Drive line shudder after leaf spring replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Apr 22, 2013.
  1. Apr 22, 2013 at 8:27 PM
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I just recently replaced my stock leaf springs after one broke with HD springs from General Spring in KC. The guys at General told me it would probably raise the rear 2" higher than stock and after a month or so it would probably settle to 1.5". My intent here was not to lift the truck, just to replace the original springs with something a little stronger.
    I'm now noticing a bit of an occasional shudder at low speeds. I don't always notice it, it sometimes seems like it fades away when turning especially. I think I may notice it when coasting and decelerating more than when accelerating.
    Is this a common occurrence with an angle change in the rear? Is there a solution to this?
  2. Apr 22, 2013 at 8:34 PM
    Jetman1979
    Jetman1979 Well-Known Member
    Michael
    North Texas
    2009 tacoma 4X4
    Throw some weight in the rear and see if it stops the shudder.
  3. Apr 22, 2013 at 8:39 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  4. Apr 22, 2013 at 8:40 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    What did you torque the U-bolts to?
  5. Apr 22, 2013 at 8:42 PM
    PA452
    Western PA
    I think it was about 80, though I don't have the numbers in front of me.
  6. Apr 22, 2013 at 8:54 PM
    KenLyns
    Belly of the Beast
    ^That's good, as long as it wasn't 37...
  7. Apr 22, 2013 at 8:58 PM
    PA452
    Western PA
  8. Apr 22, 2013 at 9:00 PM
    TacomaG26
    TacomaG26 Well-Known Member
    Nic
    Goldsboro NC
    4.0v6 4x4 TRD Sport
    2.5in spacer leveling kit with Toytech AAL in the rear, Brute Force Fab front and rear bumper, AFE stage2 CAI, Alpine headunit with Rockford Fosgate amp and sub, tibted windows, KC lights.
    Hey i have the exact same thing going on, i just added a 1.5in toyotec leaf and the same is going on......
  9. Apr 22, 2013 at 9:01 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    You guys should probably get the carrier drop or shims for the leafs. They are on toytec website.
  10. Apr 23, 2013 at 9:18 AM
    PA452
    Western PA
    I read somewhere that guys who lifted the front and rear didn't have this problem. I have Bilstein 5100s on all four corners. Would it help if I took the front up a setting?
  11. Apr 23, 2013 at 9:21 AM
    DevL
    DevL Well-Known Member
    No, it will not help. It only has to do with rear drive shaft angles.
  12. Apr 23, 2013 at 9:44 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Make sure your tail pipe is not contacting the springs. I had that happen when I changed the spring set on my 2004 and some times it would shake the truck pretty bad and other times not so bad depending on the road surface.
