double cab back bucket seats?
Discussion in '1st Gen. Tacomas (1995-2004)' started by lonzorizo, Sep 19, 2011.
  1. Sep 19, 2011 at 2:38 PM
    lonzorizo
    lonzorizo [OP] Well-Known Member
    Lonnie
    Hoopa, Ca
    2003 TRD OR, 2016 TRD OR Tacoma
    Does anybody know if the front seats of a 01-04 Tacoma will work in the back of a double cab in place of the bench seat? Thinking of doing this to build a sub box in the back.
  2. Sep 19, 2011 at 2:51 PM
    topgun155
    topgun155 Well-Known Member
    Zack
    Richmond, TX or College Station, TX
    08 Prerunner V6 Black
    Viper Alarm, In Pro Car Wear L.E.D. Tail Lights, Fog Lights, ScanGuageII, AvidOffroad Light Bar, Ammo Box Mod, Tailgate Theft Prevention Mod, Satoshi Grill, Hella 500ff behind the grill, blendmount, Cruise Control Mod, Fog Light Mod, 5100's @1.75, Toytec TSB AAL 1.5".
    I'm sure it can be done, but theres gonna be a lot of work in it. Not sure about the head room though sitting in the back I always hit my head already and it seems like buckets would lift you up even more.
    Also something to think about. At least in the second gen the back window is small and with the head rests on you have very little window to see out. With those big bucket seat you will be luck to see out at all.
  3. Sep 19, 2011 at 3:30 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    ^^^+1
    The front bucket seats sit much taller than the rears.
    I built a custom box for a low profile 10" sub. I took out the rear upholstery liner, and cut it out to maximize the depth of my box. So basically, the box touches bare metal in the back of the cab. As a result, the seat won't fold down (driver side). The box I built ended up with about 1.25 Cu Ft. which was about the minimum for the speaker specs. Even then, I had to clearance the back of the box so the magnet would fit. It's a tight fit for sure, but less work than getting buckets to fit...
    I'll try to post some pictures tonight...
