down size 6" fabtech lift PLEASE HELP
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 951mobster, Nov 13, 2014.
  1. Nov 14, 2014 at 4:41 PM
    #41
    951mobster
    951mobster [OP] Well-Known Member
    Anthony
    inland empire
    06 prerunner 4.0l automatic
    6 inch fab tech drop bracket lift, go rhino dominator 2 side steps,K&N cold air intake,bake up camera,straight piped with resonator,6000k hid driving lights and fogs,anytime fog light mod.led interior lighting.
    Dude you are a life saver I had no idea this existed I've looked up and down for a shock to get rid of that stupid spacer I thought my only option was 1500 dollar coil overs (icon &king) ...so this will bolt right up out of the box and replace the need for that 6 inch spacer?please excuse my lack of knowledge I appreciate your time in responding
  2. Nov 14, 2014 at 4:41 PM
    #42
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    lol :rolleyes:
  3. Nov 14, 2014 at 4:44 PM
    #43
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2023 TACOMA LIMITED DCLB LIFTED
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 5% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, LOCK WHEELS 17 X 9 -12 W 275/70R17 TOYO OPEN COUNTRY TIRES
    Yes bolts right up like a stock shock. Radtaco914 is also running this same shock on his db lift as well. He was also looking for an alternative to getting high dollar coilovers so I recommended it to him as well. Rcd is the only db lift I know that runs this longer shock so you don't need to run the top hat spacer if you run this shock. This shock though can be run on any db lift though to eliminate using the stock length shock and spacer that comes with the basic kits.
  4. Nov 14, 2014 at 9:56 PM
    #44
    951mobster
    Anthony
    inland empire
    Okay awesome I'm going order those shocks last question is what to do for the back I have blocks now and really want to junk those I plan on towing a good amount of weight and want to know the best option for the rear.dont know if ad a leaf or a whole new leaf pack is better for towing I have only seen leaf packs that say 3" of lift I wouldn't mind the back being slightly lower than the front but not too to much 2" diffrence max
  5. Nov 15, 2014 at 3:40 AM
    #45
    BORNWILDGUY
    Rich
    Florida
    Get a whole new leaf pack and I would recommend allpro expos which I ran on my truck. Expos will give you 4" and will able to handle the heavy loads. I would also replace the rear shocks with the longer bilsteins for the rear while your at it. be5-b110-t5
  6. Nov 20, 2014 at 6:56 PM
    #46
    951mobster
    Anthony
    inland empire
    Last question those longer shocks your talking about the factory coils work right?
  7. Nov 20, 2014 at 7:32 PM
    #47
    BORNWILDGUY
    Rich
    Florida
  8. Nov 20, 2014 at 7:46 PM
    #48
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    You have to remember that the truck stock has a 2" rake in the front so a 2" lift in the front with zero in the back = level. That is why your 6" front lift kit only uses a 4" block in he rear.
    4" lift front only needs 2" lift rear to be level
    5" lift front only needs 3" lift rear to be level
    Etc..etc...
  9. Nov 20, 2014 at 7:54 PM
    #49
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    and this kids, is why we dont use Drop Bracket lifts on our tacomas.
    I had NO IDEA that they required CUTTING OF THE FRAME.... jezus... its just ruin the structural integrity of the frame while lifting the truck sounds like a great idea to me!
    Looks like you got your options OP.
  10. Nov 20, 2014 at 8:00 PM
    #50
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Not all DB's do that, most only require one cut where the front shaft needs to clear and I hate to break it to you but the steel my DB is made out of is twice as strong as the OE frame, our frames are soft. The cam tabs on my DB are 10 x stronger than the OE cam tabs too...and ultimately if you have a 4x4 it is the only way to get more than 2" of lift without having horrific CV angles etc.
    Thatguy_2131 likes this.
  11. Nov 20, 2014 at 8:02 PM
    #51
    BORNWILDGUY
    Rich
    Florida
    Was just about to say the exact same thing but you beat me to it:thumbsup:
  12. Nov 20, 2014 at 8:02 PM
    #52
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
  13. Nov 20, 2014 at 8:05 PM
    #53
    BronsDaGreat
    BronsDaGreat Well-Known Member
    Bronson
    Wahiawa, HI
    13 TRD Sport DCSB
    6" FabTech Lift 20x12 Fuel Hostage Wheels 33x12.5 Toyo M/T Camburg Uni's UCA Spintech Muffler AppRadio 3 BHLM Wet Okole Seat Covers WeatherTech Floor Liners WeatherTech Vent Visors 6000k HID Headlights and fogs All Lighting Changed To LED AntennaX 13" Antenna Ceramic Tint K&N Drop In Filter Fully Debadged Blacked Out Emblem
    Why did they cut into your crossmember? That's only necessary for 4x4 Tacos..
  14. Nov 20, 2014 at 8:59 PM
    #54
    951mobster
    Anthony
    inland empire
    Required for 2wd as well I believe only fabtech though :mad:
  15. Nov 21, 2014 at 3:30 AM
    #55
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    :laugh::laugh:
  16. Jan 17, 2015 at 9:03 PM
    #56
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    only 4x4 have to cut the crossmember. its only so the front drive shaft has clearance to drop. your 2wd no frame cut necessary. thats any db kit.
  17. Jan 17, 2015 at 9:05 PM
    #57
    951mobster
    Anthony
    inland empire
    Fabtech is the only 2wd drop bracket kit that requires cutting the cross member says it in there handbook as well unfortunately
  18. Jan 17, 2015 at 9:05 PM
    #58
    allrsdup
    Sahuarita AZ.
    crazy i had no idea.. what did u end up doing then?
  19. Jan 17, 2015 at 10:18 PM
    #59
    951mobster
    Anthony
    inland empire
    I left it alone....down sized the tires to 33s and unfortunately going be selling it here in the next couple months
