Drive shaft spacer
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lscates03, Oct 28, 2016.
  1. Oct 28, 2016 at 8:09 PM
    Lscates03
    Lscates03 [OP] Active Member
    Luke
    2002 Red Tacoma TRD & 2018 Cement Gray TRD OFF ROAD
    my truck is vibrating after lifting it and my tires are balanced. The steering wheel does not shake but the truck itself has a slight vibration. The local off-road shop recommended getting a drive shaft spacer. However, I cannot find any online. Has anyone else done this? And can you help me find the spacer?
    Thanks
  2. Oct 28, 2016 at 9:09 PM
    wamego
    wamego Well-Known Member
    2002 Tacoma 2x4 TRD SR5
    Have you checked the driveshaft carrier bearing??? You might also think about lowering it some to help reduce the over all angle from the carrier bearing to the diff.
    inwood customs likes this.
  3. Oct 28, 2016 at 9:17 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    This, and or shims
  4. Oct 28, 2016 at 9:33 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    possibly it's lifted incorrectly or even too much ?
    had to say without seeing pictures and having details.
    But nine times outta ten it's an improper spin balance,
    possibly failed by using the wrong cone or backing plate.
    1st gen. Tacoma are lug centric.
    So when spin balancing the wheel should be mounted
    to a flat plate with the appropriate lug pattern in that.
    Then secured (balance offset) using a properly sized cone on the outside.
    I made my America's tire order the correct lug centric backing plate.
    Never had a balance issue since I've been going to them.
    It's not necessarily the spin balance machine that is used.
    It primarily has to do with having the proper backing plate.
    Many tire shops may not have the proper adapters...
    and just wing it with what they do have.
    Majority of vehicles out there are hub centric
    and usually balance just fine with cone adapters.
    ask the proprietor
    The 1st gen Tacoma are a little more finicky
    then the later Tacoma models.
    Gotta be either the tire balance...
    or something to do with the new lift/install, right ?
  5. Oct 29, 2016 at 12:38 AM
    NightProwler
    NightProwler Well-Known Member
    Harlan
    Maricopa, Az
    '01 Prerunner, '16 trd4x4, '03 cbr954rr, '03 rc51
    All pro has this one listed under the first gen section. But when you click on it, it says 05+.
    Might fit ours. Give them a call and see. Otherwise shims.
    You said it happened right after lift so I'd assume it's that and not the wheels. But if there's a chance it is the wheels, it happens, like mentioned above. I too had vibes I fought with and big o never got it right. Until I took it to discount tire and vibes were gone after balance. They must have the better ones.
    Sicyota04 likes this.
  6. Oct 29, 2016 at 4:31 AM
    gearcruncher
    Canadain bumper technician
  7. Oct 29, 2016 at 8:35 AM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    Same here. Had vibes and every time I would leave Big O it was the same damn thing. Big O couldn't get it right. Fought it for 6 months. Took it to Les Schwab the first time and done! No more vibes. I had to pay $31.50 to get them balanced since I didn't buy my tires there so I took the receipt back showing how out of balance the tires were and asked Big O to pay me back the money I had to pay to get them balanced and they did!
    grubburg and 3rYODA like this.
  8. Oct 29, 2016 at 6:27 PM
    3rYODA
    3rYODA Don’t sell to me, I don’t pay.
    Santa Clarita, CA
    2015 white 4x4 TRD
    Fox 2.5’s up front, icon 2.0 rear shocks, stock leafs, !Meso map and dome lights make all the difference in the world!
    Love when shit like that works out
  9. Oct 29, 2016 at 7:19 PM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    Yeah. Me too!
  10. Oct 29, 2016 at 8:44 PM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    +2 for shims. They are the most complete solution for rear lift with a double cardan type rear drive shaft.
  11. Oct 29, 2016 at 9:31 PM
    NightProwler
    Harlan
    Maricopa, Az
    So I'm kinda worried about this when I put in my dakars. Should I order some up anyways as they're cheap? Or should I not and wait to see how it does? It will be lifted about the same as it is now as I have blocks. Got a little vibes but think it's just my tires. Haven't got a balance in quite a while. But figured while I was at it with the leafs it would be easier to put them in at the same time. And do you have to get longer center pins with dakars and shims added?
  12. Feb 6, 2021 at 1:54 PM
    Lscates03
    Luke
    FYI - this was caused by the Ebrake not being adjusted after lift. The driver side rear drum was dragging. Even after readjusting the shoes it would go right back to dragging.
