Downshifting our auto trannies
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hardtaco, Jan 28, 2012.
  1. Jan 28, 2012 at 4:17 AM
    hardtaco
    hardtaco [OP] Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Does anyone know if dowshifting our auto transmissions to assist in slowing down, is going to do any harm? I would think it's OK, but not sure. I have an 08 crew cab PreRunner 4.0.........
  2. Jan 28, 2012 at 4:20 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    There has been many a discussion on this, and it should not hurt a thing. Alot of people do it.
  3. Jan 28, 2012 at 4:46 AM
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    It's never hurt my truck, just make sure you are shifting to a gear appropriate for your speed. Like, don't throw it into L at 55mph. :D
  4. Jan 28, 2012 at 5:34 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    By looking at the way they designed the plate that the shift knob sits in, it's almost as if they meant for you to be manually shifting gears on the fly. I also do not think the computer would allow for it to be thrown into too low of a gear at too high of a speed.
  5. Jan 28, 2012 at 5:37 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    It's good to use for going downhills etc. If you live in hilly terrain it really saves your brakes. If you know what burning brakes smells like after going down a hill, you'd use the downshifts. I do it when I am coming upto a light but I give myself enough space to use it and not use my brakes as often. I found that gear down in other vehicles I've owned that is has made the brakes have a longer life. I make sure that I am doing it under 60 km's an hour. I wouldn't suggest doing 100 km/h and slamming it into "L" or "2". It shouldn't do any damage.
  6. Jan 28, 2012 at 5:37 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Though I have never personally tried it on my truck, I am almost certain that there are ECU controls that won't let the transmission just drop into 1st gear at 65 for example... That would grenade your tranny in a hurry.
  7. Jan 28, 2012 at 6:10 AM
    bethes
    Beth
    I don't know if the computer would let you shift too far down or not, but I'm not willing to try it and find out, either. If you're close to redlining you're in the wrong gear. Hit your brakes firmly, slow quickly to a good speed. Riding the brakes down a hill is what burns them out.
  8. Jan 28, 2012 at 8:17 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    ANY vehicle will not shift into a lower gear for the appropriate speed. The transmission control module will not turn on the solenoid until the proper speed is appropriate. You are just using a Set of over running clutches when you use this. It will do NO harm to you transmission at all. The only time I have ever seen a transmission take a dump because of the user using this feature, was because he was also towing a 28 foot boat in behind him through the mountains of Alaska. This is why the invited TRAILER BREAKS for. I took the transmission out, replaced those 4 clutches and steels, reconditioned the 3-4 and reverse clutch pack. And they where on there way. Was not that bad of a thing to do
  9. Jan 28, 2012 at 8:19 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Yup, I do it all the time.
    Makes me look like a ricer :cool:
  10. Jan 28, 2012 at 8:20 AM
    jw1983
    Alberta
    Lol^^hes a ricer
  11. Jan 28, 2012 at 8:23 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    When coming to a stop sign from 55+ I shift from D - 4 - 3 all the time. The computer controlled transmission will not allow you to downshift in a manner that will harm the truck. Your face is a different story: be careful if you shift into L while on the move. The truck will try to pitch you through the windshield.
  12. Jan 28, 2012 at 8:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    FWIW, THe computer will NOT let you go into too low of a gear You can move teh shifter into one, "L" for example, but it wont actually shift until you are at a safe enough speed. ALso, if it DID allow you to shift into a gear at any speed, the tranny would be fine, but the engine would over speed.
  13. Jan 28, 2012 at 8:47 AM
    186000mps
    186000mps ..Slingin' up mud and we're scarying off bunnies..
    Charles
    Wimberley, TX
    01 Tacoma V6 4WD
    Bilstein 5100's, Toytec front adjustable coilover kit, Exporear leafs, Fox resi rears, Slotted & Drilled front rotors, 33x12.50 BFG ATs on Outlaw II 15 x 10s, Bushwacker cutout flares, K&N cold air intake with aluminum sheathing water baffles, ARB bumper with XD9000 winch with wireless remote, IPF 900XS lights, Flowmaster cat-back exhaust, Rhino bed liner, UWS gullwing toolbox with tools and recovery gear. 48" Hi-Lift Jack secured under toolbox.
    In our Auto 4Runner coming down the mountain passes around here, especially around Killington, I drop to 3 at the crest of the hills, it keeps me right around 55 the whole way down without using the brakes. I see lots of cars ahead of me with their brakes on most of the way, I am glad to be saving my brakes for when I really need them.
  14. Jan 28, 2012 at 2:54 PM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    What about coasting down a hill in N for better mileage is that harmful
  15. Jan 28, 2012 at 4:21 PM
    Maticuno
    2011 Suburban 2500
    It's actually better to descend a hill in gear. With the transmission turning the engine on a downhill run, the computer will shut down the injectors and you will be rolling along using ZERO fuel, instead of using enough fuel to keep the engine idling if you were coasting in neutral.
  16. Jan 28, 2012 at 4:26 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    interesting.. how does the engine continue firing without any fuel going thru the injectors tho?
  17. Jan 28, 2012 at 4:38 PM
    JKD
    JKD Well-Known Member
    Since the computer already downshifts while coming to a stop anyway, you won't do any further harm doing it manually.
  18. Jan 28, 2012 at 4:50 PM
    Sheppymach
    Sheppymach Well-Known Member
    Sheppy
    Philadelphia, Pa
    2014 4Runner trail edition
    BLU LOGIC bt, avid, weather tech mats & rain guards, 285/70/17, BenWA's totally AWESOME power sliding window mod.
    I have been doing it since the truck was new and in my 04 Audi A4 and never had a problem. the Audi actually loves being shifted manually
  19. Jan 28, 2012 at 4:53 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    It's fine
    Deja vu this thread
  20. Jan 28, 2012 at 5:04 PM
    Maticuno
    2011 Suburban 2500
    Is it safe to downshift while ATRAC is active? :D
