot) - fuse - pin 30 & 86 of relay.
    Relay pin 87 to BD Rock Lamps.
    Relay pin 85 to MESO's puddle switch - center pin
    Top (or bottom pin) of switch to Cargo Lamp harness, purple wire.
    Remaining pin, to ground.
    Select head Unit to Unlock on approach. You'll have to read the owner'smanual...I can't remember the steps to get to the correct page on that.”
    Edit: more information——“This module is handy to intercept the dimming of the cab illumination but it has a limit of 3 amps. Any added lamps need to be 3 amps or less. If the added lamps are more than 3 amps then the yellow wire would go to an added relay (pin 85 coil negative) so the relay can handle higher amps. If using a relay due to higher amps to handle, the added lamps only go ON or OFF...no dimming effect.” - @caribe makaira
    @caribe makaira maybe you could weigh in on @CttAznRanger setup / diagram and we could set this straight once and for all.
  3. Jun 3, 2020 at 2:28 PM
    #963
    DSRamsey13
    Thanks, @SubaruTheTacoma for sharing. And thanks @caribe makaira for your wealth of knowledge.
    Now... just to make sure I understand this. When you say, "This module," you mean the DSIM? And does the calculation of the 3A need to take into consideration the current draw of the Puddle Pods and Dome Lights? Or just whatever the DSIM is pushing?
    Thanks, again, for everyone's contributions. :)
  4. Jun 3, 2020 at 2:44 PM
    #964
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    Hmm, maybe I'm not as good in electrical as I thought I was. I have never hooked up the 86 pin of a relay to the battery, so I can't answer to that. I also don't plan on tapping into the cargo lamp wiring, so I am not sure what difference it will make in the schematic. Can you educate me on that @caribe makaira ?
    Pretty sure the 3A is for the DSIM module directly.
    DSRamsey13[QUOTED] likes this.
  5. Jun 3, 2020 at 2:46 PM
    #965
    DSRamsey13
    Cool, thanks!
  6. Jun 3, 2020 at 5:11 PM
    #966
    caribe makaira
    Caribbean, Puerto Rico
  7. Jun 3, 2020 at 5:51 PM
    #967
    CttAznRanger
    Brandon
    Boston, MA
    Oooh, ground side switch. Yeah that makes sense. I've always put my switch as the positive trigger.
    Makes sense about also not necessarily needing DSIM module. Just tap into MESO switch wiring directly with a relay.
    Since I already have the DSIM module, I might as well use it.
    Thanks for sharing the knowledge. Much appreciated.
    fatboyfirebass likes this.
  8. Jun 3, 2020 at 5:55 PM
    #968
    caribe makaira
    If you like relay "chatter" go ahead and tap into the MESO switch wiring directly...
  9. Jun 3, 2020 at 7:34 PM
    #969
    CttAznRanger
    Brandon
    Boston, MA
    Would that happen because of the dimming feature?
  10. Jun 3, 2020 at 7:55 PM
    #970
    caribe makaira
    yes
  11. Jun 4, 2020 at 7:04 AM
    #971
    DSRamsey13
    Just realized the bundle I purchased through DSIM isn't for the MESO Puddle Pods w/ MESO Puddle Pods Switch. The bundle came with a 3-way splitter. This is good if you do not plan to use the MESO Puddle Pods Switch. This also means you do not have to use MESO's two way splitter (#2 in MESO's drawing) since the 3-way splitter takes its place.
    What I need (and folks who have the MESO Puddle Pods and MESO Puddle Pods Switch) is the 2-way splitter which DSIM also sells here. That way I can use the DSIM with its own switch AND the MESO Puddle Pods with the MESO Puddle Pods Switch. For complete, independent control.
    I emailed Daniel (@DSIM) and asked if I could exchange it.
    MESO Splitter (#2)
    DSIM 3-way Splitter
    DSIM 2-way Splitter
    CttAznRanger likes this.
  12. Jun 11, 2020 at 10:15 AM
    #972
    DSRamsey13
    Quick update: Daniel sent me, free of charge, the 2-way connector. Awesome customer service.
    He also stated that the 3-way COULD work, but it would give the MESO Switch some control over his DSIM module. (The double splitter in mesos kit gets replaced with this 3 way. The switch kit gets hooked on straight at the harness. Then the 3 way split then the meso puddles and domerock follows.)
    For my application, I want autonomous control from each other so I will be utilizing the 2-way splitter.
    Thanks, again, Daniel (@DSIM)!
    DSIM[OP], Shayne and CttAznRanger like this.
  13. Jun 15, 2020 at 10:20 AM
    #973
    ExploreBackcountry
    ExploreBackcountry Oak & Iron Studios
    2019 MGM Tacoma TRD Off-Road
    Order DSIM#1243 - to run the UpTop Alpha Rack scenePods
  14. Jun 15, 2020 at 10:29 AM
    #974
    DSIM
    DSIM [OP] Well-Known Member
    Daniel
    Raleigh, NC
    2017 MGM Tacoma TRD Off-Road
    Confirmed. Should be in the blue bin this afternoon.
    Only one left in current batch. Looks like I am going to have to make some more!
  15. Jun 21, 2020 at 7:55 PM
    #975
    TacomaThursday
    TacomaThursday Member
    2019 Cavalry Blue TRD Sport
    Hi All,
    New to wiring - do these connections I just drew up make sense? My objective is like many of you - to have my rock lights come on with the push of the CH4x4 switch button AND as I approach the vehicle.
  16. Jun 22, 2020 at 5:54 AM
    #976
    DSRamsey13
    Look at Post #2. You need to use a relay.
  17. Jun 22, 2020 at 7:33 AM
    #977
    TacomaThursday
    Actually, I have a relay I just bolted to the driver's side under my hood. Just forgot to add it in to the sketch.
  18. Jun 22, 2020 at 8:00 AM
    #978
    DSRamsey13
    Then to answer your original question, "do these connections I drew up make sense?" ... the answer would have to be, "No."
    The BLACK and RED from the DSIM goes to the A-Pillar. The YELLOW from the DSIM goes to RED1.
    The GREEN from the switch would go to your RELAY (30).
    Not sure of the other wires you have coming from your battery. You would have to insert your relay for us to make sense of your drawing.
  19. Jun 22, 2020 at 8:16 AM
    #979
    CttAznRanger
    Brandon
    Boston, MA
    I don't think it will work.
    When you approach the truck, the yellow DSIM wire would give output, so it should go to a relay to turn on your rock lights. If you send it to the CH4x4 switch, it would only work if the switch was on and you were approaching the car. If you are inside the car, switching the CH4x4 on won't do anything, as the DSIM module is not giving an output.
    Let me know if that makes sense. I can try to make it more clear if you need.
  20. Jun 22, 2020 at 4:46 PM
    #980
    ExploreBackcountry
    for the UpTop Alpha (red) scenePods
    DSIM[OP], DSRamsey13 and CttAznRanger like this.
