DomeRock Module for Courtesy Rock Lights V4 by DSIM Solutions
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by DSIM, Apr 24, 2018.
  1. Apr 29, 2023 at 8:12 AM
    #1121
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I haven’t swapped around to cargo yet but my 9100 is currently triggered through my domerock. Just because I thought it would be cool to own a dome rock as I bought near the end of availability. I assume the negative trigger should work just fine on a 9100. I’m not sure if the 8xxx series had an ability to take a negative input.
    I’d love to make more progress on that stuff and my 3rd Gen but I’m mostly focused on bumpers to clear out space in the garage.
    I learn a lot from @ktbell444 though. He knows stuff. And @caribe makaira whenever I can get my brain to sync to his rpm’s.
    GuacIsExtra and ktbell444 like this.
  2. Apr 29, 2023 at 8:36 AM
    #1122
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
  3. Apr 29, 2023 at 8:48 AM
    #1123
    daveeasa
    David
    PNW
    What I meant was matched fading to the dome. So, translating the negative PWM fade out to a positive PWM fade out and similar with the fade in. Not as easy to do. The oznium will be close but lag behind a bit both ways.
    caribe makaira likes this.
  4. Apr 30, 2023 at 2:17 PM
    #1124
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Have you guys looked at the vled footwell kit or specifically the module? The kit comes with a harness or pigtail. you could likely run a switch and related for on for Rock light but This works great for the fade. I think it used to work with the DSIM.
    https://www.vleds.com/shop-application/footwell.html if you don’t use the module tie harness at least on 2nd gen faded as expected.
  5. Apr 30, 2023 at 2:30 PM
    #1125
    kmorgan3
    kmorgan3 Redside Electric, LLC | VLEDS
    Kyle
    PNW
    2020 4Runner SR5 Premium | RAM 1500
    The module isn’t doing the fading on those kits. It’s 100% the wires I tapped with the harness.
  6. Apr 30, 2023 at 5:47 PM
    #1126
    nudavinci64
    Robert
    Yah that’s what I was saying too. I didn’t see the harness for sale separate if someone didn’t want to tap
  7. May 1, 2023 at 11:30 AM
    #1127
    GuacIsExtra
    GuacIsExtra Well-Known Member
    2021 TRD Off-Road 6MT Cement DCSB
    So I wired up my trigger-1 wire to the dome fuse in the driver footwell via an add a fuse and set the SwitchPro to react on an active low signal. Unfortunately it seems like the dome circuit is always hot, even when I've closed the doors and locked the truck. I was under the impression that the dome fuse circuit was a negative switch. Any idea what I fudged up?
  8. May 1, 2023 at 12:35 PM
    #1128
    daveeasa
    David
    PNW
    You need to get the PWM - dome via A pillar tap. The fuse is +12v constant battery (also available in apillar T). You can't get it done with add a fuse as the ECU sends the PWM - signal to fade in/out so you have to get into that lead somehow.
    GuacIsExtra[QUOTED] likes this.
  9. May 1, 2023 at 12:42 PM
    #1129
    GuacIsExtra
    Shame, even DSIM's a-pillar t-harness is OOS. I'll try to fab one up. Thanks for the tip!
  10. May 1, 2023 at 12:43 PM
    #1130
    daveeasa
    David
    PNW
    They are a b, no, actually, they are a B, or more like a B!
    I assume the footwell lighting kit is an easier starting point if you're willing to hack it up?
  11. May 1, 2023 at 12:53 PM
    #1131
    GuacIsExtra
    I had been eyeing that kit, that's not a bad idea. If I'm going to be barbaric and splice into a wire, it may as well not be the OEM harness.
    Say I buy the kit. Which of the downstream wires should I splice the trigger into?
  12. May 1, 2023 at 1:11 PM
    #1132
    daveeasa
    David
    PNW
    Probably best asked in the footwell thread and answered by Kyle. My kit got sent to someone else who filed a coa form on me so I don't even know what they look like (too lazy to buy a 2nd kit). Someday I'll pony up.
  13. May 17, 2023 at 7:24 AM
    #1133
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    I'm late to the party, but suppose you just want to use a simple ON/OFF (SPST) switch instead of CH4X4 switch. I don't have any open switch panels.
    BTW, I have a 2-gen and I'm using the Universal Kit.
  14. May 17, 2023 at 9:40 AM
    #1134
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I would wire it up similar to any other lighting accessory then. The reason the above looks so complicated is because they want to have the lights illuminate when approaching or unlocking the vehicle.
  15. Jun 27, 2023 at 1:58 PM
    #1135
    Dr3w
    Dr3w Well-Known Member
    Drew
    805
    2007 White DCSB Sport
    Anyone used this module with an Auxbeam switch panel? The panel uses solid state relays
  16. Jun 28, 2023 at 3:59 AM
    #1136
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    The initial design was to turn the negative pulse into a positive switched, so should be fine.
    @daveeasa , why buy (the T) when you could simply do the depin and Y the two leads you’d want…
    Unless it’s the module you’d want.
  17. Jun 28, 2023 at 5:45 AM
    #1137
    daveeasa
    David
    PNW
    Which T are we talking about and which leads?
    People tend to be less confident about de-pin and re-pin for the most part so plug and play with leads is generally preferred when cost is reasonable. Often sourcing connectors is a bit of a challenge. For multi-position connectors, care is needed to ensure the pinout remains the same.
  18. Jun 28, 2023 at 6:24 AM
    #1138
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    The pillar “T”. I just meant as personal, not for others.
  19. Jun 28, 2023 at 6:37 AM
    #1139
    daveeasa
    David
    PNW
    I run puddle pods so I source +12v and dome PWM negative from the a-pillar. I did one T crimp on that connector, for switch illumination, and it was a fair bit of work. I’m not the best at crimping small stuff and double crimps on those terminals are extra hard.
    It would be nice to eliminate the A pillar T entirely but that dome wire, whether as a trigger to other dimmers or used directly, is a useful one to grab.
  20. Sep 25, 2023 at 8:58 AM
    #1140
    hokiehunter19
    hokiehunter19 Well-Known Member
    been running these with no issues, but now all eight of my lights won't work.
    Has anyone else run into this problem? Any suggestions?
