Dreaded "thump/clunk"
Discussion in '1st Gen. Tacomas (1995-2004)' started by AFBombdude, Jun 11, 2008.
  1. Jun 11, 2008 at 2:42 PM
    AFBombdude
    AFBombdude [OP] Member
    Litchfield, AZ
    '01 PreRunner SR5
    Bone Stock for now
    I had the dreaded thump when stopping or just after I had let off the brakes. Felt like the tranny had dropped and my gear shift (auto) would move around alot. I crawled under the truck and lubed the slip yoke and u-joints. Clunk GONE! It was driving me nuts!!
    You should have seen the crap that came out of the joints/yoke as the new lube pushed out the old stuff.
    I hope this is not a band aide fix for another problem so I am gunna keep my eye on it. But, it's gone for now!!
  2. Jun 11, 2008 at 3:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you did the right thing......as they were probably about dry as hell. just keep an eye on everything, but i dont think you should have a problem now.
  3. Jun 11, 2008 at 4:29 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    But if it does come back after some time, it may also be the dreaded axle wrap that Tacos are notorious for.
  4. Jun 11, 2008 at 4:31 PM
    BlueSilver
    BlueSilver Wave rider
    All this Taco talk is making me so hungry
  5. Jun 11, 2008 at 6:20 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I refuse to refer to my truck as Mexican fast food:D ............sounds like the dreaded axlewrap as stated above...will more likely occur whenever you come to an abrupt stop.
  6. Jun 12, 2008 at 8:00 AM
    BlueSilver
    I agree, I think calling a Tacoma a "taco" is really lame. It gives the truck a bad rap. First time I heard it I thought about the truck offroading and somehow folding in half becuase it coulden't take the terrain.
    Stop abusing the Tacoma! Thats like calling your children bastards or red headed step children. Bad carma!
  7. Jun 12, 2008 at 8:35 AM
    AFBombdude
    Litchfield, AZ
    '01 PreRunner SR5
    Bone Stock for now
    I am going to look for the axle wrap also (I hope I can get some a autozone J/K :D ). I have put my tacoma through it's paces and so far so good even on hard abrupt stops. If it starts again I will update. Thanks
  8. Jun 12, 2008 at 9:52 AM
    hardtaco
    hardtaco Well-Known Member
    Sarasota, FL
    08 PreRunner DCSB
    Don't sweat the bump / clunk deal. Most (if not all) the first gens do it at some point. I thought my tranny was screwed up at first. It felt like it wasn't kicking back down into first gear until after I let my foot off the brake at a stop light, then I feel the "bump". Oh well.
  9. Jun 16, 2008 at 5:58 PM
    Ga2000TacoOwner
    Ga2000TacoOwner Member
    The thump/clunk finally got to me (along with a worn out CSB) so I replaced the factory two piece set up with a one pice set up. Only cost me $325 installed. Best money I have ever spent.
  10. Jun 17, 2008 at 4:24 AM
    hardtaco
    Sarasota, FL
    08 PreRunner DCSB
    So, no more clunkin and bumpin???
  11. Jun 17, 2008 at 4:43 PM
    Ga2000TacoOwner
    Nope, no more clunkin and bumpin!!!
  12. Jun 17, 2008 at 5:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have never heard of a 1 peice fixing axel wrap. You may have had binding in your slip joint.
  13. Jun 17, 2008 at 5:42 PM
    Ga2000TacoOwner
    Tom Wood's Custom Drive Shafts sell the one piece shafts everyday for that reason and also to eliminate unwanted vibrabtions. I found my local for less because they reused my double CV and slip yoke.
  14. Jun 18, 2008 at 9:05 PM
    furlong24
    furlong24 Well-Known Member
    prerunner
    my truck has the same problem, i just had not time to work on it yet.
  15. Jun 21, 2008 at 12:28 AM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    short of the lack of maintainence...
    Axle wrap causes the thunk...
    New heavier duty spring paks help a bunch
    Or a traction bar designed for full travel... ie... Blue Devil and the likes... is another route
    Vibration is caused most normally from bad pinion angle/alignment... more noticeable after lifting...
    *Discounting bent things and poor tire balance
    I have never needed a one peice driveshaft to find harmony...
    Suspension Lifts under 3" shouldn't really be an issue... but if it is... 3* and lesser degree shims (based on pinion angle) can be placed between the spring and axle to dial that in a little closer... and most likely take care of those vibration issues... and may even help with the venerable clunk on the DS slip joint
    I have about 2 1/2" suspension lift in the rear...
    My Deaver leaf paks eliminated that clunk... which I had with the pos oem leafs...
  16. Jun 21, 2008 at 5:03 AM
    Ga2000TacoOwner
    You are one of the few lucky ones then.........
  17. Jun 21, 2008 at 6:03 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I thought that the 1.5* or 2.5* shims are the best for this fix? :)
  18. Jun 22, 2008 at 11:37 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    Yer probably right... I should have said 3* or less
    It will vary depending on actual lift of course...
    measuring the pinion angle will net which shim is correct for each individual circumstance...
  19. Jun 25, 2008 at 8:17 AM
    AFBombdude
    Litchfield, AZ
    '01 PreRunner SR5
    Bone Stock for now
    Well, as the grease I used on the slip yoke slowly comes out the clunk is returning. I ordered a new CSB and will install it in the next few days. Will report back on the status.
  20. Jun 25, 2008 at 8:31 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Ok my first question what is a CSB? May be a dumb question but im lost
    mine does the samething but it seems like about every 2,000 miles after i have filled the yoke with grease it comes back.
    O well guess i can deal with crawling under it every now and then lol
