Doug Thorley vs. LC Engineering
Discussion in '4 Cylinder' started by Wrencher86, Apr 6, 2010.
Which header for the 2TR-FE?
  1. Doug Thorley
    79 vote(s)
    35.4%
  2. LC Engineering
    144 vote(s)
    64.6%
  1. Mar 9, 2012 at 6:41 PM
    #81
    Backroadbomber
    Backroadbomber Active Member
    Dan
    Hamburg, New York
    2011 4cyl 4wd 5sp Base
    Bump for graph
  2. Apr 7, 2012 at 6:39 PM
    #82
    Fast1
    Fast1 Well-Known Member
    Minneapolis, MN
    2021 TRD Off-Road Access Cab
    where are the graphs?
  3. Apr 20, 2012 at 10:54 PM
    #83
    acidfly
    acidfly Well-Known Member
    Kevin
    Kitsap, Wa
    Toytec 3" lift, 4.88 gears, ARB locker, Elite front/rear bumper with sliders, Fully LineXed, Custom bedrack
  4. Apr 23, 2012 at 1:40 PM
    #84
    DESTROYERRACER
    DESTROYERRACER Well-Known Member
    Sean
    Buffalo NY
    18 DCSB 4x4 SR5
    It's new......mods starting soon. Removed step bars so far. lol
    but no 2tr header anymore?
  5. Sep 25, 2012 at 10:12 PM
    #85
    covefrog08
    covefrog08 swollen member
    Vancouver Island- Canada
    08 w/west coast pin-striping
    devil horns, weather tech floor mats, Camo seat cover, window visors, premier deck w/ 6 speakers and sub, checker plate tool box, diff breather relocate, Mag light & Fire Extinguisher behind seat
    i have one that i just ordered a month ago. they said that they were back in production... don't think they would have stopped already..
  6. Sep 25, 2012 at 10:32 PM
    #86
    JPR21
    JPR21 Active Member
    Joe
    San Antonio/San Angelo, TX
    12' Toyota Tacoma 4 Cyl. Prerunner
  7. Oct 2, 2012 at 6:39 AM
    #87
    LoneWanderer
    LoneWanderer Well-Known Member
    Randy
    Ohio
    03 4x4 Access Cab 2.7l 5spd
    Bilstein 5100s, Rancho Quick Lift struts, Wheelers 3 leaf aal, Procomp 8069s, General Grabber AT2 31x10.5, AFE Pro Dry S air filter, Dynomax Super Turbo muffler
    Does LCE not make a header for the 2001-2004s?
  8. Oct 2, 2012 at 7:07 PM
    #88
    TrailerParkJesus
    TrailerParkJesus Member
    Dallas, Texas
    '12 Tundra
  9. Oct 2, 2012 at 7:14 PM
    #89
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Already ordering LCE for my 93. Just sub'd for the charts to come :D
  10. Apr 28, 2013 at 9:00 AM
    #90
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    I know this is an old thread resurrection, but I tried to find the LCE dyno chart referenced, but it appears to have been removed from the web, and that other mythical dyno run chart never appeared.
    Regardless, I went with LCE over DT because I've been running one on my 1st gen 2.4 Tacoma for well over a decade. It fit perfectly, and the engine runs great. I also didn't want to encounter the fitting problems some people had with the DT header.
    The LCE also handled the air injection plumbing far more elegantly than the DT by incorporating everything inside of the mounting flange instead of running those ugly external tubing loops all over the place.
  11. Jun 16, 2013 at 10:59 PM
    #91
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Thanks for the feedback Greg :wave:
  12. Jun 27, 2013 at 8:30 PM
    #92
    tooter
    Greg
    Los Angeles
  13. Jun 29, 2013 at 3:16 PM
    #93
    tooter
    Greg
    Los Angeles
    Did you get the 10% discount? :)
    Coupon code: USA
    I opened up my exhaust with a Magnaflow muffler and lost some low end torque so I put the stock muffler back on and got it back. With an engine only turning 2,000 rpm at 60mph on the freeway the stock exhaust is more than enough.
    To the extent that you reduce exhaust backpressure you will give up low end torque.
  14. Jun 29, 2013 at 3:18 PM
    #94
    tooter
    Greg
    Los Angeles
    That'll save ya 45 bucks. :thumbsup:
    SillyDilly likes this.
  15. Jul 11, 2013 at 9:55 AM
    #95
    Taco2112
    Taco2112 Active Member
    Pittsburgh
    13 4x4 access cab 2.7
    265/75/16 Firestone Destination A/T, Trd or wheels, Bilstien 5100's all the way around set at .85 in the front Comming soon LC Engineering header, avid light bar, lights
    Going to be ordering the LC Engineering header this week. From what i have read there shouldn't be any fitment issues. After the install has anyone had any problems with check engine lights or any issues?
  16. Jul 11, 2013 at 10:34 AM
    #96
    tooter
    Greg
    Los Angeles
    Mine fit perfectly with absolutely no CEL issues. :)
    Just make sure you disconnect the negative battery cable during installation
    so the ECU can go completely stupid to relearn the new operating parameters. :thumbsup:
  17. Jul 11, 2013 at 10:51 AM
    #97
    Taco2112
    Pittsburgh
    Thanks, looking forward to getting these on my truck!
  18. Jul 11, 2013 at 4:17 PM
    #98
    tooter
    Greg
    Los Angeles
    If you haven't gotten a Check Engine Light it still wouldn't hurt anything if you did. What that does is to allow your ECU to relearn your engine's operating parameters to account for the installation of your header.
    Even if I make a minor change on my engine, I always take off the negative terminal to allow the ECU to reset so that it can make the best of the new operating conditions. One thing you'll lose are the a and b trip odometer settings. If you're keeping track of trip or gas mileage, be sure to write them down because they'll reset to zero when you put the terminal back on. Your regular odometer always remembers its setting.
  19. Jul 11, 2013 at 7:58 PM
    #99
    Kilo Sierra
    Kilo Sierra Member
    Alaska
    4x4
    Recently installed the LCE.
    Very nice construction and design.
    Excellent customer service, including a phone from me with installation question the night before. They answered the phone after published hours, and were more than happy to chat.
    Header went in without issue...My big dollar gearhead pals were all over the tube bends, weld beads, and how it bolted to the head and stock exhaust perfectly.
    Impressive improvement...
    ks
  20. Jul 19, 2013 at 11:53 PM
    #100
    mipawlus
    mipawlus #332 Veteran Overland, #159 TTC, #69 in your heart
    Captain Poopypants
    Aggieland
    BROJAHAHAHAHA!!!!
    Rust and dents and squeaks
    I'm curious now as to which one is better for the 6-banger. I'm looking at upgrading, and DTs are the only ones I can find, so they might have to suffice...
