Doug Thorley vs. LC Engineering
Discussion in '4 Cylinder' started by Wrencher86, Apr 6, 2010.
Which header for the 2TR-FE?
  1. Doug Thorley
    79 vote(s)
    35.4%
  2. LC Engineering
    144 vote(s)
    64.6%
  1. Jan 17, 2012 at 11:28 PM
    #61
    muleyhunter
    muleyhunter Git-r-Done
    Trevor
    Logan Utah
    07 2.7L 4x4
    Afe Pro dry cold air intake, lce header, dynamax super turbo muffler, scangauge II booming stereo
    Well I'm here to say the lce did punch out better numbers than the dt header. Better on low end torque and overall slightly better throughout the range on hp. So from personal experience, their customer service is outstanding and the lce header is worth the extra 30 dollars.
  2. Jan 18, 2012 at 5:22 PM
    #62
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    '10 4x4 5sp 4cyl Access Cab
    Weathertech Floor Liners, Scangauge 2, Tailgate Hose Clamp, Rear Seat Headrests Removed
    I got the LCE and have finished my first 500miles.
    It pulls fine up a long 6% grade on the interstate at 70-75mph without downshifting where previously I had to downshift. That was my semi butt-dyno spot and it passed.
    The Scangage says I am getting a little less than 1mpg better for the same trip, but I will need a lot more time to get that established. It seemed to get a little better towards the end as the ECU adjusted more. I am optimistic about mileage gains.
    Overall, I am happy. My skinned-up knuckles from the 2hour install are healing nicely as well. The sound at startup with stock exhaust is slightly different, but no louder. I don't notice it at all once I start moving.
    Everything fit. The directions are incomplete but if you read the install threads it all works out. Even with trying to fit it in there were no scratches from the studs, so the finish is very durable.
  3. Jan 18, 2012 at 5:25 PM
    #63
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Proofs?
  4. Jan 18, 2012 at 6:15 PM
    #64
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Still gotta put the chart together. It may have slightly better readings but across the board in alot of places was within 1-2hp of dt s and on the low end, the difference it pumps out its about 3.5-4 hp more than the dt at about 2300-2650 but other than that there are a few spots they both read identical.so yeah you definitely don't gain 20hp like the charts above shows its a very minimal gain. Plus the only reason I was able to run the test was the header was sent to me free. (thus the reason I give them some credit.)
  5. Jan 21, 2012 at 4:37 PM
    #65
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    can you show some photos of the LC installed and do you have any of the DT that you removed?
  6. Jan 21, 2012 at 6:19 PM
    #66
    08pretaco
    az
    so you mentioned HP, I dont think HP is what most people want. What were the TQ values? since we are talking low end and all
  7. Jan 21, 2012 at 6:30 PM
    #67
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Good point.I will have to run that test when I have the time
  8. Jan 21, 2012 at 6:31 PM
    #68
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Yeah I can do that
  9. Jan 21, 2012 at 6:32 PM
    #69
    08pretaco
    az
    so what kind of machine/method did you do to run the HP tests?
  10. Jan 22, 2012 at 11:07 PM
    #70
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    It was all done on a dyno in an auto shop my friend works at so it has the torque readings I'm just waiting on him for the two headers to be compared on a grid. He's a freaken slacker and hasn't had the time to get it to me yet.
  11. Jan 23, 2012 at 6:55 PM
    #71
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Very nice, thanks for doing that and please update this thread when you get them. Thanks!
  12. Jan 24, 2012 at 6:35 AM
    #72
    08pretaco
    az
    Trevor, did you remove the AFE intake along woth muffler for testing purposes and put the stock components back on?
    Also what size tires are you running
  13. Jan 26, 2012 at 12:39 AM
    #73
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Shit.. I didn't.eff that screws over a control for the equation! Damn it! You bring up a good point.
  14. Jan 26, 2012 at 12:42 AM
    #74
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    The tires aren't stock but are the same size as stock still
  15. Jan 26, 2012 at 7:04 AM
    #75
    08pretaco
    az
    Still curious nonetheless. Your post can also possibly help confirm wether a CAI for the 2.7 is beneficial or not.
    From what I hear, aftermarket intakes make you lose some low end but help up top.
  16. Jan 26, 2012 at 5:00 PM
    #76
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Good point
  17. Feb 12, 2012 at 4:18 AM
    #77
    SVHANC
    SVHANC Kermit
    Sam
    Knoxville, TN
    Did the dyno results ever come through?
  18. Feb 12, 2012 at 7:12 AM
    #78
    08pretaco
    az
    Bump for the graphs!
  19. Feb 12, 2012 at 9:46 PM
    #79
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Yeah I've got the graphs.they are printed out for me so now I just have to graph the info on a well structured graph when I get the time
  20. Feb 26, 2012 at 7:05 AM
    #80
    muleyhunter
    Trevor
    Logan Utah
    07 2.7L 4x4
    Sorry. Its shed season right now so that's where my free time is going ha ha.I'll get them up eventually
