double cab custom sub box pics
Discussion in '1st Gen. Tacomas (1995-2004)' started by ratboy85, Feb 18, 2012.
  1. Feb 18, 2012 at 11:40 PM
    ratboy85
    ratboy85 [OP] Well-Known Member
    i have searched and no luck.
    im looking for pictures of people that have made custom boxes for the double cabs. im looking into making a rear seat center console type sub box for a jl 13w7. i posted here cause we all have first gens and figured i would get better responses here
    any help is appreciated but looking for pics or box designs with cu ft.
  2. Feb 19, 2012 at 6:48 AM
    Adam Baum
    Adam Baum Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    13" sub? I know it is your truck, but why? Those are not air space friend subs at all.
  3. Feb 19, 2012 at 6:03 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
  4. Feb 19, 2012 at 6:06 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Get a shallow JL W5. Sick sub.
  5. Feb 20, 2012 at 7:47 AM
    ratboy85
    @ Adam - after ding some math and some measurements I actually think I will have enough room to produce 2 cu ft which is a good match for a sealed encloser for the 13w7
    @ Phuket - I'm not looking to fit anything behind the seat as I'm looking for a lot more bass than I could ever produce out of 2 eights with minimal airspace. Supercrew sound does have a pretty slick box though. Now if I decide to Put anything behind the seats it's actually gonna go into the bed of the truck and be ported thru the rear wall of the cab, but I highly doubt I will go that direction because off all the other things you need as in a tonneau cover, loss of the small bed we already have ha. And I work mostly down dirt roads so it just would t work.
    @ Isu- man the 13tw5 is a bad azz sub for only having 2.5" of mounting depth! But I don't think I would ever be ably to fit that behind my seat just too small back there. And since I'm building a box for the rear seat kinda like a center console for the rear seat ( I know hard to explAin and paint a picture for what it's gonna look like) I'm gonna go with a w7 cause I will be able to squeeze the airspace and get the sound out of it.
    I'm just curious if anyone else has built this setup before, which I'm almost positive someone has I can't be the only one that wants a large amount of bass
  6. Feb 20, 2012 at 7:50 AM
    ratboy85
    Phuket- that link you sent is pretty cool I've never seen a box for a 10! I wonder if when ordering that box could have them make the box wider as in the full width of the rear seat for more airspace? Run all the Amos under the front seats
  7. Feb 20, 2012 at 9:54 AM
    cadman33619
    cadman33619 Well-Known Member
    i'm looking for something like that also.... something that will sit on the back seat in the center position (and can be anchored down somehow). kinda like a center console or arm rest that can be removed with little effort in case i need the seating. something with maybe two 8" subs mounted to the sides facing outward so that an amp can be mounted directly on top (since there is limited room in teh cab for an amp). i have no idea how the air movement/space thing works. guess i need to learn a little first. something that is all in one unit that can be removed when i need to. been thinking about this for a while. did a few sketches and dimensions but i've never built a sub box before.
    please post if you find a solution. i'll keep looking into it as well.
  8. Feb 20, 2012 at 2:15 PM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I have been trying to sketch up a box similar to what you're looking for. It would double as an arm rest for the back seat. It would look something like this horrible design I'm attempting below....
    ____
    / __|
    |_|
    Sub would be on the angled portion, facing forward. Planning on a 10'' Pioneer Champion Series because they run in extremely small enclosures. I just need to find a way to anchor it down and find a spot for the amp, as I'd rather not have it mounted to the box itself.
  9. Feb 20, 2012 at 8:19 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
  10. Feb 20, 2012 at 8:24 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
  11. Feb 20, 2012 at 8:29 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    I'm working on something like this. It'll be a while before it gets finished and maybe even started but I'll be updating the thread as I go.
    http://www.tacomaworld.com/forum/audio-video/198719-bass-head-idea-thinking-out-loud.html
    I was going to ling this also.
  12. Feb 21, 2012 at 8:47 AM
    ratboy85
  13. Feb 21, 2012 at 8:53 AM
    ttran
    ttran Expert Mallcrawler
    Tim
    Cary, NC
    06 DCLB Prerunner Sport
    TRD Sport Prerunner
    Subbed to see how this turns out! I may be adding another sub to that box that Phuket linked to you soon :spy:
  14. Feb 21, 2012 at 8:56 AM
    codyadams
    codyadams New Member
    Cody
    Ocala Florida
    04 TRD SR5
    6inch lift,bf all terain 33s, 16x8 Sidebiters, Crunch Audio Amp, Kicker L7 15inch Subwoofer, Pioneer Touch Head Unit
    I gave up my entire back seat for one Kicker l7 15. Best thing i ever did.
  15. Feb 22, 2012 at 6:01 AM
    04trd
    04trd Well-Known Member
    Cleveland Ohio
    2015 f150 lariat
    weather techs, 20precent tint, leveling kit, back flip bed cover, rhino liner
    here is my set up, its two pioneer 7 inch shallow mount subs. Surprisingly for how small they are the give out some pretty good bass
  16. Feb 22, 2012 at 6:04 AM
    04trd
    Cleveland Ohio
    2015 f150 lariat
    also its right behing the back seats so you cant see them, it gives the whole truck a nice clean look with out having a huge sub sitting on the floor or back seat.
  17. May 9, 2017 at 1:50 PM
    aw3sumpossum
    aw3sumpossum Member
    Marcus
    Calgary, Alberta
    2015 6MT Double Cab TRD Tacoma
    16x8 FN 5 Star wheels wrapped with 265/75/16 Duratracs (32's) Bestop soft top Wet Oakle seat covers 30" Rough Country front bumper LED light bar HID's/cleared headlights Debadged One hell of a sound system
    I also thought about a center section sub, but figured that would limit what I can put back there. I ended up going with this and taking out the entire "40" part of the seating.
