Door lock for passenger door?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Logically Insane, Mar 10, 2010.
  1. Mar 10, 2010 at 9:36 PM
    Logically Insane
    Logically Insane [OP] Well-Known Member
    Wes
    TN --- USA
    2010 PreRunner Access Cab
    Kobalt toolbox mounted with J-Hooks, Locks on storage compartments in bed, Window Visors, Toolbox LED Lights, Underbody Lights, More to come.
    OK, is it possible for me to get a keyed entry lock for my passenger door?
    I get turned around a lot, and my passenger door always seems to be locked, and I have to walk all the way around to get my keys out of the ignition lol..
    Just kind of wondering what I would have to do, Dealership I suppose?
  2. Mar 11, 2010 at 2:02 PM
    Agent475
    Agent475 "Mark It Zero"
    Waldorf, MD
    2006 Red TRD Sport
    Hood Struts, 3" Tuff Country Lift, Shortie Antenna, WeatherTechs, Tinted front windows, custom TRD seat covers, custom pedals, debadged, custom USMC badging, quasi-functional hoodscoop (i.e. I cut it open), black front Yota emblem, Tailgate Theft-Prevention mod, Horn Relocation mod, Old Man Emu Carrier Bearing Drop, Brighter Backup Lights Mod, Smittybilt Reciever Hitch Tow Point, currently working on Satoshi Grill Mod
  3. Mar 11, 2010 at 6:04 PM
    Logically Insane
    Wes
    TN --- USA
    That'd be nice, but no I'm actually talking about the lock that you can put your key into..
    But I want it for the passenger door.
  4. Mar 11, 2010 at 6:06 PM
    DeathBound
    DeathBound Well-Known Member
    Jay
    Mississippi Gulf Coast
    2010 Tacoma SR5 4X4
    Never seen it, I have keyless entry. For me it's the best way to go.
  5. Mar 11, 2010 at 6:08 PM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    keyless entry. hit your key fob twice and it'll unlock the other side
  6. Mar 11, 2010 at 6:11 PM
    Logically Insane
    Wes
    TN --- USA
    Ok so heres the deal, occasionally I leave my remote in the truck with the key.
    But I keep the valet key on a separate chain in my other pocket. When Im on the passenger side its a drag to walk all the way around.. So they don't make 'em for the passenger side? :(
  7. Mar 11, 2010 at 6:17 PM
    TacoSupreem
    Hayden
    Kentucky
    hmm never even noticed that there wasnt a key hole on the pass. side?
  8. Mar 11, 2010 at 6:23 PM
    DeathBound
    Jay
    2010 Tacoma SR5 4X4
    I have a key hole on the front passenger side. Thought you were talking about rear doors.
    Edit: I don't have one. That sucks.
  9. Feb 2, 2011 at 6:23 PM
    endoman
    endoman Member
    Carrollton, Texas
    PreRunner SR5
    Logically Insane,
    Did you find a solution to your lock issue? I am also needing a keyed door lock for the front passenger door. My 2010 does not have an outside lock that I can stick a key in and unlock it. I don't carry the remote. Too much bulk in my pocket.
  10. Feb 2, 2011 at 6:35 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    My 08 has no power locks and has cylinders on both sides. Must be an option. Look at a dealer parts site for one.
  11. Feb 2, 2011 at 7:09 PM
    OmegaMan
    OmegaMan Well-Known Member
    The Woodlands Tx
    2010 DC TRD Offroad
    Front window tint, Silver Star headlights and Fogs. Katzkin Leather Interior, Heated seats, UnderCover bed cover, JVC DVD HD radio + NAV
    I don't see why you can't get another drivers side handle and turn it upside down. You would need to swap the pieces around but it should probably work.
    I would be fairly certain that the door handles is a global part and they have to have something for the RH Drive trucks.
    1st step is to pull the door apart and look at the guts, but it should work with not much effort.
  12. Feb 2, 2011 at 7:11 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Drivers side has a lever that operates a rod which locks and unlocks the striker lock. It would turn the wrong way if it could be installed on the passenger side.
  13. Feb 2, 2011 at 8:50 PM
    joes06tacoma
    Joe
    Central Coast, CA
    My 06 has power locks and a keyhole on the passenger door. I doubt there has been much changed between the two years. I would make friends with the dealer parts guys and get them to pull up the diagrams for an earlier truck and then your truck and see what parts are different between the two. Order those parts and install. Ask if they can key the lock for you with your keycode that came with your keys. Otherwise, might have to find a local locksmith to change it.
    If you follow through with it, post up please. I am curious now.
  14. Feb 2, 2011 at 9:08 PM
    OmegaMan
    The Woodlands Tx
    2010 DC TRD Offroad
    This is why I said to flip the tail piece on the back of the lock. The rod should be the same on both sides (drivers door should work on passenger side).
  15. Feb 3, 2011 at 4:49 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Be easier and cheaper to keep the passenger windows down.:D
  16. Feb 3, 2011 at 5:20 AM
    endoman
    endoman Member
    Carrollton, Texas
    PreRunner SR5
    I have seen some Tacomas with the passenger outside door lock, so the parts should be available for my 2010. I will attempt to find the parts list from Toyota. Hopefuly, the parts are low cost.:rolleyes:
  17. Feb 3, 2011 at 6:06 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Look up a dealer website, most use the same online parts exploded view program.
