Drift shaft from 3.4 same as 2.7?
Discussion in '1st Gen. Tacomas (1995-2004)' started by mk23, May 17, 2017.
  1. May 17, 2017 at 3:36 PM
    mk23
    mk23 [OP] Member
    Eagle CO
    2002 Xtra cab 2.7 i4 4wd sr5 grn
    k+n cai, Leer cap, headers, 17 MT classics, 32" Cooper Atp, Bilstein 5100/ome 880, 20" Led bar
    Can I swap a complete rear driveshaft from a 2003 3.4 v6 Xtra cab to a 2002 2.7 i4 xtra cab?
    DustStorm4x4 likes this.
  2. May 18, 2017 at 1:30 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  3. May 20, 2017 at 1:20 PM
    mk23
    mk23 [OP] Member
    Eagle CO
    There is a used 1listed on CL all rebuilt (claiming) new carrier bearing and u joints, for 200$. says he spent 200$ for service, and ended up buying a custom 1 piece. From the listings I've viewed, seems to be a slightly different part #, but that doesn't necessarily mean that it is indeed a different part
  4. May 20, 2017 at 1:25 PM
    mk23
    mk23 [OP] Member
    Eagle CO
    Seems that auto or manual may be more important of a question that 6 or 4 cylinder. Obviously the cab length too, but they are the same.
  5. May 20, 2017 at 3:04 PM
    mk23
    mk23 [OP] Member
    Eagle CO
    Seems that The manual version of the same engine seems to be 4" longer (front portion anyways) than the auto version, so from that I'm gonna say they not identical(the donor shaft is from v6 auto). Not sure about the rear portion. Maybe some compatable parts. The rear part of mine (propeller shaft) is the suspect of upcoming failure
  6. May 20, 2017 at 5:30 PM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    for what its worth I was told 4c and 6c trannys are way different and no way to mate them, I would be shocked if the driveshafts weren't also different size and lengths
  7. May 20, 2017 at 6:10 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Check the part numbers up in the links I posted - looks like they might be the same. I didn't want to go and say they were w/o confirming from one of the parts dealers. Don't want to be that guy when I'm not sure. Drive shaft flanges might be universal parts on Toyotas so the lengths seem to be the factor that will make or break it :notsure:
    keakar[QUOTED] likes this.
  8. May 20, 2017 at 6:15 PM
    keakar
    karl
    louisiana
    ya, I mean if the part numbers match they match, just seems strange if the trannys are different sizes and lengths then what gives if the shafts are the same?
    maybe its just the engine mounting positions and that's why the shafts are the same? :notsure:
    Dalandser[QUOTED] likes this.
  9. May 20, 2017 at 6:32 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'm thinking they might have engineered the housings to make sure that they would match up to use the same driveshafts to cut down on cost. Just my guess though.
    @mechanicjon
