Door Lock/Unlock Beep "How to turn beep off"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grassflatsfisher, Nov 9, 2009.
  1. Nov 9, 2009 at 7:41 PM
    grassflatsfisher
    grassflatsfisher [OP] Well-Known Member
    NW Florida
    09 Tacoma TRD OffRoad DC
    Grille Guard, Husky Liners, More to come...only got 800miles on it.
    Is there any way to turn OFF the beep and double beep when you lock and unlock your doors?
    I got a 2009 if that makes a difference.
    Thanks ahead of time for the help!
  2. Nov 9, 2009 at 7:43 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    Yes you can turn it off. I did it to mine. Do a search on here and you will find instructions.
    Good luck!
    :cheers:
  3. Nov 9, 2009 at 7:46 PM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    This will make it quieter:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/46824-quieting-lock-unlock-beep.html
    or Step one: Open the drivers door and insert the key into the ignition
    step two: Remove the key from the ignition and, within 5 seconds,
    reinsert the key back into the ignition and switch to the on position.
    Step three: After 10 seconds, the system enters the answer-back mode
    step four: Within 10 of the answer-back beep the switching mode is
    started, press the remote twice and teh system will turn off
    or on based upon which the system is set.
    Elite777 and StreetTiresJay like this.
  4. Nov 9, 2009 at 7:46 PM
    grassflatsfisher
    NW Florida
    Tell me what to search... I've tried beep, key fob, turn off, etc... Haven't seen anything on it.
    Thanks!
  5. Nov 9, 2009 at 7:46 PM
    Taco-NB
    New Brunswick
  6. Nov 9, 2009 at 7:50 PM
    sandman427
    sandman427 KR FAB
    Amir
    WAY THE HELL OUT THERE, So Cal
    BAMF TACO!!
    2 ten inch kicker cvt subs, pioneer deck and alpine 1000 watt class D amp, and flowmaster exhaust, 4 inch camburg lift spindles and my coilover is adjusted to 1" (5inch total) in front and 3" All Pro leafs, KING off road racing reservoir shocks and coil-overs, KR FAB CUSTOM BUMPER with three 9" HELLA 4000 Race LIGHTS , HID headlights with rigid amber LEDs , "KR Fabrication" custom built bumper, sliders and tiregate, Full size spare with matching rim, custom bed bar with two amber off road lights, cb radio, also BHLM (thanks Ray), and debagged
    i was actuall woundering the same thing thanks... what about the automatic lock after 15 sec..??? is there a way to shut that off too..??
  7. Nov 9, 2009 at 7:52 PM
    deeznutz
    deeznutz Well-Known Member
    Seattle, WA
    09 SR5 DC LB 4x4
    Search function:
    Originally Posted by jmed99 [​IMG]
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    HINT: The driver side door is closed.
    http://www.tacomaworld.com/forum/2n...-stop-beeps-when-i-lock-unlock-my-taco-4.html
  8. Nov 9, 2009 at 7:54 PM
    grassflatsfisher
    NW Florida
    Awesome! Thanks for the quick replies... As soon as IDA gets done dumping 10" of rain on me I'm going to do it.
    I'd like to know about the 15 sec auto lock as well.
  9. Jan 22, 2010 at 10:38 AM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    Do you think this will work if i have an after market alarm on it. Mine HONKS once to lock, and twice to unlock, and I feel like it wakes up everyone in my street when I go anywhere at night.
  10. Mar 30, 2011 at 10:46 AM
    Eurosport
    Eurosport Well-Known Member
    around the world
    thanks for the directions,
    confirmed to work on 2011 :thumbsup:
  11. Mar 30, 2011 at 1:30 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    You probably have the same alarm that came in mine (mine died). It was a "Pursuit" by Audiovox. The instructions are online (Google it) and tell you how to do it.
    RZ Rob
  12. Mar 30, 2011 at 2:42 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Quicker fix without all the geek work (sorry guys).
    Lift the hood, stand by the battery, hit your lock/unlock and find this:
    Tape over the plug:
    No beep :cool:
  13. Apr 1, 2013 at 11:58 AM
    904man
    904man New Member
    NorCal
    Stock SR5
    New to this forum, love my new Taco! Hated the beep when locking and unlocking the doors!!!!! Your formula works! Thank you very much. FYI, the alarm still sounds (steady beep) when you try to lock the doors and one of the doors is still open. I like that.
    Best and Thanks!
    904man
  14. Jul 11, 2015 at 11:58 AM
    octico
    octico New Member
    If it's the KARR system you have and you want to disable the horn and only have the beep sound. I just did it on my truck and I am so happy! Below are the steps to do it.
    - key into ignition
    - turn to ON
    - turn back off
    - push little button behind blue alarm light by your leg area 3x
    You will hear 2 soft horn beeps confirming programming.
    Manpants likes this.
  15. Jul 11, 2015 at 8:57 PM
    Manpants
    Manpants Well-Known Member
    San Diego, CA (Santee)
    2012 4x4 TRD Off Road
    Air freshener....
    Was just about to look this up. Sweet.
    octico[QUOTED] likes this.
