DONE with HIDS!
Discussion in 'Lighting' started by MMazz365, Jun 8, 2012.
  1. Jun 8, 2012 at 8:30 PM
    MMazz365
    MMazz365 [OP] Well-Known Member
    Michael
    NY
    TRD Off Road
    -flowmaster dual side exit exhaust -3 inch lift -cb radio -scanner -DTRL's -Fogs Anytime -Truxedo Soft Tonnahu Cover -eyelids -grillcraft upper and lower -fogs behind the grill
    :mad: Well after about a year and a half I starting getting lots of problems and the fixing began. Finally tonight, I gave up.. Stock head lights back in. Does anyone know just bulbs that are very good and bright like HIDS?
  2. Jun 8, 2012 at 9:16 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Cheap hids are ok as long as you use a relay harness to power them directly from the battery, otherwise the ballasts burn out. Spend the $10 and get the harness. You can make one yourself, but you will wish you spent the $10 instead.
  3. Jun 8, 2012 at 11:02 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I ran PIAA Intense White bulbs for about 3 years, and was very happy with whiteness, brightness, and reliability. (They're available for $44/pr from Amazon.) Note that while the Intense Whites have a blue appearance when off, the light they throw is WHITE (not even the slightest hint of blue). When one burned out last month, I replaced both with a set of Osram Rallye 70/65W bulbs from Candlepower for about $40. So far, they seem like a nice upgrade.
    I've also heard good things about Philips X-treme Power bulbs, which are available for $30/pr from Amazon, OSRAM Night-Breakers, available through Amazon for $34/pr, and Sylvania SilverStar zXe bulbs, available through Amazon for $60/pr.
  4. Jun 9, 2012 at 10:50 AM
    MMazz365
    Michael
    NY
    TRD Off Road
    Wow thanks for the info I'm definitely going to look into those
  5. Jun 9, 2012 at 10:52 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I'll never use cheap HIDs again. I understand your frustration as cheap HIDs do suck... OEM quality or nothing for me.
  6. Jun 9, 2012 at 11:02 AM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    Toyota also uses HIR bulbs but not sure what the status on manufacturing is. You can find HIR for the tacoma but from not ever having used them I do not how they compare to stock. The process adds on more layers of reflective coating on the bulb, providing 75% same brightness to HID bulbs. I have used Piaa extreme white bulbs, very very bright compared to stock, but did burn out a kinda fast in my opinion. HIR would be the way to go, like I said that's most likely what the new toyota bulbs are.
  7. Jun 9, 2012 at 11:06 AM
    05sctaco
    Ken
    Santa Cruz
    You really need a projector with HID's for the correct beam diffusion. Our stock head light spreads the light into to many directions and does not focus it to where the road is. I've installed a few cheap hid kits on no HID cars and by far the best is with a projector, look factory and very clean. :cool:
  8. Jun 9, 2012 at 11:06 AM
    stowayman
    stowayman Well-Known Member
    Gary
    Monterey, CA
    08 DC 4X4 TRD O/R - Debadged
    Kenwood DNX9980HD Nav - BT - Sirius - backup camera, Weathertech digifits, maglite mod, 14" billet antenna
    I'm running Sylvania Silver stars in the headlights and fog lights... pretty happy with em
  9. Jun 9, 2012 at 11:17 AM
    meeestirg
    meeestirg Well-Known Member
    Vance County, NC
    HID bulbs are only supposed to last about 1-2 years. the ballasts only about double that. they die quicker if you are constantly turning them on and off (flashing your lights at people who cut you off or are driving too slow in front of you) HID's should be allowed to fully warm up before you turn them off again.
  10. Jun 28, 2012 at 6:35 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    ive had OEM PNP hids (D2S bulb w/ an H4 shield), retro'd TLs, the phillips xtreme vision, and NAPA bulbs....
    best one yet...$7 bulbs from NAPA! no joke. they are 85w/100w bulbs. i purchased some H4 ceramic connectors, ran a relay and some 16 gauge wiring and let those things loose! amazing results, and very reliable. let me know if you want anymore info.
  11. Jun 28, 2012 at 6:38 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    I use osram night brakers
  12. Jun 29, 2012 at 1:35 AM
    05sctaco
    Ken
    Santa Cruz
    Got my fiance philips extreme 80+ way brighter than stock nissan bulbs. I'd run the 80/100w only with a relay. But i have pnp hid bixenons and they work pretty good. Very bright, had to install new bulbs and the new ones are way brighter then the old ones.
