Doors Lock Automatically - How Do I Disable?
Discussion in '1st Gen. Tacomas (1995-2004)' started by uncleelihu, Oct 18, 2009.
  1. May 5, 2017 at 11:21 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    old thread revival....
    I have a 2000 Tundra with the VIP RS3000 System. I followed the instructions on page 20 of the manual and it worked just fine! I even started the engine and the doors did not lock. Working just fine. If you can't find you manual, here is the procedure:
    1) Sit in the driver's seat with the driver door open. 2) Insert the key in the ignition switch, and turn it to "ON" (not ACC) 5 times (ON-LOCK-ON-LOCK-ON-LOCK-ON-LOCK-ON) within a 10 second period. The STATUS MONITOR'S LED turns on, and the piezo "Chirper" sounds once.
    YOU MUST PERFORM THE NEXT STEPS WITHIN 30 SECONDS!
    3) Select the operating mode:
    MODE
    Auto lock/unlock ON
    Programming step: Close the driver's door
    Programming Completion:Turn the ignition switch to the "LOCK" position (the chirper sounds once and exterior lights flash once)
    Auto lock/unlock OFF
    Programming step: Close the driver's door, then open, and close it one more time.
    Programming Completion: Turn the ignition switch to the "LOCK" position (the chirper sounds twice and exterior lights flash twice)
    dthisner likes this.
  2. May 5, 2017 at 1:41 PM
    wilcam47
    Will
    Bourbon state
    I finally got the annoying auto lock to disable! Took a few tries but it worked!
  3. May 5, 2017 at 4:54 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    I don't know if it worked. I did this and started the truck, put it in gear and the doors didn't lock. I'll see if it worked later as nothing beeped.
    wilcam47 likes this.
  4. May 6, 2017 at 8:23 AM
    wilcam47
    Will
    Bourbon state
    If it didnt lock when you turn the ignition on it should be gtg...mine didnt chirp either then as I was turning it off I heard it chirp, I didnt notice the lights since I was concentrating on the dash.
  5. May 6, 2017 at 11:32 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    It didn't work. I can't program a fob and I can't seem to do anything with this alarm. I'm real close to taking the grounds off this POS and living without it.
  6. May 7, 2017 at 8:07 AM
    wilcam47
    Will
    Bourbon state
    I couldnt get the fob to work but I got the locks to disengage. Did it beep when you had the door open and cycled the key 5 times? after that I closed the door then opened then closed then went to acc IIRC. then it beeped
  7. May 7, 2017 at 12:14 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Does not chirp when any of that is done. Sigh.
  8. May 7, 2017 at 2:54 PM
    wilcam47
    Will
    Bourbon state
    Mine didnt at first but dont go all the way to start, keep the door open and cycle it. Maybe you have an aftermarket system.
  9. May 7, 2017 at 2:58 PM
    wilcam47
    Will
    Bourbon state
    heres a closer version to what mine did, Does yours have a LED security light?
    5) Step in the vehicle and make sure that all doors are closed completely
    6) Insert the key into the ignition key cylinder.
    7) Wait for more than 5 seconds.
    8) After turning the key to the ACC position, turn the key from the ACC to the
    ON position 5 times within 10 seconds (Last position : ON).
    ➨ Status Monitor LED will illuminate for 30 seconds.
    Note : In case you implement 6 times or more by mistake,
    action steps 6)-8) you made will be canceled.
    Please retry from step 6).
    9) While the LED is illuminated :
    • Open and close the driver’s door 2 times.
    • Turn the key to the ACC position.
    ➨ LED will continue illuminating.
    ➨ Indicator lights will flash 2 times.
    Ignition controlled door lock ON :
    10) While the LED is illuminated:
    • Open and close the driver’s door 1 time.
    • Turn the key ACC-ON-ACC 1 time (Last position : ACC).
    ➨ Indicator lights will flash 1 time.
    ➨ LED will extinguish.
    Ignition controlled door lock OFF :
    10) While the LED is illuminated :
  10. May 8, 2017 at 10:26 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    No LED. Mine has the RS3000. Verified by the code on the black box. It has a red pushable light in the lower left bottom dash. It never lights up unless it is screwing with me, like not letting me start it when the battery is disconnected. I'm just going to disconnect the damned thing.
  11. May 8, 2017 at 1:36 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    Here's something weird. I took off the grounds, taped them up and started the truck and everything works. So I go to lock the doors after getting out with the door switch and the horn beeped. Just like my wifes Rav4 used to do with or without the remote. Did it actually start working after I disconnected it?
  12. May 9, 2017 at 9:12 AM
    wilcam47
    Will
    Bourbon state
    Heres what I found for your RS3000
    http://www.parksoffroad.com/tacomamods/alarminfo/alarminfo.htm
    The factory setting for the automatic door locking and unlocking function is on.
    1: Sit in the drivers seat with the drivers door open.
    2: Insert the key into the ignition switch and turn it to on (not acc) 5 times (on-lock, on-lock, on-lock, on-lock, on) within a 10 second period. The status monitors LED turns on, and the piezo chirper sounds once.
    ***You must perform the next steps within 30 seconds***Select the operating mode:
    Automatic door locking and unlocking on: Close the drivers door. Turn the ignition switch to the lock position. The piezo chirper sounds once, and the exterior lights flash once.
    Automatic door locking and unlocking off: Close the drivers door once, then open and close it one more time. Turn the ignition switch to the lock position. The piezo chirper sounds twice, and the exterior lights flash twice.
    If you do not turn the ignition key to lock, or exceed 30 seconds during the programming steps, the status monitor's LED will turn off and the previous operation mode will remain.
  13. May 9, 2017 at 7:02 PM
    scheide
    scheide Well-Known Member
    nebraska
    84 toyota
    4.88 gears, marlin crawler, 4" lift,lockers front and rear,33x10.5 swampers, header, u-bolt flip kit,relocated shocks in rear,walker muffler, pinion e-brake conversion,9000 ramsey winch.
    Ok, I have a 99 with out a key fob. Just use a key to lock, unlock mine. Anyway I can disconnect the doors that automatically lock when I start the engine?
  14. May 11, 2017 at 9:11 AM
    wilcam47
    Will
    Bourbon state
    Try the steps I posted in post #32 it should work, Im not saying it will but at least try it. It worked on my 2000 Tacoma.
  15. May 11, 2017 at 7:07 PM
    #35
    scheide
    nebraska
    84 toyota
    thank you. I will give it a try.
  16. May 13, 2017 at 10:37 AM
    #36
    wilcam47
    Will
    Bourbon state
    did you get it to work?
  17. May 13, 2017 at 12:01 PM
    #37
    scheide
    nebraska
    84 toyota
    Maybe tomorrow. Too many graduations to go to today.
  18. May 14, 2017 at 2:59 PM
    #38
    scheide
    nebraska
    84 toyota
    it worked perfect. Although I had to try it twice due to not following the instructions carefully. Thanks a bunch...
  19. May 14, 2017 at 9:09 PM
    #39
    wilcam47
    Will
    Bourbon state
    I was relieved to get the auto lock disabled...it was so really annoying when you had to shut off the vehicle or use the power lock switch to unlock. It was about 1/2 second too slow for opening the door too. Annoyed passengers even more. I know it seems petty but its nice to get in or out when you wanted without shutting it off or hitting the locks.
  20. Aug 19, 2022 at 2:13 PM
    #40
    dthisner
    dthisner Member
    2006 Blue Tacoma SR5 (Kitti)
    it worked for me as well. Thank you :D
