Drive Shaft vibration, ABS randomly activating on turns
Discussion in 'New Members' started by SouthTexasTacoma, Mar 20, 2013.
  1. Mar 20, 2013 at 10:41 AM
    SouthTexasTacoma
    SouthTexasTacoma [OP] New Member
    Jeremy
    San Antonio, Tx
    Lifted 4x4
    6" lift 33" tires 20" wheels
    I bought my first Tacoma 2 weeks ago.. Just installed a 6" Pro Comp suspension lift kit and 33" tires on it this past Sat. I am now having drive shaft vibration while on the accelerator (i have tried but shims provided with the kit for the carrier bearing) and sometimes my ABS will randomly activate when I'm making a turn. Anyone with common problem or possible helpful knowledge??
  2. Mar 20, 2013 at 10:47 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    You're positive it's the ABS and not the VSC?
  3. Mar 20, 2013 at 10:50 AM
    SouthTexasTacoma
    Jeremy
    San Antonio, Tx
    Lifted 4x4
    The little traction light blinks and it feels like abs but in the Gas pedal. What is VSC
  4. Mar 20, 2013 at 10:59 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You need to get the ECU reset for the taller tires. The computer thinks you're in an unsafe situation because it reads the speed difference between the wheels and changing the overall diameter of the tires will alter what the computer is reading.
    What you are experiencing is VSC, Vehicle Stability Control.
  5. Mar 20, 2013 at 10:59 AM
    Fightnfire
    Marysville, WA
  6. Mar 20, 2013 at 11:00 AM
    C O R E
    C O R E Christian Off Road Engineering
    Clint
    South Texas
    03 TRD 4x4 5spd v6
    Line-X bedliner, bedlined toolbox, Satoshi Grille, bedlined stock old school wheels, Pioneer DEH-X9500BHS head unit, Deck plate mod, ISR mod, K&N Drop-in, Thrush muffler dumped @ rear axle, Grey wire mod, +5mph fender stripes
    The increased angle of the driveshaft may be causing it to bind under accelaration. Do the 2011's have a double-cardan style driveshaft? if not, I would assume that replacing it with a double cardan would fix the issue. 6" is alot of lift without modifying any of the drivetrain... Then again, I'm assuming you havent made any drivetrain mods already.
    I'm on the south side of San Antonio by the way, nice to meet another taco neighbor!
