Doug Thorley Short Tube Header DYNO!
Discussion in 'Performance and Tuning' started by TacomaGus, Jun 13, 2012.
  1. Jun 13, 2012 at 12:21 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    Finally found a dyno for the 1GR with the short tube headers over on XRU. FJ Cruiser with stock intake and exhaust, just headers. Looks like a +10-20 Ft/Lbs torque gain from 2300-3300 RPM which would be very useable. Def made up my mind on the short headers despite the hassle of welding, hopefully this will help others' decisions on headers easier as well since the long tubes are so popular, yet they may not be the best for some applications/driving.
    Of course they drop off significantly in the higher end, but then thats what the Long Tubes are for...
  2. Jun 13, 2012 at 1:47 PM
    TacomaGus
    Gus
    Morgantown, WV
    bumpage, gotta be some discussion on this one lol
  3. Jun 13, 2012 at 4:02 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Good find. What I had done on my girlfriend's 1GR, with her JBA shorties, was to have v-band flanges welded onto the cats. Between the header and the cat. That way, it opens up a lot of flexibility with her exhaust.
    The cats we used were spun high flow cats from Magnaflow. Having the flanges on them means that we can swap out her cats with new, if/when they go bad. Also, it means that we can swap out the cats for "test pipes" to be able to reduce the restriction, and pick up a little more top end.
    Just haven't gotten around to making the test pipes yet.
  4. Jun 13, 2012 at 4:34 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  5. Jun 13, 2012 at 8:22 PM
    TacomaGus
    Gus
    Morgantown, WV
    very interesting idea. glad i found that graph tho cuz it finally made me settle on the short headers. Now i can get those, and the URD maf cal for the price of the long tubes (with O2 sims). Of course I'll have to get the headers welded in but it's fine since i'll be able to order the headers and maf cal at the same time now all thanks to XRU haha
  6. Jun 14, 2012 at 6:21 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Definitely thanks for posting the find. I've passed on the DTLT GBs twice now as I don't want to lose any low-end, and haven't found any data on the DTST.
    Looking at the graph though, it's a bit of a concern that the ST TQ line is so lumpy.... Just adds some questions as to the viability of this pull, or the actual gains through that range.
    Good to see some gains starting in the low 2k range, but since the graph only starts at 2.2K, and it appears that the slope would take the ST TQ line below the stock TQ line, I still have some concerns about the affect on low-end.
    Thanks again for finding and posting, still good info!
  7. Jun 14, 2012 at 6:31 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Interesting... The second graph still shows stock being better up to 2,500 RPM. I think I'll stay stock :)
    bdej97 likes this.
  8. Jun 14, 2012 at 7:18 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I think the second graph was the LTs...
  9. Jun 14, 2012 at 7:28 AM
    Pugga
    Massachusetts
    Ooh... missed the text between the 2 graphs, I thought it was just a more cleaned up version with the short tubes. :eek:
    I retract my previous statement, seems like the short tubes are the way to go unless you spend a lot of time on the upper end of the rev range. They look promising for commuting and towing.
  10. Jun 14, 2012 at 7:51 AM
    TacomaGus
    Gus
    Morgantown, WV
    ya i was thinking this too, but the graph does seem to agree with the notion of more low end power gain with the ST. And say you did lose a little below 2k rpm, who cares haha, its not like your really every driving around under 2k rpm for an extended period of time. Atleast I'm not with the 6 speed and I usually even shift early to conserve gas (usually shift around 2500 rpm)
  11. Jun 14, 2012 at 2:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When asked, I tell people that the shorties are the best for performance.
  12. Jun 17, 2012 at 10:00 AM
    Cortland
    Cortland THIS IS AMERICA!!!
    Cortland
    Arizona
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
  13. Jun 17, 2012 at 5:42 PM
    Lightningtodd
    Lightningtodd Well-Known Member
    Todd
    Albuquerque
    2010 Double Cab 4x4 TRD Off Road
    Good find. I have been considering the short tubes for a while now, but it seems like nobody has commented much on them. Having the short tubes welded in seems like such a better route to go rather than deleting cats and going with the long tubes. Can't decide if I want to do this mod next or a new grille.
  14. Jun 17, 2012 at 5:45 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    How much would it cost to have a shop weld the cats onto the shortys?
  15. Jun 17, 2012 at 6:22 PM
    TacomaGus
    Gus
    Morgantown, WV
    i've heard anywhere between $250-400 depending on location
  16. Jun 19, 2012 at 11:19 PM
    kikiadv
    kikiadv New Member
    San Diego
    2012 Toyota Tacoma Baja
    what is the catalog/part number for the short ones? i saw the long ones for 2012 4.0L are THY-515-LS-C.
    also does this give you more or less MPG's? I would think more since the truck is breathing better.
  17. Jun 20, 2012 at 8:01 AM
    TacomaGus
    Gus
    Morgantown, WV
    not sure on mpg but i doubt there's much change. it says on URD's website that they do not fit the 2012 tacomas. I'd call gadget to get a better idea of what will work or the time frame for the 2012 header release
  18. Jun 20, 2012 at 8:13 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Nice! :thumbsup: I felt an increase in the top end thanks to my Long Tubes. Too bad I put them on the same time as my lift and big ass tires so I never got to feel the increase on a stock truck's performance.
  19. Jun 20, 2012 at 12:11 PM
    TacomaGus
    Gus
    Morgantown, WV
    ya i only have 32's but they still did some damage performance wise. Can't wait to get the short tubes and maf cal installed to really feel some power and hopefully wake up my intake and muffler (at 2525) some more
  20. Jun 22, 2012 at 1:04 PM
    TacomaGus
    Gus
    Morgantown, WV
    still ended up going with the long tubes. Found a guy on XRU who was letting his JBA LT go for $250 , never installed. Hit up gadget and got the rear o2 sim and gaskets. All comes out to $420 shipped.
