double din radio, switch panel location....
Discussion in '1st Gen. Tacomas (1995-2004)' started by clayshutr, Sep 29, 2016.
  1. Sep 29, 2016 at 2:11 PM
    clayshutr
    clayshutr [OP] Well-Known Member
    Robby
    Central MO
    02 dc 4x4, 08 T4R v8
    ome 882 billy's dakars 255-80-17 STMAXX SCS F5 some other random doodads
    Just like the title says, Anyone have a double din and use a large switch panel? If so were did you locate it? I was wanting to do a pillar mounted panel beneath the handle, but no one makes one that I have seen. So that leaves me with trying to add it to some existing trim on the dash or along side the console.... Just looking for some ideas. I'm open for about anything. thought about maybe on the roof above the rear view, which would require some skills with fiberglass (which I have none of). Lets hear what you think!
  2. Sep 29, 2016 at 2:29 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Have you seen @paranoid56 switch plates he fabs and sells?
  3. Sep 29, 2016 at 2:32 PM
    FirstGen Jer
    Jeromey
  4. Sep 29, 2016 at 3:33 PM
    clayshutr
    Robby
    Central MO
    I have a double din radio, so it's not possible to use one like that. Ash tray holds the cb, so that's out.
  5. Sep 29, 2016 at 4:00 PM
    FirstGen Jer
    Jeromey
    Ahhh! My bad I misunderstood what you where asking
  6. Sep 29, 2016 at 4:06 PM
    FirstGen Jer
    Jeromey
  7. Sep 29, 2016 at 9:50 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    i believe there is enough room in the roof to use one of those snap in switch holders.
  8. Sep 30, 2016 at 5:49 AM
    clayshutr
    Robby
    Central MO
    Snap in switch holder?
  9. Sep 30, 2016 at 8:47 PM
    paranoid56
    San Diego
    14 double cab taco
    something like this
  10. Oct 1, 2016 at 8:42 AM
    clayshutr
    Robby
    Central MO
    So you think between the headliner and roof panel there is enough room for this to fit and not hit the roof panel? that would be spectacular.
  11. Oct 1, 2016 at 7:28 PM
    paranoid56
    San Diego
    14 double cab taco
    I cant find the pic, but somebody posted a pic of using that bracket in the headliner near the map light.
  12. Oct 1, 2016 at 7:58 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    I like idea of switches in the headliner in terms of space, my issue is I like switches for lights and the locker in the dash so I can hit them quick and they're in my line of sight
    Turning off the lights is a big one, my switches are right by the headlight switch arm so I can turn off my light bar with my brights for oncoming traffic. If that's not a concern the headliner seems ideal
  13. Oct 1, 2016 at 9:01 PM
    paranoid56
    San Diego
    14 double cab taco
    for that, i would would set the switch up on a on off on switch, so you could trigger them with your highbeams or by themselves.
  14. Oct 4, 2016 at 9:09 PM
    Laxtoy
    Maltby, WA
    That would solve it.
    My lightbar is already on an on-off-on switch since it's dual beam amber and white, only other solution is to isolate them each to a switch, but that adds another switch on the dash, space is limited, yaddah yaddah.
    It does suck not having it go off with the high beams, my old light forces were wired that way with the wiring harness, but I also didn't like not being able to run them without the brights on.
    If I add another set of halogens or hids, which I might because the light bar doesn't compare to the light forces for light thrown down the road, I'll put that one on a spdt switch, that's a good idea
