Drain Mod instead of Deck Plate Mod???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Turp, Jan 30, 2011.
  1. Jan 30, 2011 at 5:27 PM
    Turp
    Turp [OP] Well-Known Member
    Virginia
    02 PreRunner SR5
    K&N panel/ snorkel removed Keyless, 2022 4Runner Wheels
    If you're not off roading, any need in a deck plate?
    I was thinking of a floor drain route. I saw this was used by another Tacoma owner and am considering it.
    Application: You pretty much cut the same size and positioned hole as the Deck Plate Mod and the floor drain fixture screws in place with its own retaining nut. The drain has a grate so large debis would be kept out. Down-side for wet offroading is it's harder to plug, but for my use, not a problem.
  2. Jan 30, 2011 at 5:35 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
  3. Jan 30, 2011 at 5:41 PM
    Turp
    Virginia
    02 PreRunner SR5
  4. Jan 30, 2011 at 5:43 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Yes-there's the box-an elbow attachment fitted in the fender-then a long snorkel that runs backwards toward your radio antenna inside the fender.
  5. Jan 30, 2011 at 5:46 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    I disconnected the long snorkel and pulled it out, then I removed the elbow and cut the L part off and re-inserted the remaining part that fits into the fenderhole-then reattached the box to that, This gets you cool fresh air from outside the engine bay-plus it still looks stock at the box
  6. Jan 30, 2011 at 5:59 PM
    Turp
    Virginia
    02 PreRunner SR5
    Curious about the mounting bolts. Did you spin the snorkel in the mount flange or spin the whole mount flange and disregard bolting it to the fender?
    I'm no stranger to removing snokels and I like your approach.
    Your mod puts the air intake postion where my stock 2nd gen Isuzu Trooper was; thing was it had a snake of pipe that was a "U" shape around the airbox. I removed it. In addition My YJ Wrangler had a short snorkel that extended forward through the grill, but still had a turn in it and small opening. Both were just above the headlights and the modified opening were only slightly lower than original.
    Looks like I'll do some snorkel removal, take the drain back, and pocket 7 bucks... Thanks
    You mentioned the engine sound, I noticed that right after installing my K&N on my Tacoma and my Jeep.
  7. Jan 30, 2011 at 7:10 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    As you can see in my thread I first cut about 3' of the elbow at an angle and then spun it forward to "catch" the incoming air-but after consulting with Gadget-the guy who started this thing, he told me it's still acting restrictive that way and looking at that bend it made sense, so I cut that elbow all the way down but left that "tab" to help keep it properly seated in the fender. Now it has that nice big opening suckin up that fresh air sans engine heat you may suck in with a drainmod or deckplate. The key is to keep that fender insertion part of the mod to keep hot air out of the equation. They apparently installed this whole thing to make the truck able to ford water-that's nice if you find yourself in that situation-but us regular guys will never see that. This mod basically puts the fresh air entry point back to where it should be.
  8. Jan 30, 2011 at 8:00 PM
    Turp
    Virginia
    02 PreRunner SR5
    Like this method. Thanks
  9. Jan 30, 2011 at 8:16 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    Glad to have helped ya! Please put up how you like it-oh and very important...do the ECU reset by disconnecting the positive side of the battery for about 10 minutes then reconnecting it so it can learn the change quickly. I disconnected mine then did the mod then reconnected it-so about a half hour.
  10. Jan 30, 2011 at 9:07 PM
    Turp
    Virginia
    02 PreRunner SR5
    Sure Thing
