Drive Shaft Vibration After Installing 3 degree axle shims
Discussion in 'Suspension' started by lpfe42, Jun 4, 2018.
  1. May 10, 2019 at 11:11 PM
    whatjones911
    whatjones911 Well-Known Member
    2018 DCSB OR 4x4 MT
    Yeah it is in the correct direction. My working angles are low. From TC, 4.1 — 2.9 — 1.1
  2. May 12, 2019 at 2:21 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The correct way to setup a 2-piece driveshaft with 3 single u-joints is, 0-equal-equal.
    The alternative method is, equal-0-equal. This basically mimics a one-piece driveshaft with 2 single u-joints. This, as you know, requires a carrier drop. IMO, the angle of the carrier drop should be considered, to avoid binding the bearing.
    What was your first working angle before the carrier drop?
  3. May 12, 2019 at 2:58 PM
    Vjtrey1
    Vjtrey1 Well-Known Member
    Richmond, Tx
    2018 Super White Tacoma TRD OR DCSB
    Simple mods
    I know this but if you have a warp rear axle it will still shudder or vib no matter how perfect your angles are.
  4. May 12, 2019 at 3:10 PM
    splitbolt
    NW Arkansas
    True...but his working angles, if correct, are horrible.
  5. May 12, 2019 at 5:18 PM
    whatjones911
    2018 DCSB OR 4x4 MT
    Method 1, 0-equal-equal, is out of the question since from factory Toyota sets this up at an angle. You could modify the carrier bearing cross member to get it to zero but can't see myself doing that
    My best attempt would be to go for method 2, equal-0-equal.
    There's a third method and that is a net zero of all 3 working angles considered which I learned from 4crawler.com. This is what I am trying to shoot for which for my situation of 4.1 — 2.9 — 1.1 should be pretty close but I guess it doesn't work or most likely I am misunderstanding this method.
    First angle before the CB drop was 3.3
  6. May 12, 2019 at 5:44 PM
    whatjones911
    2018 DCSB OR 4x4 MT
    After some thought, Method 3 would work but not in my case. The example 4crawler has up works, 2 - 4 - 2, because it cancels out in both directions which is a crucial point I left out when considering my setup. :facepalm:
  7. May 17, 2019 at 11:59 AM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
  8. Jun 7, 2019 at 9:22 PM
    lpfe42
    lpfe42 [OP] Well-Known Member
    Kenny
    Santa Barbara County
    20 DCSB CEMENT
    5100/887 Icon uca
    265R75 16D KO2'S. 18MPG on average
