Double cab drop
Discussion in '1st Gen. Tacomas (1995-2004)' started by l3aml3oo 01 Taco, Mar 31, 2011.
  1. Mar 31, 2011 at 12:06 AM
    l3aml3oo 01 Taco
    l3aml3oo 01 Taco [OP] Member
    Cody
    Oahu
    01 PreRunner D-Cab
    HID, Spintech Exhaust
    Ok so i have an 01 double cab and i want to do a 3/4 drop on it. i dont wanna bag it and i have spintech exhaust thats dual out and the driver side pipe goes through the leafs so i wanted to know if that was gonna be a problem. Any suggestions or opinions welcome. please
  2. Mar 31, 2011 at 12:38 AM
    l3aml3oo 01 Taco
    Cody
    Oahu
    01 PreRunner D-Cab
    Also was looking around at some other sites and hearing i may have to either replace or swap ball joints for the control arms? And does it matter if its a 6 lug or 5 lug. if it does mines a 6 lug.
  3. Mar 31, 2011 at 5:54 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    So far, all I've found is if you wanna drop a DC your best bet is to do a 5-lug frame swap. If you were to find a way to lower w/o frame swapping, your exhaust would have to be chopped up some, best thing would be to dump at axle. Me and some other guys on here believe that the furthest down a 4x4 could go is ~2.5" and not suffer CV bindings ( kind of like lifting a truck yet inverted). You might be able to do a Spring under axle in the rear or remove leafs for the rear setup. For the front, you could get shorter coils.
    Feel free to read through these links, might be of some help:
    http://www.tacomaworld.com/forum/street-trucks/136911-just-throwing-idea-out-there.html
    http://www.customtacos.com/forum/showthread.php?t=146087
  4. Apr 2, 2011 at 5:21 PM
    l3aml3oo 01 Taco
    Cody
    Oahu
    01 PreRunner D-Cab
    ok so if i do a 2/3 drop i wont have to do a frame swap? imma keep looking around and asking to see if dropping a double cab is even possible. thanks
  5. Apr 2, 2011 at 8:01 PM
    orieo
    orieo Well-Known Member
    Oregon
    03 PreRunner SR5 DoubleCab
    Deck plate mod, magnaflow muffler, 20% front tinted windows, HID Projector retrofit
    Go over to customtacos.com and search. There is a lot more info on lowering over there than here.
  6. Apr 2, 2011 at 8:02 PM
    Gieser
    Gieser Official Flatlander
    MB, Canada
    06 tundra yamaha edition
    scion Head Unit and magnaflow muffler...so far
    he has a prerunner though so he has no cv angle to worry about. right?
  7. Apr 2, 2011 at 8:19 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Correct.
  8. Apr 2, 2011 at 8:33 PM
    carolinaTRD
    carolinaTRD Well-Known Member
    Evan
    Ft. Bragg, NC
    03 double cab TRD debaged
    nothing....yet
    don't drop it you'll just ruin a perfectly good truck
  9. Apr 3, 2011 at 8:02 AM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
  10. Apr 3, 2011 at 8:05 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    I wouldn't frame swap it.if anything just replace the front half of the frame from a 2wd base Tacoma.
  11. Apr 3, 2011 at 9:16 AM
    jblair
    jblair Well-Known Member
    Colorado
    99 taco 2.7L I4
    lift, big boy tires, deck plate, no more sway bar, painted stuff
    ^that
