drive shaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bduane, Jan 25, 2015.
  1. Jan 25, 2015 at 9:31 AM
    bduane
    bduane [OP] Member
    Bernie
    Mn.
    '99 tacoma
    lift,wheels
    my drive shaft went out on me yesterday on my '99 Tacoma. What is the part name for this on the inside that went out? Haven't seen this before,was on when bought.
  2. Jan 25, 2015 at 9:49 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    You might want to have your post moved to the 1st gen Tacoma forum.
  3. Jan 25, 2015 at 11:01 AM
    bduane
    bduane [OP] Member
    Bernie
    Mn.
    '99 tacoma
    lift,wheels
    ok,Thanx.
  4. Jan 25, 2015 at 11:49 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
  5. Jan 25, 2015 at 11:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
  6. Jan 25, 2015 at 12:36 PM
    Chuy
    Lakeside, CA
    Silver Taco
  7. Jan 25, 2015 at 12:50 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You should be able to rebuild that with a couple of universal joints and some time. Just make sure to match mark everything to get it back together correctly.
  8. Jan 25, 2015 at 2:16 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    You can't normally find off the shelf ujoints for that double cardon. Toyota only sells the whole assembly. If you somehow find the rare ujoint that might work, it's kind of a bitch to do, and don't mess up the ball, there's a toon of little needle bearings that like to fall out. the whole thing is a wear and tear item, so it might be a good idea to find a decent driveshaft shop and they will rebuild it for much less than a new one.
  9. Jan 26, 2015 at 4:06 AM
    bduane
    bduane [OP] Member
    Bernie
    Mn.
    '99 tacoma
    lift,wheels
    the ball is what went out.
  10. Jan 26, 2015 at 10:35 AM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    And unfortunately not easily repairable. I'd be looking for a good used shaft, even if it needs new u-joints. If that fails, visit a local driveline shop and have yours redone, or a new one made. And grease the new one regularly.
  11. Feb 11, 2015 at 1:58 PM
    wolfgang
    wolfgang Active Member
    south USA
    12 4 door prerunner
    Air Intake system
    Cardigan joint
  12. Feb 11, 2015 at 2:25 PM
    wolfgang
    south USA
    12 4 door prerunner
    Air Intake system
    After 98,000 miles I got a new drive shaft on my extended warranty, the difference is amazing, it's like I bought a new truck. What's weird is that the old drive shaft was in good condition no play anywhere. The new drive shaft is completely redesigned and is very different than the old one, it now has some sort of harmonic damper on it. The symptoms were: Felt like it down shifted while stopped or that I had been rear ended while stopped. ( Waiting at a traffic light)
    Other things that have been replaced are all 4 wheel bearings. Removed and reinstalled the windshield several times for a strange wind noise. And ( drum roll please ) the POS Entune radio twice, still does not work properly. This is my 4th Tacoma, overall they are OK, drove a Chevy new midsize and it needs more refinement all over. Toyota better pay attention and listen to us owners though.
  13. Feb 12, 2015 at 6:07 AM
    bduane
    bduane [OP] Member
    Bernie
    Mn.
    '99 tacoma
    lift,wheels
    Thanks all. I found a shop close to me that rebuilds them. Got the whole thing rebuilt and lengthened for just under $400.00
  14. Feb 12, 2015 at 12:57 PM
    Buckoma
    Buckeye, AZ
    2016 TRD Sport 4x4
    That's not bad. The two specialized ujoints for the joint are usually about $85 each, so by the time you factor the ball rebuild, labor, shop fees, etc... fair deal. Hope you're gtg.
