Double wide semi tires
Discussion in 'General Automotive' started by JCBigler, Mar 1, 2013.
  1. Mar 1, 2013 at 3:30 PM
    JCBigler
    JCBigler [OP] Well-Known Member
    Chouteau, OK
    Silver 2010 4WD, SR5, DC, TRD OR w/tow
    stock, Yaesu FT-8800R with a Maldol EX-107B, rear breather mod
    So, recently I have been seeing a fair number of semi trucks with double wide single tires on the back of the rig and on the trailer, as opposed to dualies. What's up with these? Are they better? Cheaper?
  2. Mar 1, 2013 at 4:02 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Super singles. Less weight and better fuel economy I hear.
  3. Mar 1, 2013 at 4:07 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    A fair amount more money as well.
  4. Mar 1, 2013 at 4:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    this.
  5. Mar 1, 2013 at 5:01 PM
    snoope
    snoope Well-Known Member
    Winter Haven Florida
    2002 Tundra Limited 4x4
    We are changing our tri-axle tag tires to supers for just that reason;less weight to us means more sand/rock hauled....We do have 2 newer tri-axles with supers on the front to "increase" the front axle weights we can LEGALLY carry ......
    We then cap those to "run" once or twice on tags ..twice the savings...
    This is what is keeping us from a total switch...$$$$$$$$ up front cost and to convert is only cost effective if "ready built" part is available for the "app" you already own.....The boss/owner is seriously looking at 2 new trailers;dump trailer and flo-boy and both will be on Supers...HUGE gains when you start "Fresh" at the factory....
  6. Mar 1, 2013 at 8:34 PM
    JCBigler
    Chouteau, OK
    So does it seem like these will become the new standard then?
    And semis now will no longer be 18 wheelers? 10 wheelers just doesn't have the same ring to it.
  7. Mar 1, 2013 at 9:22 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    The super singles have been around for decades...more expensive on initial purchase, but less overall problems. They run cooler and give better durability for the same load capacity. Some of the drivers I know really like them with the most significant problem being damaged tires in remote areas and trouble getting replacements.
