Drilling through 18/8 70k psi fasteners
Discussion in 'Garage / Workshop' started by soggyBottom, Nov 18, 2024.
  1. Nov 18, 2024 at 11:24 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    I need to safety wire some 18/8 70k psi fasteners. Are cobalt bits enough? Can I use manual application of cutting oil or will I need flooded coolant?
    Any advise would be appreciated.
    @soundman98 somehow I feel like you may the answer here
  2. Nov 18, 2024 at 11:34 AM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    Do you have a milling machine?
  3. Nov 18, 2024 at 11:36 AM
    undisider
    undisider Member
    Nathaniel
    2x 99 tacos
    one "stock" TRD one lifted/locked, supercharged SR5
    They should drill fine but stainless likes to work harden don't let the drill bit turn in the hole without cutting or it will harden and break the drill bit or just not be drill able anymore. Cutting fluid can be useful but down let the part heat up. A drill press or better would be help alot with good and consistent feed
    soggyBottom[OP] and Pablo8 like this.
  4. Nov 18, 2024 at 4:32 PM
    InThePlains
    InThePlains Well-Known Member
    Sharp bits and plenty of flowing cutting fluid.
    soggyBottom[OP] and soundman98 like this.
  5. Nov 18, 2024 at 6:25 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i work with stainless fasteners, but i don't believe anything my company supplies to me is that high quality/tensile strength...
    all the comments so far are what i'd say. speed tends to be slow, keep it oiled, and if you've got lots of holes to make, it's better to go through extra bits than to try forcing the same bit through all of it.
    i've generally been pretty happy with the store-bought milwaukee titanium bits. the blue color spyder bits tend to cut slightly better in metals, but are about double the cost, so always been a tough sell. i haven't tried a ton of cobalt bits, but the few i have cut only marginally better, but not enough to justify the additional cost premium for me.
    most of it comes down to the cost/speed you want the project to go. higher end bits can make for faster drilling, but get obscene pretty quickly cost-wise.
  6. Nov 19, 2024 at 11:56 AM
    InThePlains
