Door trigger
Discussion in '1st Gen. Tacomas (1995-2004)' started by rparagas69, Mar 22, 2019.
  1. Mar 22, 2019 at 10:07 PM
    rparagas69
    rparagas69 [OP] New Member
    Ron
    1998 tacoma
    Anyone know where to locate a door trigger wire on 1998 Tacoma standard cab to install car alarm?
  2. Mar 23, 2019 at 2:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I just have to Ask What is a door trigger ?
    Does it control the bed mounted 40MM Grenade Launcher ??
  3. Mar 23, 2019 at 6:35 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I think he is asking about the courtesy lamp switch. I've never owned a std cab, but looked at a few pics on Rancho Toyota site and saw this door pic. Looks like the switch peeking out from the front, lower area.
  4. Mar 23, 2019 at 8:31 AM
    rparagas69
    Ron
    1998 tacoma
    Sorry for misunderstanding I meant door trigger wire to hook up the car alarm?
    Running Board Man likes this.
  5. Mar 23, 2019 at 9:26 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    When that switch closes it completes the circuit to ground
    I have no idea if that works for the alarm wired the correct way it would work depending what your dealing with alarm wise
  6. Mar 23, 2019 at 10:00 AM
    BartMaster1234
    BartMaster1234 American Auto Horns
    Tyler
    San Francisco, California
    Flux Capacitor
    Trigger wire for what? Are you looking for a circuit that tells you if the door is opened or closed?
    There are two circuits you can use, and they are both ground switched. There is a door lock actuator sensor on power door equipped trucks to tell the Integration Module and/or stock RS3000 alarm system that a door is open. Or you can use the circuit that connects to the courtesy lights, should also be ground switched.
  7. Mar 23, 2019 at 10:42 AM
    rparagas69
    Ron
    1998 tacoma
    I’am looking for a negative door trigger wire when you open the door it’s negative and when closed you get 12v circuit that would trigger the aftermarket car alarm I will install
  8. Mar 24, 2019 at 12:53 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Then your going to need a to buy a switch that works how you want and install it
  9. Mar 25, 2019 at 7:23 AM
    Glamisman
    Glamisman Well-Known Member
    every alarm I have removed from a Tacoma has been hooked into the wiring under the panel by your left foot or left knee. I dont know if a 98 has a Body ECU or not... I dont have a wiring manual for that year... 96, and 2000 and up yes. Maybe some else here can upload the door lock portion of the diagram.
  10. Mar 25, 2019 at 7:43 AM
    rparagas69
    Ron
    1998 tacoma
    Thank you so much glamisman,hope someone here have the door lock portion diagram
  11. Mar 25, 2019 at 8:02 AM
    Glamisman
    when I removed the alarm from my 98 I didnt check to see if the door lock portion was grounding or powering the wire... sorry. I just got tired of the locks auto locking as I drove off and having to push a button to unlock as I get out.
