DomeRock Module for Courtesy Rock Lights V4 by DSIM Solutions
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by DSIM, Apr 24, 2018.
  1. Jun 25, 2020 at 9:43 AM
    #1001
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    Let us know your findings. I have some diodes laying around i can use and i just had thought about that. Are you having the same thing happen with your dome lights as well? with dsim plugged in DOME lights no longer fade/dim. With it unplugged they Fade/dim normally?
  2. Jun 25, 2020 at 9:45 AM
    #1002
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Yes, just thought it was the price to pay for having puddle lights triggered by the dome circuit. I will test your theory tonight.
  3. Jun 25, 2020 at 3:55 PM
    #1003
    ExploreBackcountry
    ExploreBackcountry Oak & Iron Studios
    2019 MGM Tacoma TRD Off-Road
    Just finished my install- I used a switch after the DSIM module so I can have the rock lights come on or not with the dome. If switch is ON (rocks come on) dome NO fade - switch OFF (no rocks) dome fADES.
    DSIM > switch > relay
  4. Jun 25, 2020 at 4:02 PM
    #1004
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    that's interesting... so your switch only is to make the lights come on when the dome circuit is triggered aka, door unlock, door open, etc. and off makes them not come on at all with the dome circuit? do you also have a second switch wired from the dsim trigger to make them manually come on anytime you want?
    edit: also if above is true then it does seem that yours is behaving just as mine is, except for me its physically unplugging the dsim where your switch is doing that.
    so are there others here that are using the dsim module and your overhead dome lights actually fade on and off?
    it's starting to sound like this is how it's intended to work since so many others experience the same.
  5. Jun 25, 2020 at 4:16 PM
    #1005
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    This is weird. In his install video, it shows the dome lights fading in and out with his rock lights. Check out the 7:40 mark.
    https://youtu.be/q4spJKvuJWE
  6. Jun 25, 2020 at 4:18 PM
    #1006
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    very interesting indeed. It looks like i've counted atleast 4 of us so far where it's not working in that fashion. myself, @ExploreBackcountry , @Puppypunter, and @oostroma.
  7. Jun 25, 2020 at 4:20 PM
    #1007
    DSRamsey13
    Just wished Daniel (@DSIM) would chime in and save us all. :bananadead:
  8. Jun 25, 2020 at 4:22 PM
    #1008
    ExploreBackcountry
    I do have another switch- however it goes to the relay
  9. Jun 25, 2020 at 4:23 PM
    #1009
    oostroma
    oostroma (Boomer)
    Ontario
    There will be a delay in testing the inline diode theory until tomorrow night folks. Forgot truck is dropped off for oil change tomorrow.
  10. Jun 25, 2020 at 4:24 PM
    #1010
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I am planning the 2 switch method you mentioned. I worked up the circuit in post #834. I am hoping to finish up the wiring this weekend. Other projects took precedent until now. It's interesting to hear about fade and non fade scenarios, as I don't actually use the dome light. I mainly planned on using the "courtesy lights" for helping the vehicle stand out at night in a parking lot. The manual "work lights" are for when a weekend project runs into the evening.
  11. Jun 25, 2020 at 4:24 PM
    #1011
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    I almost wonder if it is just as simple as a polarity miss match. Maybe The Red/black wires coming from the a pillar that plug to the DSIM being crossed/switched for some reason... if that's the case it is worth noting that the a pillar tap wire i'm using was provided in my meso puddle pod kit and not from dsim. maybe it's switched on the meso tap? i'll have to try and play with it soon as i get some time.
    here’s a quick video of my lights you can see right at :18 where the dome turns off instantly and not fade, same thing right at :58 seconds with the rear cargo lamp. https://youtu.be/Dx1Yzkas-co
  12. Jun 25, 2020 at 4:29 PM
    #1012
    ExploreBackcountry
    Switch in the bed turns on camp lights and triggers the scenePods in Alpha rack.
    DSIM (switch ON) triggers scenePods in Alpha rack.
    I just disconnected the “dash light” feed to the switch (to rule that out) same behavior on effect.
  13. Jun 25, 2020 at 4:31 PM
    #1013
    DSRamsey13
    Thought about that too, but I think you'd blow some fuses if that were the case, but not 100% sure. I also found out that there are some jumpers on his board that you can switch, but that's only how the module behaves when it's triggered (ON or OFF).
  14. Jun 25, 2020 at 4:33 PM
    #1014
    DSRamsey13
    I see that your Puddle Pods fade in & out, but yeah... your dome is like it's set on a light switch (ON/OFF).
  15. Jun 25, 2020 at 4:34 PM
    #1015
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    yea! thats from the ozdium dimmer. I love it!
  16. Jun 25, 2020 at 4:36 PM
    #1016
    DSRamsey13
    Oh... it doesn't come that way from MESO?
  17. Jun 25, 2020 at 4:38 PM
    #1017
    oostroma
    oostroma (Boomer)
    Ontario
    Ok, so you are getting the fade effect with the added dimmer. My puddle pods are connected directly to the DSIM harness "+" feed and I am getting instant On and Off with them and interior dome light.
  18. Jun 25, 2020 at 4:38 PM
    #1018
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    if you wire your lights into the circuit without using the dsim, they can fade on/off i believe. but if using the dsim, the trigger is just an on/off.
    It's confusing, but you got it!
    DSRamsey13[QUOTED] likes this.
  19. Jun 25, 2020 at 6:55 PM
    #1019
    ExploreBackcountry
    I confirmed with DSIM before I installed that the module has a diode - So I only added a diode from my bed control panel to the relay.
  20. Jun 25, 2020 at 7:26 PM
    #1020
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Here is my experience with the module when I tested it in the truck (not on the bench). I plugged the module straight into the A-pillar tap. No other loads on it except for the stock dome lights. When the module was plugged in, the dome lights would fade on and off very quickly (almost like there was no fade at all). Unplugging the module restored normal fade (about +/-1.5 seconds from on to off). So the oznium wasn't causing any issues, as it wasn't in the circuit at all. The DSIM module was outputting a positive signal, just like it is supposed to do. I was kicking around the idea of trying a diode as well. I've also wondered if a resistor would do any good? The module itself is a relay, two diodes, and a capacitor, so maybe a relay would slow down the discharge rate? This might not work though since the capacitor is regulating the voltage, basically eliminating the "modulation" in PWM so the relay doesn't flicker. I'll have to play with it some and see what it does...
    Also, I didn't see how the cargo light acted since I have a topper and mine is always turned off. So I'll check that too. My current revision of my wiring plan went back to no DSIM module as the lights I am using have very low draw, but I still have the module (and the oznium dimmer) to play with. Meso is sending me a few splitters that I will be using to make a custom harness for footwell/puddle/light bar lights, so I'll have the A-pillar opened up again soon.
