Don't forget to clean your MAF
Discussion in '2nd Gen. Tacomas (2005-2015)' started by powdr_dayz, Feb 9, 2012.
  1. Feb 9, 2012 at 11:45 AM
    powdr_dayz
    powdr_dayz [OP] Active Member
    Colton
    Montana
    2010 Tacoma TRD Off Road
    I installed a TRD CAI back in November and saw an immediate and significant drop in my gas mileage from ~20mpg to ~15mpg. I thought that it may take some time to calibrate the new intake and that this might have been the cause of the poor fuel efficiency. But tank after tank, it never seemed to improve. After doing some research, I kept coming across the direct correlation of poor efficiency and a dirty MAF. Sooo, on tuesday I removed the MAF and came to the realization that it was completely covered in an oily soot (possibly the result of an overly oiled CAI filter). I sprayed some electronics cleaner on the sensor, left the battery unplugged for about 30 minutes, and connected everything back up. Since doing this, I've noticed a huuuuuge improvement in my gas mileage and think I may even be back to the pre-intake levels.
    If you've noticed poor fuel efficiency, and haven't changed your driving habits, I highly recommend checking and cleaning the sensor. Just a thought...
  2. Feb 9, 2012 at 12:00 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Yep, plently of us do it. There's a few write up's on how to do it. I typicalled make it part of my oil change process. Clean it every change.
    Thanks for the heads up, :wave:
  3. Feb 9, 2012 at 12:27 PM
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    Seems no matter what I do I always get 18 mpg. Cleaned maf, throttle body, changed ALL lubes, new plugs, new filter. Before and after have always made no difference, got the truck with 40 k and its always been the same now at 60 k
  4. Feb 9, 2012 at 2:22 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    That's the EPA average so you must be doing something right.
  5. Feb 9, 2012 at 2:25 PM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    A thread on cleaning the MAF ... :confused:
  6. Feb 9, 2012 at 2:39 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  7. Feb 9, 2012 at 5:24 PM
    SOSHeloPilot
    2024 4Runner SR5
  8. Feb 13, 2012 at 8:36 AM
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    Saw this thread and realized I have never cleaned this. I have always run stock filters, have 86k, and get 20-23mpg regularly. Cleaned throttle body at 78k and way pretty clean.
    Just wanted some opinions before I do this, is it worth doing? I am a if it ain't broke don't fix it kinda guy:eek:
  9. Feb 13, 2012 at 11:16 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Have you changed the diff oil? If not it might be sludgy and that'll suck mpgs from you.
