driveline vibration fix write up..................may work for you too.
Discussion in 'Technical Chat' started by tacomaman06, Mar 2, 2009.
  1. May 5, 2010 at 11:19 PM
    #61
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    A little research, and I seem to be correct.
    Galvanic Corrosion
  2. May 14, 2010 at 3:43 PM
    #62
    WOLVERINE
    WOLVERINE Member
    Newfoundland
    2010 DC TRD Sport
    timbrens
    I have a 2010 DC TRD Sport and noticed from day 1 that it had a slight vibration at hwy speeds on the drive home. I asked the dealer if they were all like it and he let me test drive another one and sure enough they are all like it from new. Annoying really when on the hwy. I told the dealer I'll live with it if I had too but if this cures it, I'll be freaking smilin!
    I will try this when I get home in a couple of weeks.
    So I guess it makes the driveshaft staighter from the Tcase to the rear diff through the Carrier bearing, hey? That's my guess! When I do it I'll tie a string from end to end and see what the difference is...
    Good find if it works....
  3. May 14, 2010 at 5:03 PM
    #63
    gjbonner
    gjbonner Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
    let me tell you i was amazed at the results. it is sooo much smoother now! all from a 1/4 inch worth of washers:)
  4. May 14, 2010 at 5:29 PM
    #64
    OCTaco
    OCTaco Well-Known Member
    OC
    '16 TRD Sport DCSB
    Is this only for trucks with lifts?
  5. May 14, 2010 at 6:22 PM
    #65
    gjbonner
    Guy
    Northern Idaho
    no it is not for just trucks with lifts.
  6. May 31, 2010 at 4:31 PM
    #66
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    For what its worth, I will try this sooner rather than later. For the record though, I had a 2" spacer in the front and the TSB done for the rear. With this set-up, I was getting the "BUMP" as if someone had tapped my truck from behind when stopped at a light. Well, I made the upgrade to Bilsteins 5100's all the way around and still had the BUMP. The front bilsteins were set at the highest setting (2.5). Just recently, I added a leaf to the rear and the BUMP went away! HURRAY!!! Since then, I have now been experiencing the same vibrations you all have said. Mine have been progressively getting worse and more noticeable at different speeds. It real obvious when approaching an incline, never a decline. I'm noticing these vibrations at low speeds, then at 27 MPH, roughly again at 47 and then 57. I say all this to see if there is some sort of consistency in what people are feeling.
    Lifted rear - Vibrations?
    Lifted front - Bumps?
    I wanted to also make sure this small plate on the bottom is what I need to do to see if this works for the set-up I have.
  7. May 31, 2010 at 5:49 PM
    #67
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    try it out man,,,,,1/4 inch spacer has worked for lots of folks...because it drops the barrier bearing a tad......letting the driveshaft get a better angle.
  8. Jun 7, 2010 at 11:33 PM
    #68
    Leadgolem
    Greg
    Littleton, CO
    Are these speeds lining up pretty closely with your shift points? It sounds like the more torque your using the more your vibration. When my first gen did that is was a bad U-joint. Might be worth the 5 minutes to crawl under your truck and yank on the U-joints. See if any of them feel loose. Though, unless you've been wheeling I can't really see a U-joint going out that fast.
  9. Jun 19, 2010 at 9:36 AM
    #69
    hoeflich
    hoeflich Its all mod on the inside
    florida
    96 3.4L 4X4
    Stuff
    So, had a 2" AAL and Billy 5100's installed, noticed the vibration the next day...went and installed 1/2" worth of washers and #10-1.25 x 50mm bolts...low and behold I noticed while doing this, that the damn gas tank metal trim was bent back at a 90 deg angle rubbing on my shaft (how cool is that to write!) so shit, I dont know which one was the issue, but...there both resolved/installed, and I dont vibe!
  10. Jun 27, 2010 at 10:58 AM
    #70
    StandupTaco
    StandupTaco Well-Known Member
    2010 DC TRD Sport
    Tried it out on my stock truck for shits and giggles and it doesn't work. Oh well....
  11. Jun 27, 2010 at 1:11 PM
    #71
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you problem...especially if its in the driveline......vibes when you take off or slow down could have to do with the torque converter or driveshaft.
  12. Jul 20, 2010 at 6:59 PM
    #72
    Dobri56
    Dobri56 Well-Known Member
    Dan
    Massachusetts
    2012 trd sport longbed
    Smitty Bull bar, PIAA 540, MBRP turn down exhaust, Tractor trailer tool box. Black headlight mod, fog light mod, TRD seat covers, tacoma floor mats, Recon under tailgate light
    Ok I'm doing a lot of research I wanna lift my truck but want to avoid the vibe..... could someone point me in the direction of doing this right. I really want to do the billy's. not looking at a full 3 inch lift don't see that i need to have new tc a arms
  13. Jul 20, 2010 at 7:23 PM
    #73
    Dobri56
    Dan
    Massachusetts
    Also I thought that the issue was with the front diff not the drive shaft?
  14. Jul 30, 2010 at 7:48 AM
    #74
    WorldDestroyer06
    WorldDestroyer06 Active Member
    Pablo
    Paraguay
    06 2.7 Access Cab 4x4
    upgrade front Susp with OME heavy duty Bilstein with 2.5'' spacer, secondary filter remove, throw in a K&n High flow Airfilter, in the rear 1'' aals, back light mount in bed rails, customize fuse box, led stripes in engine compartment, tint all around, head unit swap for a single din pioneer deh 6300ub.
    i have a driveline vibration between 55 mph - 70 mph then it stops the vibration but is very anoying.. i got balance and new tires but still:mad: i have custom made spacers may this be the problem too???:confused:
  15. Aug 13, 2010 at 9:00 AM
    #75
    HNGNON
    HNGNON New Member
    New Orleans
    10 Sport
    I'm new to this but would like a set of the spacers also. 203 Villere Dr., Destrehan, La 70047
    Thanks
  16. Sep 16, 2010 at 11:43 AM
    #76
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    The shaking stops after 13 seconds, but left the video running to show that my speeds were increasing and that the shaking did stop. Bilsteins in the front (2.5) and on the rear. Back has tsb and aal. That's it.
    I can't say I've tried the spacer to lower the drive shaft yet. Over the last 2 weeks now, the vibrations have progressively gotten worse. I took a video from inside the truck at a take off from a light.
    Details: slow take off, between 25 & 40 mph on flat streets or slight uphill. The shifting has been hard, especially the downshifts (hard knock). I'm seriously concerned about it now.
    http://www.youtube.com/watch?v=X8qR-J7RLJU
    For now after searching all the treads again, I seen the following potential problems...
    1) Torque converter
    2) Zerks that need greasing
    3) Unbalanced driveshaft (spacer drop)
    4) Bad rear differential
    5) Carrier bearings
    6) Bad U-Joints
    7) ?
    Anyone else have something to add?
  17. Oct 11, 2010 at 12:50 PM
    #77
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    slight vibration at 50-55 - very slight, went to lowes and baught 5 feet of 1" wide 1/4 thick alu, cut two 1.35" lengths, drilled 3/8 inch holes and then hit them with a coat of rustoleium engine enamel high temp high gloss paint - letting it dry, and will mount and post back.:D
    total build time..ten minutes tops. looks like it'll mount in two minutes - if this works i'll be one happy dude.
  18. Oct 11, 2010 at 3:04 PM
    #78
    Coreyjon
    Upstate, Ny
    note to self - 3/8 hole too small, went two sizes bigger, 13/32" - or you could go 7/16 if you didn't have 13/32. repainted, will mount in an hour.
    then to test drive!
  19. Oct 11, 2010 at 4:45 PM
    #79
    Coreyjon
    Upstate, Ny
    1/4 inch spacers installed, there is still a very slight vibration, but it could easily be the new tires installed, plus the new lift, with the front and rear of the truck being much stiffer it could also just be more road "noise" felt in the truck because of how much firmer the suspension is not to mention the new tires, so all in all I'm not going to go crazy - very happy with the way it came out. The spacer installed made the driveshaft look like it was a straight b-line to the rear axle instead of the slight bend that was there after the lift.
  20. Oct 13, 2010 at 9:41 PM
    #80
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    do you think just stacking washers to get 1/4" and placing em in between or just getting a 1/4" washer with a 3/8" diameter inset hole will work?
