Drive Shaft Lube Points 2nd Gen 4WD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moondeath, Jun 18, 2012.
  1. Oct 16, 2017 at 4:19 AM
    #41
    sioux
    sioux Well-Known Member
    Northern Minnesota
    2012 DCSB SR5 4x4
    I just wipe it down with a shop towel. It doesn't need to be spotless, excess grease will just get flung around the undercarriage. Wiping it down with a shop towel has worked just fine.
  2. Oct 16, 2017 at 4:46 AM
    #42
    gearcruncher
    Canadain bumper technician
    The Slip Yoke is dry because the type of lubricant used is very expensive . Regular grease will only last a day . With this said , manufacturers cheap out and just dribble enough on the splines to make your truck feel new .
    Spicer still has the driveshaft contract with Toyota . Spicer also makes driveshafts for General Motors , Ford and Chrysler
    Adding a grease zerk to the slip yoke causes the slip yoke to extend and hydro lock .
    The only way to properly lube the slip Yoke is by removing the driveshaft and manually applying the " Special Lube "
    If you have a two piece driveshaft , reports are coming in there is a lack of lubricant on the splines of the slip and stub . Your truck will clunk when downshifting into first gear when cold . Takes a special lubricant
    This stuff will work http://www.lowrangeoffroad.com/ptfe...-ford-motorcraft-xg-8-ml1167-31508-42027.html
    And this stuff is said to be the best but pricey http://paceperformance.com/i-782162...bricant-high-temperature-c1-2-w-a-t-1-lb.html
    AlCapwn, a400ryan, GilbertOz and 4 others like this.
  3. Oct 17, 2017 at 5:16 PM
    #43
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Thanks for the info.
    I need to do this. How hard is it to remove and grease?
  4. Oct 29, 2017 at 7:41 AM
    #44
    Trandall13
    Trandall13 Member
    2014 white Tacoma TRD
    Awesome thread! I was struggling with how to get to the 2 hard to reach zerks.
    Alexely999 and Benzdriver81 like this.
  5. Dec 4, 2017 at 7:19 AM
    #45
    mystert
    mystert Well-Known Member
    Eric
    Ventura CA
    2005 Tacoma TRD Sport 4x4 6spd
    Ive owned my truck for a few months now and while changing the oil I tried to grease the driveshaft and the u-joints don't have any grease fittings. The truck is a 2005 TRD Sport 4x4. Is this normal? No zerks on the caps or on the main body of the u-joints
  6. Dec 4, 2017 at 12:01 PM
    #46
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    Any pics, by chance? My 05 Sport 4x4 has them :notsure:
    Alexely999 likes this.
  7. Dec 4, 2017 at 6:05 PM
    #47
    PDXKid
    PDXKid Active Member
    2011 DC TRD Off Road Manual Transmission
    Stock for now
    I was just under there doing all of the drive fluids (F&R diff, transfer case and trans.) Why didn't I think to do this then? :annoyed: :homer:
  8. Dec 12, 2017 at 7:55 PM
    #48
    PFD FIRE
    PFD FIRE Well-Known Member
    David
    San Diego
    2011 Toyota Tacoma TRD Sport
    265/75/16 Goodyear Duratrac Tires, Total Chaos UCA, Bilstein 6112 Coilovers (front) Bilstein 5100 (rear), TRD CAI, TRD Cat Back Exhaust, Rough Country/Lamphus LED lights, rear ARB locker, Baja Rack
    I have a 2011 tacoma 4x4 dbl cab, it has about 90,000 miles and I’ve never lubed the drive shaft U-joint. It’s my guess it’s time to lube them. What grease do you recommend to use for my tacoma?
  9. Dec 13, 2017 at 3:57 AM
    #49
    BadDNA
    BadDNA Uh, huh huh... Member
    Eammon
    Cabot, VT
    '15 Blue Ribbon Metallic DCLB SR5 4x4
    OME BP-51s, JBA UCAs, Dakar leaf pack, Hammer Hangers, SOS Skids and sliders, Mobtown Tailgate reinforcement, Bussman fuse block, and stuff...
    I like the Lucas Red-N-Tacky but any quality chassis and bearing grease is going to be fine.
  10. Dec 13, 2017 at 7:28 PM
    #50
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    Same here.
  11. Dec 14, 2017 at 2:54 PM
    #51
    TONYCANNOLI
    TONYCANNOLI Well-Known Member
    ‘15 DCSB 4x4 Sport / ‘14 SR5 Premium 4Runner
    Sub’d. I have been getting a loud thud as well when I brake. Sounds like the driveshaft. Truck only has 15k on it.
  12. Mar 27, 2018 at 9:02 AM
    #52
    MilSpec
    MilSpec Well-Known Member
    2014 Tacoma TRD Off-Road [1GR-FE] [A750F]
    Me too... this is something my father instilled in me when he taught me how to change the oil on his '84 Toyota Pickup. Back then it was every 3k miles.
  13. Mar 27, 2018 at 9:07 AM
    #53
    MilSpec
    Odorless mineral spirits should make it much easier to wipe away. Just soak some blue shop towels and wipe.
  14. Mar 27, 2018 at 9:28 AM
    #54
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Thread revival!
    I actually just greased my zerks this weekend. Pretty easy stuff. Used mobil synthetic pink grease.
    Only thing that was strange was that I had a hard time getting the grease gun house off the zerk. Once it was on it was a bit difficult to get off, is that normal or is it my grease gun?
  15. Mar 27, 2018 at 9:32 AM
    #55
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Sounds normal. Can you adjust the grease gun? I have to fiddle with mine
    TacomaMike37[QUOTED] likes this.
  16. Mar 27, 2018 at 11:36 AM
    #56
    TacomaMike37
    13' DCLB MGM
    Just checked can't adjust the grease gun. All good though
  17. Mar 27, 2018 at 12:44 PM
    #57
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    CMD-KY likes this.
  18. Mar 27, 2018 at 12:49 PM
    #58
    TacomaMike37
    13' DCLB MGM
  19. Mar 27, 2018 at 12:54 PM
    #59
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    How hard is it? What does it entail doing? Ty
  20. Apr 5, 2018 at 12:39 PM
    #60
    patchesj
    patchesj Well-Known Member
    So I was able to get the 2 on the front shaft without any issue. Then found the one behind the transfer case, and the one after the carrier bearing. But... The one on the rear diff is just not there. No fitting on any of the ends of the u joint. What is going on?
