Doug Thorley Short Tube Header DYNO!
Discussion in 'Performance and Tuning' started by TacomaGus, Jun 13, 2012.
  1. Jun 22, 2012 at 1:20 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    blasphemy!
  2. Jun 22, 2012 at 1:42 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That is a hell of a deal! Lucky you man. If I was still paying on my engine build, I would have snagged those up.
  3. Jun 22, 2012 at 3:25 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i know right haha. idk when i will get them, but no rush. Will be updating on here and XRU with the results
  4. Jun 26, 2012 at 12:01 PM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I know the OP went with some LTs, but the other factor in ST or LT decision is that the 09+ stock exhaust manifold was redone a bit going from a log to more of a tube manifold. I "have read" that the 09+ manifold flows better then the pre-09, but not sure how that affects the ST/LT dyno pulls. I would assume that the deltas in the curves is less, but definitely not sure by how much.
  5. Jul 10, 2012 at 11:29 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    tempted to get some shorties if there was another GB offered and see the difference!
  6. Aug 1, 2012 at 12:58 PM
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    How much does a 5 pound increase in torque translate to an increase in towing capacity?
  7. Aug 1, 2012 at 1:18 PM
    XPOTRON
    XPOTRON Is LIVE on the GRID.
    Stefen
    Chandler, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
  8. Aug 1, 2012 at 4:12 PM
    TacomaGus
    Gus
    Morgantown, WV
    just get the long tube's. You DO NOT feel the low end loss with a stock y-pipe. My area (SW PA and WV) is literally all hills, curves, and shit roads and I def have more power to climb these hills now, even in higher gears, than I did before.
    Also after you pay for the install of the short tubes their the same price. Unless you get the stock manifolds off yourself and take it to a shop to be welded, but then if you ever have a leak, you gotta take them off again to get touched up since its prob unwise to weld with the sensors in there
