Done my research, just want confirmation
Discussion in 'Wheels & Tires' started by 1GR, Mar 11, 2012.
  1. Mar 11, 2012 at 5:56 PM
    1GR
    1GR [OP] Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Ok, so I know how annoying all of the "will this fit" threads can be over and over, so I decided to play it smart. Before posting I did all the research, and by research, I mean browsed this forum for a couple hours.
    After seeing these "wheelers" mentioned over and over again, and having recognized them from seeing them in person on a taco, I knew these were the rims for me. I have a 2010 trd sport, double cab, so I know I need the 16x8's. Now my questions is for tires. I found some t/a ko's in a 285/75r16 for a good price. Which equals a tire just under 33x11.5. On the wheelers website, they have type a for up to 11.5" tires, with a 4.5" bs. And type b for 12.5" tires, 4" bs. Now these tires being just under 11.5" should fit fine with type a, but type b should give it a wider stance, which is a look I am looking for.
    Are there any disadvantages or maybe advantages by doing this (other then laws or VI's). And will this require a body mount cut, or just the regular fender trim, mudflap removal?
    Thanks for being patient and for the help in advance.
    - S
    Edit: Forgot to mention 3/1" lift/leveling kit. No that it matters for my question, I just know someone will ask.
  2. Mar 11, 2012 at 9:42 PM
    1GR
    Scott
    BC, Canada
    I am not concerned with rubbing on the inner fender liner, that can be trimmed. Just concerned with stance and rubbing on body mount, uca.
  3. Mar 11, 2012 at 11:48 PM
    1GR
    Scott
    BC, Canada
    After looking through your thread, it seems like quite a hassle for that size. Don't want to do the body mount mod. Wonder if 265/75R16 with a 4" bs would be more appropriate. Remember fender and mudflap trim/removal are fine. Also keep in mind offloading in this truck won't have a lot of extreme flexing. Any input?
  4. Mar 12, 2012 at 1:40 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    255/85/16 (the other 33"s) BFG KM2s on 1st Gen TRD ORs with 4.5" BS. No trimming and still running mudflaps.
  5. Mar 13, 2012 at 6:56 PM
    rossivey
    rossivey Well-Known Member
    North Texas
    06 Black DCLB 4x4
    the cab mount chop is nothing. a little work with a dremel tool and a grinder. BAMF makes some cab mount chop plates you can weld on to give it a more factory look after you chop it. Took me about an hour to do mine. i just left mine open though.
  6. Mar 13, 2012 at 7:14 PM
    1GR
    Scott
    BC, Canada
    Thanks. Best info so far. 285/75R16's it is.
  7. Mar 13, 2012 at 7:21 PM
    rossivey
    North Texas
    06 Black DCLB 4x4
    no problem. i debated about the cab mount chop until i found some decent info and then decided to go with it. Mine comes close to rubbing on the passenger side but not close enough to do the chop. i trimmed up the fenders with just the dremel tool. be sure to use a fairly tough cut off wheel or you'll just brake a bunch of them. i spray painted the cab mount black after i chopped it, by the way.
  8. Mar 13, 2012 at 7:40 PM
    1GR
    Scott
    BC, Canada
    Don't worry. I have all of the proper professional tools. ::D
